Phatcycle Project Bike
Bikes: There is always room for one more.
Quoted: 184 Post(s)
Liked 391 Times
Picked up a Phatcycle cruiser type bike today off FB Marketplace for $20. It is a basket case. It is a PROJECT:
/From the FB ad.
While I'm tearing it down tonight, I'll be thinking about the options before me with this bike. It's a fairly light aluminum frame and I think it might make an interesting rat rod bike.
Looks like someone already started to remove the paint from the frame. I'm toying with stripping all the paint from the frame and leaving it bare. Have any of you guys and gals done this with an aluminum frame? If I do this, should the frame be protected with a clear coat or something else?
Thanks for any ideas or suggestions!
/From the FB ad.
Don
Don
Likes For GeezyRider:
Quoted: 184 Post(s)
Liked 391 Times
Frame stripped
It took two days but I got pretty much all the paint off the frame:
The only salvageable Phat Cycles decals are on the fork so I will keep the fork original with just some cleaning and polishing.
Don
Don
Quoted: 184 Post(s)
Liked 391 Times
Phat Cycles cruiser frame details
It's a rainy Saturday and I'm experimenting with possibly adding gearing to my aluminum Phat Cycles single speed cruiser. I put a six speed freewheel on an extra 20 inch rim and mounted it along with a derailleur and shifter onto the frame. The single speed wheel that came with the bike (I believe it is original) had a hub spacing of 130mm and the 20 inch test wheel I am using is spaced at 135mm. I was relieved that the 135mm wheel went into the dropouts rather easily. And, the cheap Tourney derailleur and indexed thumb shifter moved the chain up and down the freewheel crisply and easily.
But what is really interesting is the Phat Cycles frame. As you can see in this picture, this single speed cruiser frame has a derailleur hanger and mounting options for coaster, linear pull or disc brakes. Not pictured are the cable guides for a front derailleur as well. It's like this frame is the Swiss Army Knife of cruiser frames.
Look at all those options for brakes!
I think this bike is going to be so much fun to ride, tinker and experiment with!
Don
Don
Quoted: 184 Post(s)
Liked 391 Times
Phatty is shaping up
The bike is close to being ready to ride. I had to order a seat post because this one is past the minimum insertion point. Also, none of the handlebars I have on hand are quite what I want. So I won't be cutting cables or cable housings until I find the right handlebars.
Don
Don
Rhapsodic Laviathan
That is weird. You should put all three brakes on it. I'd keep the fork, just because it has linear pull mounts, and is a spaded fork- something I wish I could find for my Cranbrook.
Likes For Jax Rhapsody:
