Bearing sizes needed for '75 Fuji S10-S - help !
minimalist cyclist
Bikes: yes please
Quoted: 1119 Post(s)
Liked 1,642 Times
The slowest rebuild in BF history is a step closer to completion this w/e if I can get some help with the correct bearing sizes for a '75 Fuji special road racer S10-S. Somewhere in the years of storage after being taken apart the original rusty bearings have escaped like socks in Jerry Seinfeld's dryer .
I have the Fuji catalog specification page and it's all original components, so everything I need bearing sizes for should be listed here. The only specification not listed might be the Sunshine hi flange hub model # is 5345. Any help on bottom bracket, top/bottom headset and wheel bearings will be much appreciated !
Quoted: 2026 Post(s)
Liked 1,096 Times
As a general rule, cup-and-cone hubs use 3/16" bearing balls in front, typically 10 per side, and 1/4" balls in the rear hub, 9 per side. Cup-and-cone bottom brackets use 1/4" balls, 9 or 10 per side depending on whether they are in a retainer or not. Headsets vary but many use 5/32" balls and the count is usually between 20 and 25 per cup depending or use of retainers or loose balls. You can buy loose bearing balls in packages of 100 from any mail order bike shop, industrial supply house like Grainger or even Amazon. Get Grade 25 balls. They are better than necessary but cost so little they are worth it.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
Liked 1,096 Times
señor miembro
Liked 6,488 Times
minimalist cyclist
Bikes: yes please
Liked 1,642 Times
señor miembro
Liked 6,488 Times
Liked 1,096 Times
señor miembro
Liked 6,488 Times
minimalist cyclist
Bikes: yes please
Liked 1,642 Times
Another question - I'm going to make this bike a single speed, but still use the original rear 14-28 cluster along with just the 50 T front big ring. I understand with no derailleur the alignment is important and I need the chain to stay pretty much in line. With the relatively small large ring, can I take apart and change the order of the rear cluster so that the smallest 14 or maybe the 17 T cog is directly in line with the front ring but keeping the 5 ring spacing I'll need? I am a masher and think this would work best for my riding. Here's the rear cluster
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
N.B. the headset uses 5/32" balls, 20 in a retainer in each race IIRC.
Old fart
Liked 3,400 Times
A single freewheel would work, but AFAIK only White Industries offers a 17t option, and those aren't cheap. Affordable single freewheels are available in 16 or 18 tooth counts. 15t is the smallest sprocket you'll find on a single freewheel that will fit your hub. Smaller tooth counts are available, but require a special BMX hub.
Likes For JohnDThompson:
minimalist cyclist
Bikes: yes please
Liked 1,642 Times
No, the two smallest sprockets are threaded, while the larger three sprockets are splined.
This bike was such a rust bucket that everything not green got painted black...going for the very-used messenger look
Old fart
Liked 3,400 Times
I actually have a 16 courtesy of my buddy 3speedslow but looking at it on the hub doesn't look right to me. Does this look like it will be in-line or do I need some kind of spacer?
minimalist cyclist
Bikes: yes please
Liked 1,642 Times
I should know later today when I get into it - I'll come back for more help if it doesn't .... thanks John D !!
EDIT ended up using the original freewheel on the 2nd (17 T) sprocket and it works great. It's on the road finally !
