What do old people ride, lets see your bikes
#3027
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
#3028
Quoted: 8281 Post(s)
Liked 9,053 Times
Like many Japanese corporations, they are a conglomerate.
"The predecessors of Bridgestone began making diversified products[28] in the 1930s, soon after they started making tires. Today, Bridgestone diversified operations encompass automotive components, industrial products, polyurethane foam products, construction materials, parts and materials for electronic equipment, bicycles and sporting goods. Diversified business generates about one-fourth of total sales in the Bridgestone Group.
Automotive parts are an especially large line of business for Bridgestone in diversified operations. Bridgestone supplies automakers with vibration-isolating components, such as engine mounts. Bridgestone also supplies air springs for trucks, automobiles and train carriages. Bridgestone market aluminium wheels and other automotive accessories, too."
#3029
meh
Quoted: 1111 Post(s)
Liked 1,013 Times
https://www.sheldonbrown.com/japan.html#kabuki
#3030
Liked 9,053 Times
My favorite part about the Bridgestone bikes ... When Japanese bikes were hot in the 70s and 80s, Bridgestone created Kabuki bikes to sound Japanese
#3031
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,836 Times
@macstuff
39/19 gearing with 27” wheels rolling 25mph = you one fast spinner above 140 rpm. How do you keep your feet on those flat pedals at that cadence?
Or maybe check the accuracy of your speedometer.
Exhilaration is a powerful force, beyond all logic.
#3032
My new Domane al5. First road bike since the mid 80's. Very smooth ride and crisp shifting. Love it so far, lol.
Likes For Mtl01:
#3033
Bikes: A Blue One and 2 Green One's, then there's the Yellow one. And oh, yeah, a Black One. Did I mention the Red One?
Quoted: 75 Post(s)
Liked 195 Times
@macstuff
It rolls easily at 25 in 2nd with normal cadence. Getting it up to 30+ gets it spinning pretty fast.
You can see my speedo on the handlebars. its a cheap XOSS but its wireless GPS so I don't think there is much wiggle room there. You can also see the Zefal strapless toe clips. Those help a lot with changing gears and zipping around.
I built it to do 25 easily because that's as fast as I should be going with one arm.
I just meander and clip around on flat terrain here in Tucson
#3034
Liked 9,053 Times
I don't think I ever had a bike that would roll easily @25mph unless it was pointed downhill. Also, if I have to go 30mph I have to work pretty hard.
#3035
Veteran, Pacifist
Liked 4,836 Times
Yes, thought single speed.
See, what do I know?!?
but,
I really wanted to know which alien species could spin 140rpm with platform pedals
but,
#3036
Veteran, Pacifist
Liked 4,836 Times
but again = what do I know?!?
Likes For Wildwood:
Likes For N2deep:
#3038
OM boy
Bikes: a bunch
Quoted: 517 Post(s)
Liked 645 Times
Quote:
@macstuff
still seems a bit of ET cycling...
the S2C mulitples at 138% - so your tall gear for a 39/19 would work out to 78" - which at 25 mph means 112 rpm - and if you adjust for 27 vs 700 about 8 mm - that now gives close to 110 rpm Normal.... ? with flat pedals ?
you're a better man than I, Gungha Din...
reminds me of the guys in ski forum posting their 'speed' on a 'groomer', on 170 cm skis - 77 mph - GPS verified of course... not in aero tuck and with ski jacket and bibs,,,, LOL!
consumer GPS - I'm not convinced...
Ride On
Yuri
@macstuff
Not really, It comes out to roughly 56if and 75if for 1st and 2nd. Maybe you thought it was a single speed?
Ride On
Yuri
#3039
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
I purposely set up my old MTB with touring bars like this to ensure I could work hard without going too fast on our local trails. Just holding 20 mph is easily 250 watts unless I shift forward to a lower body angle.
This air drag is actually something that helps single speed make more sense. Even with a tolerable hill climbing gear of 64 gear inches, by the time I start to feel I’m spinning really fast, I’m also working really hard, even on the flats.
Otto
Likes For ofajen:
Likes For Gravel Rider:
#3041
Quoted: 768 Post(s)
Liked 1,743 Times
here are my main two rides. Trek Emonda ALR 2016
Trek Domane SLR7 2021
Likes For jaxgtr:
#3042
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Keep the chain tight!
Likes For Trsnrtr:
Likes For ColonelSanders:
#3044
Old newbie
Bikes: 2022 Trek Emonda SL 5, 2002 Klein Quantum, 2000 Trek 8000, 2011 Trek 7.5 FX
Quoted: 18 Post(s)
Liked 77 Times
You old guys have some nice bikes. I'll post photos of mine later. I'm told that I need at least 10 posts before I can post photos. I just bought myself a 2022 Trek Emonda SL 5 about a month ago to go along with my 2002 Klein Quantum.
I now have 10 posts.
Likes For classic carl:
#3045
Quoted: 768 Post(s)
Liked 1,743 Times
Hmmm, hard question. I honestly thought about selling the Emonda when I got the Domane, but there are some differences in the 2 that are noticeable outside of frame material and weight, so I hung on to both. I have had a longer time to futz with and get ALR perfectly setup, where I am still tweaking the Domane here and there. The ALR is 54cm and the Domane is 52cm, but the overall geometries were pretty close, everything within a few mm of each other. The 52cm frame on the Domane felt better than the 54cm, but as I started stretching more I was starting to feel a little cramped, so I recently moved the Domane to a 100mm stem and that seemed to help a bunch. The ALR has such an smooth comfortable ride, but I just recently changed my wheels from the older Aeolus 5 non TLR to the Aeolus Pro 5 TLR, which made things even better now that they are tubeless. The ALR is mechanical\Rim, the Domane is Di2\Disc, I freaking love Di2, but the Ultegra mechanical just shifts perfectly and my ALR frame is not setup to run internal Di2 cables and I am not a fan of SRAM, so I will keep the mechanical Ultegra. I live in a very flat part of the world and bombing down a mountain and having to worry about melting a rim brake surface is not a concern, so having or not having disc is not in my top 100 must haves on a bike, but since you really can't get a new bike without it, not much I can do there. The only other thing I might change would be the cranks, the Domane came with 170mm, which I should have changed out to 172.5 when I ordered the bike, but I did not, so I will probably make that change in the near future. The Domane does ride like a dream and really eliminates a boatload of crappy road surface beating, so for super long distances, it is really, really nice to have. I have carbon bar and seat post on my ALR, and the fork on the ALR is the same fork that is on the Emonda SLR, so the ride is unbelievable smooth for an aluminum frame.
However, having said all of that, if I only could keep 1, as it stands today, I would keep the ALR. It's just that damn good. I figure I will find that same level of comfort in my Domane soon, as I am very close.
edit: I also just ordered some Aeolus Pro 51 wheels for the Domane, suppose to be here late Nov. I like the 50mm deep wheels.
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Likes For jaxgtr:
#3046
Quoted: 768 Post(s)
Liked 1,743 Times
I was seriously looking at the Emonda SLR last year, but ended up going to the Domane. Do you have it yet, or is it on order?
Likes For jaxgtr:
#3047
Old newbie
Quoted: 18 Post(s)
Liked 77 Times
I was lucky to get it though. When I originally stopped in early September to see what they had, they told me there was a 58cm ALR comng and a SL 5 in silver in early October. I stopped in one day after a ride a week or so later and there were several boxes of bikes on the floor. There was a 52, 54, 56, and a 58cm SL 5 in blue, which is the color I preferred anyway. I asked if it was sold, the owner said no, and I told him to build it. He thought I didn't want a blue one, and the employee I originally talked to wasn't aware that the blue ones were on their way. The silver one still hasn't arrived as of yesterday.
I see you're from Jacksonville. My wife's brother lives in Orange Park on Fleming Island. I've been there a couple of times, but haven't ridden there.
#3048
Old newbie
Quoted: 18 Post(s)
Liked 77 Times
LOL, I ran into the same "problem" this summer. It started off with me being curious about a mid 90's Klein Quantum II. Picked it up, fell in love with the paint, and then fell in love with the ride. Not all al harsh like I've always heard and really fast!
With the latest saddle swap I got this one under 18 lbs.
#3049
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Regardless of gearing or cadence, pushing an upright bike through the air at 25 mph will be a lot of work. Somewhere in the range of 400 to 500 watts. Does anyone call that easy?
Otto
Otto
Every once in awhile, I get an idea in my head that requires scientific analysis. Thank goodness it doesn't happen too often, because I get enough of that at work. But this question of how to travel most efficiently in an upright riding position demands that I turn my seat-of-the-pants theory into empirical data.
So I found a cycling aerodynamics calculator right here on the interwebs (https://www.exploratorium.edu/cyclin...dynamics1.html) and used Excel to create a chart depicting the effort required to maintain increasing speeds on level ground with no winds. Here's what that looks like:
Cycling Aerodynamics
As I suspected, the effort to maintain speeds greater than the typical 10-15mph range of your average English 3-Speed increases exponentially. For instance, in order to maintain a speed of 20 mph, it takes double the effort needed to cruise at 15 mph. More dramatically, the effort to maintain 14 mph (32.25 Watts) almost triples at 20 mph (94.01 Watts)!
All of which supports my assertion that a 3-speed is better off with lower gearing if the goal is to enjoy cruising along in a dignified manner. I think the only reason they put such small cogs on at the factory in England was to keep the leg pumping to a minimum - spinning up hills must have seemed rather frantic to them, and as such, unseemly. Better to hop off and walk leisurely up that hill, right?
USMC 1981-1991 Semper Fi!
#3050
meh
Liked 1,013 Times
^^^ That's why I always draft a roadie when riding my upright city bike
True stories:
I've received some props from a local B group when I held their wheel while commuting home, I got dropped once the road got hillier and I was heavy with laptop, clothes, and other commuter crap.
I've been yelled at for drafting a roadie on a busy greenway, so I passed and dropped them. (Bluntly stated, on Midtown Greenway in Minneapolis during rush hour, it's damned hard not to end up pacing someone ... so many bikes and few options to safely pass)
Full-on Fred kit with my Globe Daily 2:
True stories:
