Affordable Modern Steel Road bike options
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 202 Post(s)
Liked 71 Times
I've decided for my next bike I would like a modern road bike with a steel frame. I really like the ride of my vintage bikes, but miss my brifters and indexed shifting. Don't really want to modify an old bike. My only real qualifications are steel frame, wider tires like 30mm+, endurance geometry, and indexed shifting drivetrain with brifters. I want to start searching the used market for one. Hoping for some suggestions of brand and model that I should be looking for. Thinking like a $500 budget. I've seen some Jamis bikes that seem to meet what I'm looking for, but haven't seen one in my size. I'm hoping there are other brands and models I should be looking for. Thanks in advance for any suggestions.
check out the Frugal Average Bicyclist
Frugal Average Bicyclist The goal here is to help you keep cycling on a budget.
Expired Member
Quoted: 3674 Post(s)
Liked 5,432 Times
Anything is possible but I wouldn't expect many choices with that budget.
Likes For shelbyfv:
Likes For Leinster:
Quoted: 202 Post(s)
Liked 71 Times
Yeah I've seen some that meet all of what I'm looking for in the price range except for size. Hard one to search though as it mostly turns up vintage steel bikes.
Why not? If what you're after is the feel of the older bikes, the easiest way to nail that is to use an older bike as a base. Modern steel often uses wider tubing and ends up a lot stiffer.
In many cases it's not like you'd actually need much modification anyway. As long as you're not buying something really old, or that uses a bunch of French standards, adding brifters is unlikely to require much "modification" besides re-spacing the rear end.
Likes For HTupolev:
Quoted: 202 Post(s)
Liked 71 Times
Sunshine
Quoted: 10964 Post(s)
Liked 7,490 Times
Don't even look for a specific size since if you look for '56cm', you may miss out on what someone calls 'M/L' or a 55cm that fits like the 56 you want due to geometry.
As for brands with modern steel frames...
jamis, kona, surly, all city, black mountain, fairlight, soma, mason, and many more.
Likes For mstateglfr:
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
20c tires became a thing in the late 80s/early 90s, but outside of that era, tire clearance really shouldnt be a problem. Even in the mid-80s youd see bikes like Fignons with his Modolo calipers that could probably easily take a 30.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Out of your budget but I keep looking back at Waterford made frame sets. I have all the parts from my old broke Madone but my carbon wheels are rim brake.
https://www.benscycle.com/milwaukee-...BoC8i4QAvD_BwE
Quoted: 2432 Post(s)
Liked 638 Times
I was going to recommend the Soma Fog Cutter but then I saw your small $500 budget. Good luck with that. No one can tell you what to look for in used bikes, we have no clue what's for sale where you live.
Quoted: 202 Post(s)
Liked 71 Times
https://carsoncitybikeshop.com/priva...me-52cm-black/
for now Im gonna stick to finding something used though.
Likes For BikingViking793:
Le savonnier
Bikes: I can count 'em on one hand
Quoted: 729 Post(s)
Liked 602 Times
yeah that seems like a fun option down the road. This is more of a budget option:
If you're talking about modern gravel tires, sure. But in your OP, you wrote "30mm+." Tons of quality vintage steel road frames can fit that no problem, especially if you're looking at early 1980s and before.
Quoted: 202 Post(s)
Liked 71 Times
And those will all have quill stems. I know it can be done, just not really interested in changing a vintage bike.
Quoted: 202 Post(s)
Liked 71 Times
Will a Surly Cross Check frameset work well for me? Thinking I like it a bit better than the New Albion and have a bike I could take most the parts from to build it up.
Sunshine
Liked 7,490 Times
The CC geometry is definitely longer and lower than some other options, at least thats true at the larger end of the frame sizing.
You have had many bikes and presumably know what works well for geometry so I would guess you know if the CC geometry works in your frame size.
Quoted: 7652 Post(s)
Liked 3,473 Times
It seems from this post (and the half-dozen bikes in your info) that you have considerable experience cycling, and ridiculously unrealistic expectations. I had to go back and check that this wasn't a zombie post form ten or more years ago.
Except for big-box stores, I don't know anybody selling quality bikes (on par with what you already ride) for $500. You can get some decent but outmoded bikes from Bikes Direct, with either ancient 7-speed or 8-speed Claris, cheap, heavy wheels, cheap heavy seats and seat posts, etc ..... Stuff you probably wouldn't enjoy riding. And certainly nothing you would call "modern."
Quoted: 202 Post(s)
Liked 71 Times
Really?
Quoted: 35 Post(s)
I've converted several vintage frames. Huge project, even for one that seems simple, just because stuff always comes up that you don't expect. And likely not made easier given the current parts shortage. Fun stuff if you're into it but if not...
I think an older Surly is a decent idea. I don't know about pricing but you might get lucky with a ~10 year old model.
Good luck
Likes For sanmi:
if I may recommend a custom Ti from chinese factory, I got one for around $500 (frame only) been 3 years on it without any issues. But for the record the ride quality is a bit "harsher" than my vintage steel or my modern steel CX bike (with the same wheelset, tyre, and saddle/seatpost combo)
Likes For bleui:
Bikes: Gitane Course, Paris Sport, Peugeot AO8, Peugeot Bretagne, Peugeot Premiere 85, Peugeot Premiere 86, Peugeot ANC Halfords Team Replica, Peugeot Festina Team Replica, Motobecane Grand Sport, Motobecane Super 15, Raleigh Pro Race, Raleigh Stratos, BSA
Quoted: 117 Post(s)
Liked 427 Times
A Thorn Audax frameset is around about your budget. I've seen a few of them on Audax and BCTC rides - they look very well made and the owners are always complimentary about them. They'll take tyres up to 35mm. The people who run Thorn are very good and they will ship overseas.
https://www.thorncycles.co.uk/bikes
Likes For ExPatTyke:
1984 Klein Performance with your choice of components
