Addiction 2021.2
#1251
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,530 Times
#1252
Quoted: 18415 Post(s)
Liked 15,550 Times
Happy National Glazed Spiral Ham Day!
Likes For phrantic09:
#1254
Quoted: 10236 Post(s)
Liked 5,184 Times
Woohoo, after much fiddling around, it looks like this Origin8 fatbike front derailleur adapter, which is made for the other type e-type derailleur, oriented upside down will work just fine if I drill a hole in it for the "Bracket Fixing Bolt B".
With the drive side cup tightened down, it actually holds everything in place without said bolt, but I'd feel a lot better with a bolt in place. Bolt finding, hole drilling and tapping will have to wait til tomorrow night though.
Gonna be pretty psyched to go 2x on this thing. Will have to be 2x10 for a while til I can trade an 11-46 for an 11-42. Shimano says the rear derailleur isn't happy with 2x and a 46T big cog. Oh, I guess I have to dig up another chainring too.
#1255
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Likes For Trsnrtr:
#1256
Liked 5,184 Times
woke up with two questions this morning.
My cervelo BB is a Bbright 24x90. I found the replacement, but if I wanted to go with something else can I? Is there a simple way to see what is compatible?
If I wanted to replace the bearings in my superteam wheels, do I need to figure out what specific size bearings these wheels take.
Did a light google search last night on both of these topics. Didn’t get very far. Not an emergency, just curious.
#1257
Super Modest
Liked 4,620 Times
Quick spoke story:
Many years ago, I came in from the field when my secretary told me that we had a copier repairman working on our machine and was totally flummoxed. I checked on him and he had manuals and schematics all laid out on our break room table, meanwhile tapping his forehead with a spoke. I had been using a spoke for a book mark in a tech manual and it had evidently fallen into the machine while I was making a print copy.
He had found it during routine maintenance and was trying to figure out where this threaded hooked thing was supposed to go in our machine.
Keep the chain tight!
Likes For Trsnrtr:
#1258
Liked 15,550 Times
What does one wear to a vaccination? Don’t think I’ve had one since I was a wee little thing.
#1259
Quoted: 3361 Post(s)
Liked 3,638 Times
I'm cheap thrifty and spokes are more expensive than I want them to be, so it really helps me out to know how many I have on hand.
Of course, knowing what length they are just ensures that the ones I have in stock are never the correct length, but it makes me feel better inside
#1260
Mostly Harmless
Liked 4,530 Times
Quick spoke story:
#1261
Mostly Harmless
Liked 4,530 Times
Likes For rjones28:
#1262
Mostly Harmless
Liked 4,530 Times
#1263
Quoted: 20810 Post(s)
Liked 9,456 Times
#1264
Bikes: Shmikes
Quoted: 10170 Post(s)
Liked 5,863 Times
As for the wheels, look up the hub on the mfgr's web site and it should specify a bearing size.
Why are you thinking of replacing this stuff?
Likes For MoAlpha:
#1265
Quoted: 6963 Post(s)
Liked 10,964 Times
#1266
Liked 9,456 Times
I wouldn't do anything with the wheels, yet. No real reason to until they give you reason to. But yeah, you need to find out the bearing size/model; see if you can find some markings indicating the hub model and search that way, rather than searching for the wheelset model.
Likes For WhyFi:
#1267
Mostly Harmless
Liked 4,530 Times
Sitting at the Firestone shop getting the summer tires put on the VW. The waiting area TV is tuned to some infomercial channel. Currently, playing one for "Car Shield". They want me to be afraid that my tire swap and alignment could cost me THOUSANDS of dollars.
#1268
Quoted: 9653 Post(s)
Liked 6,365 Times
Likes For Mojo31:
#1269
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Are you running tubeless??
#1271
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
In other spoke news, I finally made a reasonable effort to true the plus bike wheels I built a while ago. I mean, disc breaks, so who cares, right?
Even though the front wheel fits in the truing stand, I already had the masking tape out to do the rear wheel which doesn't fit in the truing stand, so I figured I'd stick with that
#1272
Liked 5,184 Times
Your shell is BBright. Your bottom bracket is whatever they installed to get you to the crank compatibility that you wanted. Did you get it from Excel and are you running Shimano cranks? If so, it's likely a Wheels Manufacturing BBright Out1 or something along those lines.
Not planning on replacing either now, was just thinking ahead. The cervelo has been making a knocking noise when I pedal slow under load for a while now. Hasn’t gotten worse but in the eventuality it does just wanted to be prepared.
Wheels are fine too, just did more reading on them and the bearings seem to be only major complaint. Coming up on almost 2000 miles on them and they are still going strong.
They sell the wheels now with ceramic bearings as an option, I didnt see that when mine were ordered.
#1275
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
I skipped riding this AM, it was supposed to rain- guess what it didn’t do?
weather is supposed to suck tomorrow, so unlikely to ride then either and have a birthday celebration with the family Saturday so my mileage is likely to be low this week.
