Addiction 2021.2
#2951
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Im riding 25mm tyres now.. my weight is probably south of 230 lbs. I don't want to get on a scale yet. But I'm lighter than I've been in quite a while. Errr.... skinnier anyways. I'm riding mi. Roads. They suck. Holes, cracks, chip seal, you name it.
#2952
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
It's your call but I bet you would do ok with something around 95-100F, 100-105R. Give it a try. As always, YMMV.
Likes For datlas:
#2953
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,898 Times
Yeah, I was gonna say. I'm 200 and I run 85F/90R on 28s.
#2954
he said member
Bikes: yes please
Liked 1,951 Times
#2955
Quoted: 10236 Post(s)
Liked 5,184 Times
#2956
Liked 11,898 Times
The holes are a problem, because obviously you don't want to pinch flat. But lower pressures would hep with the cracks and chipseal, and you may be amazed at how much nicer it feels. Just changing from 110F/120R to 90F/95R made both the Battaglin and the Cannondale a whole lot comfier. I intentionally rolled through some patches of cracked pavement to test this, and it was amazing. I can still feel it, but the bike doesn't jump around.
Do you have room in the forks and stays for 28s? Because that makes a big difference in my experience.
#2957
Liked 11,898 Times
Hey, there's an idea! Matching socks! I'll need at least 7 pairs, though possibly the Ritchey and the Cannondale are close enough I can get by with the same color.....
Do they make socks in Electric Blue?
#2958
Quoted: 9653 Post(s)
Liked 6,365 Times
Likes For Mojo31:
#2959
Liked 6,365 Times
Those work, Bam.
#2960
Quoted: 389 Post(s)
Liked 255 Times
I weighed 220 when I raced criteriums on good pavement, with 23's, I ran 140psi. Now, at 210, with 25's, it's usually 115r, 110f. With 28's I'm also 90r 85f.
Edit: These are all on old narrow rims. There's so many variables. The 28's that I have are stiff sidewalls. I think they're Schwalbe Durano's? And if I know the route won't have a bunch of potholes, I'll lower my 25's to 110/105.
#2961
Liked 11,898 Times
Tubular wheels for Mrs. Peel are mostly cleaned up. The butterknife trick worked really well on the rear wheel to remove the old glue, but the front wasn't quite as crunchy. I need to get me some mineral spirits.
The rear is built for a freewheel, not a cassette, so I got a 13-26, which gives me a lower gear than I have with the clincher rims - at least till that 26t cog I ordered arrives. I installed it and then checked to see how it shifted, and discovered I'll have to reset my limit screws when I swap wheels. It wouldn't shift onto the biggest cog, and then it overshot the smallest. . I ended up dropping the wheel out to get the chain back out.
Tubular tape arrived last night. Tubulars to arrive today. I guess the first thing to do is to stretch them onto the rims and blow them up, right? Second COVID jab today, so I hope I'm up for it!
#2962
Liked 8,925 Times
genejockey gets it.
#2963
Quoted: 20810 Post(s)
Liked 9,456 Times
On modern rims, I'd say 19+ mm int width, 75psi is entirely reasonable on 28s for a 200lb person. He'll, I ran 75psi on my Assaults (17mm wide). With my current wheels, 23mm wide, I'm running 28s at +/-60psi, but I'm firmly under 200 these days.
Likes For WhyFi:
#2964
Liked 8,925 Times
#2965
Liked 8,925 Times
Hey MoAlpha I have a couple patients who clearly have dysautonomia. I actually think they have MSA but I am not qualified to differentiate between PSP, Parkinson's, MSA and dysautonomia, NOS. They each have seen local neurologists and downtown/academic neurologists, and in both cases have essentially been told thanks for coming, we have nothing for you, treat the symptoms, and don't come back.
Is that state of the art still? The patients are very frustrated.
#2966
Liked 11,898 Times
#2967
Liked 8,925 Times
Likes For datlas:
#2968
Habitual User
Quoted: 4946 Post(s)
Liked 8,086 Times
Check out Swiftwick Aspire 4 in "Lagoon Blue".
#2970
Liked 6,365 Times
#2971
VFL For Life
Bikes: Velo Volmobile
Quoted: 28610 Post(s)
Liked 1,857 Times
#2972
VFL For Life
Liked 1,857 Times
#2973
Liked 5,184 Times
Gusting 35 here, made for an interesting ride. As much as the wind sucked, The pollen was way worse.
#2974
Liked 9,456 Times
#2975
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Tange Champion #2
EDIT: Brazed by Tsunoda. The bike has decals from both. Later on, Lotus (which was really just an American importer who had the bikes build under contract, I believe) had them build by Cinelli, in Italy, from Columbus steel. Apparently Champion #2 is equivalent to Columbus SP, so that's better for an old fat guy like me.
