Bike shorts and hygiene
Hi!
I am planning a 5 day bike tour, starting from my doorstep and wild camping on the way. I am using cycling shorts with padding, but only have one pair. Since they are quite expensive where I live (90 Euros in Germany), I hesitate buying another pair. I know that wearing underwear under the shorts is a big no-no in the cycling community, but I have even considered that to increase the level of hygiene on the trip.
Do you take multiple cycling shorts on multi-day bike tours? How do you care for hygiene down there?
Thanks!
Thanks!
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 336 Post(s)
Liked 782 Times
I was not aware that wearing underwear was an issue?? I’ve never cycled without them and cannot think why it would a problem??
much cheaper than extra cycling shorts……
Likes For Tomm Willians:
Quoted: 6196 Post(s)
Liked 4,811 Times
I'd buy several pair. Maybe start a go fund me page if you have to. Otherwise just rinse them in fresh clean water at the end of every day. If you have a little oxyclean, or other sanitizer, then add it, but rinse twice with the last being just water. Let dry in the best breeze you can, but if they aren't completely dry the next start time, why care, they'll be sweaty soon anyway.
Underwear will just increase your chance of getting sores from wrinkles and abrasion. Underwear won't make anything any better. It's the microbes, fungus and stuff that will grow in the moist fabric that will bother your skin. They need to be removed daily so their population is kept to a minimum.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
It's been universally accepted...forever...that you don't wear anything under cycling shorts with a chamois. Never.
Likes For cxwrench:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Not sure what your accommodations on the tour will be, but, if you turn your shorts inside out and leave them out in the sun, the UV rays will kill off bacteria. You can also bring a small bottle of Woolite and rinse them out in a sink between uses. Personally, I'd take two pairs; one to ride in while the other is sunbathing or drying out.
Likes For Rolla:
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
Buy more riding shorts. If you can't afford them you shouldn't be touring the countryside. Easy for me to say I suppose. At least carry some soap and wash the shorts everyday. Even if they don't fully dry at least the bacteria will be neutralized.
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
Wear underwear and only wear cycling shorts when cycling. Make a point to keep them clean as you can.
Thanks to all your answers. Okay, I'll bite the bullet and buy another pair of cycling shorts. That way one pair can be washed in the evening and the second pair worn during the day while the first pair dries.
Which brings another question: given how slow the padding dries, how do you dry it? Ideally I would like to hang it up somewhere on the bike where the wind would act like a dryer, providing it doesn't rain of course. Do you have any experience with that?
Likes For cyclopath256:
Get a shock cord and attach the pants to the rack. I put them on my back rack. Time and sun dries them, typically before the end of the day. In fact, I dry most of my clothes that way while on tour.
BTW. if it is less expensive, just purchase a chamois and wear it with shorts you may already own. Or buy a less expensive short, such as nylon athletic shorts. I am not aware of any advantages of wearing skin tight shorts on a tour where the goal is site seeing and not speed.
Likes For debade:
Likes For iReadBlitz:
Quoted: 4416 Post(s)
Liked 4,872 Times
If you buy more shorts, get a pair with a removable liner/chamois. So then you can use the same outer shell with several pairs of liners. A lot of shorts now come as a shell without a liner, which you then buy separately. So you could buy one shell and 2 or 3 liners to rotate.
Quoted: 18424 Post(s)
Liked 15,580 Times
If they don’t dry over night you can strap them to your rear rack if you have them. Wind and sun will dry them pretty quickly.
And wearing unwashed shorts won’t mean the end of the world for you.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Underwear under padded cycling shorts is not a big no no. I wear seamless, form fitting and breathable underwear under my cycling shorts all the time. Underwear isn't going to do anything to help the OP's sweat, bacteria and taint odors but other advice has been offered for that. I'm only chiming in because the Internet has propagated a slew of rules not just for cycling that people hold as a universal truth.
Likes For Chuck M:
Liked 4,872 Times
Likes For PeteHski:
Quoted: 2333 Post(s)
Liked 2,097 Times
I've ridden in a pair of bibs for 5 straight days. Probably not the best idea but I was ok with it. The jersey smelt much worse.
I don't really need padding and sometimes nowadays, I use black "crew" rowing shorts. They are tight and black but no pad. I think I paid $10 for two pair online.
Dead but dreaming
Location: Bay Area, CA (East Bay - Contra Costa County)
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 171 Post(s)
Liked 326 Times
I got the advice well before the Internet was around not to wear anything under my cycling shorts. I can't imagine needing (or wanting) to have anything, regardless of how form fitting it is, underneath my cycling shorts.
I'm not going to make fun of anyone else for doing so (well, maybe privately).
Likes For KJ43:
Quoted: 1109 Post(s)
Liked 1,200 Times
I believe cycling shorts are actually designed to be worn without any material (i.e. undies) between the skin and the pad. The material that makes the pad is better for sweaty skin contact than underwear, plus the absence of wrinkles or chafing from underwear material. That's been my experience anyway having started with special "cycling" underwear at first and then no underwear for the last 20 years or so.
Anyway, another reason not to wear underwear is if you use chamois cream. I've recently started using it more than in the past and it help with potential sores.
I have baggies with a removable "liner" too. But that liner is pretty much a scant bicycle short, not much different than my old non-bib shorts. I can't see how that would reduce the issue in the OP- still requires the same maintenance / cleaning as any bike shorts. Just buy another pair of bike shorts and wear them under baggies - and that's any baggy shorts, not "bike" shorts - if you like wearing baggies.
Quoted: 144 Post(s)
Liked 119 Times
Apart from everything else that's wrong with underpants on a bike, after washing them they take longer to dry than bike shorts. On short tours I take two pairs of bike shorts and a pair of undies for off the bike.
Liked 4,811 Times
If you want to wear a underwear then use the sports type underwear that is made from synthetic material. They look pretty much like cycling shorts anyhow. So you'll be fine just wearing them and nothing else.
But if you need cycling shorts for the chamois, then don't use anything else between the cycling shorts and your skin.
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
I don't know why someone would wear undies with cycling shorts unless they had some medical or digestive issue. On tours I prefer to go commando after the ride, let the parts air out. Bring a pair of boxers for sleep wear. Also, in the past I've used the heated hand dryers/blowers in restrooms to dry stuff. I read recently that they can harbor germs so that may not be a good idea.
Likes For kahn:
Liked 15,580 Times
So true.
Many years ago I rode 6 days without a shower and only rinsed my riding kits a couple of times and then only in cold spigot water. Three of those days were pretty warm and humid. Checked into a motel after the sixth day. The woman working the desk looked at me like I was a Sasquatch. When I emerged from my room after cleaning up, the young girl sweeping up the parking lot said “You look like a totally different person.”
