SHimano bar end shifter boots
Slow Moving Vehicle
Bikes: Felt F-70, Terry Madeleine, Novara Safari fully customized by me
Are you talking about bar end shifters that fit into the ends of drop bars? My bar end shifters have 2 plastic parts: the lever boss cover & and the outer cable guide. There is nothing like a drop bar boot on mine so I'm unclear what part you are talking about, can you post a picture?
Help grow the future of cycling in the world. Volunteer at your local "earn-a-bike" program. In the Boston area https://www.bikesnotbombs.org/about
Liked 1,099 Times
I believe the OP is describing the little plastic sleeves that cover the end of the shift levers. You're right, they have no "boots" like brifters.
I'd contact Shimano America to see if they are available as a replacement part. Otherwise, just wrap the levers with tape.
Bikes: n, I would like n+1
Liked 133 Times
https://aebike.com/page.cfm?PageID=30...ils&sku=LD0501
Shimano bar end shift lever segment unit is the closest thing I can find. The link shown has a high % markup from the QBP price so it may well be cheaper through a shop. Shops can get that from QBP, part #LD0501. That sounds like it may be the indexing plate, you would have to ask, but it's the only small part that I can find which relates.
Death fork? Naaaah!!
I replaced mine with a pair off an old Sun Tour stem shifter trimmed to fit.
Dip the levers in boiling water and they'll slide right off.
Trim to fit, dip 'em back in the water to soften them up, and slide them onto your Shimano barcons.
Top
Top
Bikes: 1990 Burley Bossa Nova, 1992 Paramount PDG-70, 1993 Specialized Stumpjumper, 2005 Jamis Dakar XC Pro, 2007 Rivendell Bleriot
Liked 5 Times
One of mine just fell off yesterday. It actually looks fine without, but you lose a couple mm's of leverage I guess.
Maybe I'll try wrapping it in twine and shellacing it
