Winter project bike frame protection
My wife and I bought a new bike for each in September. My plan this winter is to place clear tape or similar material on the frame of each bike for frame protection. Does anyone have suggestions what material works best at a reasonable cost <$60 per bike and where to purchase? The bikes are road touring type and I live in Canada.
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
If its a decent quality paint finish, it will last longer than the person riding the bike, even when subjected to adverse conditions
Likes For Moisture:
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
They make a special film for that you can find online, but like Moisture mentioned, if it's a good quality paint job and most good bikes come with quality paint then just put a good quality wax on it and spend a little time cleaning it after rides. My old Giant looks good and it's been around a while. I don't wax it, seems excessive for an old bike, but I clean it after every wet ride.
Drip, Drip.
Liked 193 Times
I recommend to not worry about the cosmetics so much. Just go out there and enjoy your bike. Nothing like seeing my bike covered in dirt, mud, and scratches. It consoles me to confirm that I've been thrashing the thing duly.
Likes For Moisture:
Quoted: 3460 Post(s)
Liked 1,466 Times
Use a good car wax on the bike frame and components before winter comes. If you ride a lot, maybe reapply once or twice before spring.
Do they use very much de-icing chemicals where you live on the roads? If so, your chain will be shot by spring, give it a good wax lube before each ride but plan on replacing it in spring. I do not put many miles on my bikes in winter, so I usually just start in fall with chains that are near the end of their life span and replace in spring.
Thank you for your replies to my post. I will take your advice in consideration and dial back my intentions of plastic frame protection. The main areas I am concerned about are where the bike carrier clamps down to the frame of the bikes. Keeping the bikes clean and using a quality wax sounds like good advice and much more simple.
Liked 1,466 Times
A lot of the worst of it had already melted before I took the photo. Note how much icy crud built up on the wheels, spokes, etc., that has not melted off yet.
My bike is the yellow one. I am glad I had an internally geared hub instead of a derailleur bike for this trip, the drive train would have been a bigger mess to clean up.
Quoted: 2604 Post(s)
Liked 1,933 Times
I think the biggest problem you'll have with the finish is leaning the bike up against something and watching it fall down, scraping all the way. Very painful the first time it happens.
You might try careful application of some clear packing tape on the seatstays, top tube, and fork to prevent that scraping. I'm not sure what it would do to any decals, though.
Liked 1,466 Times
If you really wanted to wrap something on the frame, I would recommend avoiding anything with good adhesive. Maybe a kitchen cling wrap like Glad Press N Seal would be better.
Go to Amazon and search for 3M helicopter tape. It's the stuff they put on the leading edges of helicopter blades to protect them from damage. It applies like a decal and it works great. There are a variety of widths and shapes you can get it in. It's also the same stuff the automotive industry uses to protect from rock chip damage on hoods, doors etc... There are a number of die cut versions that are for protecting chain stays from chain slap, from cables rubbing on head tubes etc.... We just bought it in a roll and applied it to the various tubes.
It's easy to apply - you use a hair dryer to keep it soft and soapy water to apply it like a decal. There are tons of videos on Youtube about how to do it. It's easy if you're patient.
We did this last season on my wife's custom Gunnar frame for her gravel bike and a friend that also bought a Gunnar frame. You can't see the stuff but it is super touch and it will protect the paint in a big way. This bikes gets ridden on a lot of gravel roads and it the tape has done a terrific job of protecting the paint from chips. We applied it on the chain stays, the underside of the down tube and the fork blades. Highly recommend it - wish I'd done it on one of the frames of a bike I'd built.
For what bikes cost these days, and if you care about taking care of your stuff, this is the answer.
Yeah JohnJ80 just gave you the right info. I used the ISC Racers tape and if you read the reviews they are full of bikers. Now if you have an area of the bike that takes a heavy beating you might want too look at 3m 2228
https://www.amazon.com/3M-Scotch-Moi...5151931&sr=8-5
I use it on my chainstay and under the bottom bracket on my mtn bikes. It is very thick and rubber like but it is a bit messy to take off.
Amazon won't be your only available source, but a good start
