Is this a safe way to add water bottle mounts?
#76
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
10 years? That's longer than many bikes here even stay in one's possession.
Seems like a win.
I drilled out a frozen river that was loose in a cannondale frame. Installing a new one was simple, it took 2min and a couple of spare nuts/bolts to tighten.
I will be haply to not think about it for the next decade. I will be happy if I still have the frame a decade from now, truthfully.
Seems like a win.
Either way, I prefer not to be the one to create a frame modification headache that might be regretted by a future owner, if I can help it.
Case in point, here's a Raleigh Super Grand Prix that I was forced to pick up in a lot from the LBS to get a Professional frame. Looks half decent...
...until you get to the water bottle cage carnage:
Yes, these were most definitely not in line. Someone tapped right through the tubing. In retrospect, grinding the lower hole larger and to the left might have worked to allow a rivnut to be installed centered in the frame.
I'm not saying one shouldn't do what they want to do with their own bike, but anyone not fully intending to live with the modification should at least consider the future owner before committing to this.
-Kurt
Likes For cudak888:
#77
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
This. I'm no stickler for originality, but I draw the line at making irreversible frame modifications, especially to "nice" bikes. Peugeot UO-8? Maybe, if no other option is available. PX-10? Nope. My Frejus or Automoto? No way.
Likes For smontanaro:
#78
Bikes: Several
Quoted: 207 Post(s)
Liked 1,042 Times
Likes For Brad L:
#79
Bikes: Several
Quoted: 207 Post(s)
Liked 1,042 Times
IF I were to use rivnuts on a frame, I’d do with the bottom bracket removed. I don’t like the thought of the metal shavings getting into the bottom bracket bearings.
Likes For Brad L:
#80
Quoted: 834 Post(s)
Liked 2,126 Times
Case in point, here's a Raleigh Super Grand Prix that I was forced to pick up in a lot from the LBS to get a Professional frame. Looks half decent...until you get to the water bottle cage carnage: Yes, these were most definitely not in line. Someone tapped right through the tubing. In retrospect, grinding the lower hole larger and to the left might have worked to allow a rivnut to be installed centered in the frame...
-Kurt
-Kurt
#81
Liked 4,395 Times
This is what I’m dealing with on my 1947 Ciclo Piave. Someone added cable guides and bottle cage bosses sometime in its past. The cable guides can be easily removed, but my framebuilder friend says I’d need to replace the downtube to remove the bosses. Of course, then I’d need to rechrome the head lugs. These mods definitely created a lot of work for me.
-Kurt
#82
Quoted: 834 Post(s)
Liked 2,126 Times
Coincidentally, I just came upon these Elite cage brackets today which I haven't seen before. They seem a bit more elegant than some of the other options.
https://www.deporvillage.net/elite-v...e-cage-bracket
In addition, I notice they also offer a vintage-style, Eroica-branded bottle cage for the handlebar (currently on sale for $25.60):
https://www.deporvillage.net/bottle-cage-elite-eroica
Likes For gaucho777:
#83
Liked 4,395 Times
That looks promising, pity that it's a 3D render and not a picture of the actual part.
I remember when some repop bottle holders ran as much as the real thing, so that L'Eroica piece isn't too bad a deal. Pity the base isn't a bit more encapsulating for bottles that aren't strictly rigid though.
-Kurt
-Kurt
#84
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
Looking at all these other klutzy dodads, my klutz is looking more and more genius. LOL.
#86
Quoted: 1949 Post(s)
Liked 2,010 Times
I like the look of those elite clamps. https://www.elite-it.com/en/products/vintage
But I don’t want to interfere with “Peugeot” at the moment. Minoura to the rescue. Bonus is that it fits over the center of the stem and leaves the tops clear for my hands.
73 PA-10e
73 PA-10e
Likes For Brad L:
Likes For 1simplexnut:
#89
blahblahblah chrome moly
Quoted: 1174 Post(s)
Liked 2,570 Times
Your Piave is gorgeous and well worth that concours-level paint though, so I expect you would want whatever it takes to look perfect again. But I'd advise against rechroming, that is liable to do more damage than filling the holes would.
I made the plugs with a flanged cylindrical part sized to fit the hole, just long enough to reach through the tube wall and a little more (~1 mm) for an inside fillet of silver. The flange on top is just barely there, just big enough to prevent the plug from falling through. All the flange is filed off after brazing.
The brazing must be done by someone well-versed in thinwall bike tubing, not a muffler repair shop! The filing step is equally tricky because if the file tilts to one side or the other, it can nick the tube. This is the thin unbutted part of the tube, so any file marks are to be avoided. On such a fine frame, I would use only my finest files (fine here meaning opposite of coarse) and work slowly. I have seen fairly horrible coarse file marks left in frames from even hero brands like <redacted> or <redacted> (no need to name names here!), so don't assume a framebuilder is good enough at filing. Some might be skillful, but in too much of a hurry. You want someone slow for this job!
I am not angling to to do this repair, I am retired, all my framebuilding was more than 25 years ago.
Mark B
