Bike computer, broken mounting tabs
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
Hi
Probably this is a rhetoric question. Is there any way to repair broken mounting tabs on a bike computer? I broke the tab at the bottom, and it will not hold securely in the mount. There is an ugly fix like in the second picture (scotch tape and/or rubber bands).
I see that there are many such questions for Garmin, and there exist some aftermarket bottom covers with replacement tabs. This is not the case for my computer (Sigma BC 23.16) because it is much less common.
Broken tab
Broken tab
Quoted: 523 Post(s)
Liked 229 Times
You can secure it using a small amount of RTV silicone sealer between the computer and the mount AFTER putting in a brand new battery. If you do not get carried away with the amount you apply, you will be able to separate the mount from the computer when you need to replace the battery but it will not fall out on its own. Don't apply it to the contacts.
Likes For VegasTriker:
Quoted: 821 Post(s)
Liked 1,655 Times
You can get Garmin 1/4 turn mount "phone case adapters" that use peel and stick tape. They should be able to adhere to the back of your Sigma, and use a Garmin mount.
Likes For Bald Paul:
Quoted: 217 Post(s)
Liked 155 Times
This can also be done if the rear part of the mounting bracket is removed.
