So ... what are the latest thoughts on carbon clinchers and rim brakes?
#76
@SkepticalOne
A junkie broke the window in my car and pulled the bike out while I was taking a leak on a long drive. Disappeared with them and the bike.
I loved the wheels. The new ones are waiting for me in a shop in a little mountain town on the other side of the Cascades, I'm leaving this evening to pick them up tomorrow.
#77
Quoted: 129 Post(s)
That's a good speed for 125, but at 15mph you are not getting a lot of advantage from deep rims.
A 55mm rim will be much better at high speeds and give a much larger aero advantage, think 20mph vs 18mph. At least for my Easton ec90 55mm
#78
Quoted: 129 Post(s)
This is why I don't like you---you have too much talent and skill.
I won't do tubular because of the (perceived) difficulty of changing tubulars on the roadside in the rain at night along a dark stretch of road two-thirds of the way through a painfully long ride... which is exactly where I did my last tube swap (well, honestly it wasn't raining ... ) But I dream of a pair of 1300-gram clinchers tough enough to support me.
changing a tubular is pretty quick, as fast as replacing a tube if you know what you are doing. In my experience (6 years riding, 4 mostly on tubular) tubular tires flat less than clinchers, and never pinch flat. Also you can put sealant in them and they become impervious to little thorns etc. that kill a tube.
for alloy, tubular rims are not a whole lot lighter or better than clincher. they used to make 250 gram tubular rims (yes alloy) but now most are around 400g and overbuilt for cx use
for alloy rim brake pads CoolStop has really nice salmon colored pads for wet, and combination pads (black and salmon) for all conditions, and a three compound CX pad for even more conditions
#79
Quoted: 7652 Post(s)
Liked 3,474 Times
Personally I found that finally I have hit the sweet spot ... I know enough to know what I don't know.
Seriously, I was on what was, for me, a long ride on a Sunday night last month and got two punctures in a couple miles. It was an unlit stretch of road (which I like) and I had lights on the bike, so if I needed to add a glueless patch for a third flat I could have.
I hear about how much better tubulars ride, and I hear it from people whom I believe to be honest and experienced ... but I like to plan for worst-case scenarios, having found myself in so many .... Maybe when I get older and crazier I will try tubulars and regret all the wasted years ....
#80
Quoted: 18883 Post(s)
Liked 10,646 Times
Got 'em this weekend. Forgot how magical these things are.
@Maelochs, I don't know how many bikes and wheels you have, but new toys are always fun, and they call you out to the road. Go for it man.
#81
Bikes: Basso Luguna, Fuji Nevada
Quoted: 4261 Post(s)
I use BBB carbon fiber wheel brake pads in 6800 calipers on eBay 50MM x 23MM rims. I've never had an issue with stopping power, even when riding in the rain.
#82
Quoted: 1814 Post(s)
Liked 923 Times
I wouldn't know, as I haven't had 20mph moving average in decades.
Did have a quite fast time on a flattish DC last year (on same wheels as you), but can't separate the wheels from
drafting, etc. etc.. Since it's pretty much a guess anyway, I don't want to overstate.
The most objective measure I have is that a regular riding partner who outweighs me by 40 lbs would always
coast past on descents, but while using those wheels, he never did.
#83
Liked 3,474 Times
#85
Liked 3,474 Times
Do pretty much anything you want, I am cool with it ... but Don't Make Me Think.
I am an American, after all.
#86
Liked 10,646 Times
I realized I should maybe mention this, especially with braking traditionally being the Achilles heel of carbon rims.
I got mine this weekend. First ride was up and down Sun Mountain. Got to the top just after sunset, came down at full speed in the dark, it was a deery night, I didn't give it a second thought.
Phenomenal stopping power and control. But they're disc brake wheels, so I knew that, I knew exactly what to expect, and didn't have a worry in my mind. They work brilliantly in the desert sun, they work fantastically in the Seattle rain, I don't ever have to worry about knocking my teeth out all over the road. Which was the stated intent behind this entire thread.
If I'd had more time, the first ride would have been Washington Pass - a longer, steeper, faster descent. But road tubeless is a bear to set up and they were ready an hour before sundown.
Anyway, I don't think anybody would buy a set of Chinese carbon rim-brake wheels and take them up and down a mountain for the first ride. I sure wouldn't.
Words to the wise.
Words to the wise.
#87
Quoted: 6556 Post(s)
Liked 58 Times
Words to the wise.
Words to the wise.
Actually you make a very good point. There are lots of arguments about carbon clinchers, Chinese and otherwise, but when you cast that light on it, the choices do get a bit clearer. And this from a guy who totally believes in the product.
#88
Liked 923 Times
Words to the wise.
Words to the wise.
Glad that you like your wheels, but your post has several problems IMO.
- Repeating tired CF stereotypes.
- Riding full speed down a mountain in the dark without a second thought.
- Riding full speed down a mountain in the dark on the first ride of untested wheels & tires.
- You have experience riding in the desert?
- Apparently believing that disc brakes guarantee against crashing.
- Generalizing about what anybody would do.
#89
Liked 3,474 Times
Well ... sorry about all y'all's problems ... I''ve solved mine.
I am getting a set of nice, light hand-built alloy rim-brake wheels, and eventually a set of deep CF discs ... for the next bike I build.
Wife wants a new car so ... Leverage!
#90
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4390 Post(s)
Liked 3,016 Times
(yeah, I know this is a zombie thread)
I'm headed to Las Vegas to ride over the MLK weekend, and unexpectedly I can't take the disc brake bike with me. So I'm taking the rim brake bike. Normally, that one has carbon (Lightbicycle) clinchers, but there are some long long descents on my planned routes - 3000-4000 feet continuous at 5% or so - and having done them before, I know I'll be riding the brakes for a long time. (You guys with skills who would bomb down these at 50+ mph - bully for you, but there's too much debris on these roads for me to be comfortable with that).
So I'm going to swap out the nice carbon rims for some old wheels with alloy brake tracks. Maybe it's not completely necessary, but it will give me a little less to worry about.
Call me weird, but brakes and wheels aside, I'm going to enjoy the ascents and hate the descents.
#91
beeballman
I am considering building a lightweight endurance-geometry frame which would be more comfortable (more relaxed riding position, wider tires) for longer rides than my Workswell 066.
The question I am facing is rim brakes and deepish carbon clinchers with potentially questionable braking ability and the potential of wearing out the (rather more expensive) rim or disc brakes, in which case I could offset the weight lost with CF wheels with discs and heavier calipers. (I always seek to avoid unnecessary weight loss.)
With CF rims I can get lighter wheels for the same money--but light wheels which don't stop or don't last .... not such a bargain.
So ... does anyone here ride CF rims with caliper brakes, and how bad is it/are they?
#92
Quoted: 3952 Post(s)
Liked 7,297 Times
Likes For tomato coupe:
#93
Liked 3,016 Times
The question then lingers - why did I choose this particular zombie thread to revive with my post?
B/c it was the first one I encountered in a search that about fit the bill, where people discussed braking on long descents.
I apologize to all those other zombie threads that weren't picked for resurrection. Their time will come.
Likes For MinnMan:
#95
Don't ride the brakes, both on hard at the same time, cool down and repeat. You will be fine.
Likes For popeye:
#96
Quoted: 3241 Post(s)
Liked 2,512 Times
#97
Quoted: 2333 Post(s)
Liked 2,097 Times
Delaminated carbon is also a zombie issue unless one is braking on old, lousy epoxy rims.
#99
beeballman
I purchased Roval CL50 Rim Brake Carbon wheels about 18 months ago, I have had no noticeable difference in braking. You need to make sure you use pads meant for carbon rims, but I have noticed zero difference in braking. Now , I also do not ride in wet weather either.
#100
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
I expect the existing technology to be around for many years, but don't think we will see any improvements on what we have.
Comments?
