Chainring BCD questions
I’m considering the purchase of the Zizzo Liberte bike as my first folder. Its specs for the crank include ”48T Prowheel aluminum alloy crank arm 170mm black anodized w/ black aluminum chainring cover”. Does anyone know the BCD for this crank? I’m concerned that the 48T ring is too small and might want to swap it out for a larger chainring. Any thoughts on making this change such as max usable size, shifting performance with larger chainring? Also, does the chainring have alternating narrow-wide teeth to keep the chain from jumping off on shifting? Thanks for any comments.
Quoted: 573 Post(s)
Liked 118 Times
Just measure the distance from center to center (in mm), and double it to get its BCD. Could be 110 or 130
Then, get a 50/52T chairing with the right BCD and number of bolts (5, unless it changed).
Thanks for your reply. Was hoping to find an owner here who could verify. I looked at Pro-Wheel’s site, but couldn’t find an exact match for the crank. guess I’ll email Zizzo for more specs.
I'm only guessing, but from the picture it looks like a 110. You could certainly find a 52T chainring for it. As for whether it's narrow-wide, it would be unusual to have both narrow-wide teeth and a chainguard on a chainring.
From review pics on Zizzo’s site, it appears the chainring guard is only on the outside and not on both sides of the chainring. That is what made me wonder about the teeth sizes.
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 452 Post(s)
Liked 405 Times
Why not just contact Zizzo and ask?
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
I did contact the company via email this morning and was pleased to get a reply very quickly. The BCD is 110 and the chainring is not narrow/wide. There is a chainguard on the outside of the chainring and a chain guide on the inside. A larger chainring can be used as long as the chain is long enough or replaced if needed. I have a road bike I converted from double chainrings to a single and used a narrow/wide ring which works great. To me, this route seems more elegant than using a guard/guide.
Quoted: 164 Post(s)
Liked 44 Times
its either 110 or 130 , seems like all of prowheels 5 arm cranks are 130 , but i would never run a 48 chain ring on 1x8 , what IDIOT do they have gearing these bikes , unless you live in a completely flat city and never go outside of that , and on a folding bike with flat peds , NOOOOOOOOOOOOOOOOO , seems like you could easily swap the crank for a cheap used carbon and run a 39 or 36 , id at least try to get 1x10 if you are running 48t , all of their cranks seem to come with a chain guide so i wouldn't worry about the chain coming off unless you crash !
I realize I'm very late to the party here, but I know the answer. I had chance to check out a Liberte a while ago and it had a 110 BCD crank. I was really hoping it had a 130 BCD. Hope that helps.
Quoted: 4806 Post(s)
Liked 3,932 Times
