Questions on a Scapin KS-25
Hi all! I'm a moderate-time lurker and first time poster who's dipping a toe into the world of vintage bikes. I've been eyeing a Scapin KS-25 frameset on Craigslist and am wondering how hard it would be for a first-time project. I've got several questions:
- Is $300 a fair price for a bare frame/fork? Condition looks excellent but there are no decals and no hardware. I'm assuming figuring out the stem and getting a seat post might be an adventure.
- Would it be possible to put a more modern groupset on the frame? I looked at Campy Chorus C prices and have decided that a full restoration is not really in the cards at the moment (but maybe in the future!). What I do have is a Campy Centaur groupset I could pull off an early 2000's Univega
- If possible, would it be sacrilegious to put that groupset on? Will I be struck down by the vengeful Vintage Bicycle Deity?
Likes For NestorNotabilis:
Mother Nature's Son
Quoted: 855 Post(s)
Liked 1,448 Times
First of all, make sure it is a Scapin KS-25? Putting a "more modern group set" on vintage bikes is done by a lot of cyclists. It is only wrong if you think it is wrong. I have no comment on value, and no comment on being struck down by some imaginary deity.
Bianchi Goddess
Quoted: 2949 Post(s)
Liked 2,970 Times
NestorNotabilis Is the frame like this one from 1986? I would not put a modern group on this because the "Escrago" or Aero type shifter mounting with internal cables. You's have to use a clamp of sometype for the cable housing stops and that will get ugly. Plus you need to find a nice seatpost in 25MM, most better quality bikes of the era used a 27.2 or 27.0 post.
Pics sourced from this site. That's a beautiful bike. BTW even setting up Index DT shifters on this might be tricky. https://www.veloversum.com/scapin-ks-25
Edit: I'm not sure I've ever heard of this KS-25 tubing before and while it looks like maybe carbon or aluminum it is steel with special internal lugs, similar to a Vitus or other clued AL frames, then they are silver soddered. Interesting
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
It has the Scapin on the seat stay, the sloping top tube, and the eyelets for the internal cables, so I think it's pretty likely! Not that I've been particularly successful about finding information.
I'm very jealous of whomever ended up with that one - it is gorgeous.
Can you elaborate on why an indexed shifter might not work with the internal routing? How did they originally get the cable housing to work?
Edumacator
Quoted: 2502 Post(s)
Liked 3,259 Times
Also indexed shifters are precise one cable throw, and the cable angles might be problematic?
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Bianchi Goddess
Liked 2,970 Times
jdawginsc is correct the cable routing tends to bind too much for indexing. You could never go spect to put a regular housing stop on that and insert in the hole and if you use a clamp to mount them, there is no routing under the bottom bracket shell for the cables.
Same with index downtube shifters. I had a customer insist I cut one of those escargot type shifter mounts off on his Battaglin time trial bike and I still tear up today thinking about it.
where is this frame? Do you a link to the sale posting?
Unfortunately, I can't post links or photos yet, but it's on Seattle Craigslist - a search for Scapin turns it up. A couple pictures in there's a close-up of the downtube.
Bianchi Goddess
Liked 2,970 Times
NestorNotabilis This frame looks li it has regular shifter bosses with cable stops bolted on already. So perhaps the Brifters will work. However it is missing a water bottle boss. Can’t tell if this chromed or just stripped of paint. https://seattle.craigslist.org/see/b...710918625.html
Groupetto Dragon-Ass
Quoted: 415 Post(s)
Liked 790 Times
Interesting lug work. Sent me off searching and found this: https://www.veloversum.com/scapin-ks-25
Quoted: 3576 Post(s)
Liked 2,997 Times
Likes For smd4:
Bikes: Emonda, 79/80 Colnago Super, early 80s Eddy Merckx, end 70/beginning 80s Somec Super Corsa, Santa Cruz Bronson
Quoted: 46 Post(s)
Liked 63 Times
Very nice looking frame.
Since the KS-25 frame building method involves tubes being pushed over the lugs and soldered with silver solder, similar to glued Vitus frames, which are sometimes reported to have issues with bonding loosening, I’m wondering if the same applies to the KS-25 frames. Does anyone have information on this?
Likes For Campagnerdo:
Quoted: 36 Post(s)
Liked 53 Times
I understand these frames are Columbus tubed. The 25.0 seat post won't be too difficult to find, nor the stem. These were commonly chromovelato finished, colored lacquer over chrome. I believe this one on Craigslist has been stripped of its lacquer. The water bottle rivnut can be replaced. Being a steel frame, I don't think there is any concern over debonding, these aren't bonded with a glue or epoxy. It's a handsome frame that one does not encounter often.
Hey!
Not sure if you ended up buying the frame.
I own a Scapin KS-25. Its a size 56, which is a little big for me but I make do with a short stem and short seatpost height
Its actually quite light and rides like a dream! In the 8 years I have owned it, I built it up with Full vintage Campy parts for Eroica, Ultegra Di2 for some time and now it has Dura Ace 7700 + carbon wheels. It works great with all 3 builds.
Its so versatile and well worth the $300 IMHO
Cheers!
Cheers!
Likes For ashwath22:
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 679 Post(s)
Liked 1,002 Times
Very nice frame and well worth it
