Go Back  Bike Forums > Bike Forums > Fatbikes
Mid-ride flat inflation
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Old 02-17-22, 11:19 AM
_ForceD_
Sr Member on Sr bikes
_ForceD_'s Avatar
Bikes: Several...from old junk to new all-carbon.
Quoted: 1019 Post(s)
Liked 785 Times in 414 Posts
I’ve never ridden a fat bike…strictly a road cyclist…but just wondering how you all go about inflating flats mid-ride. I was on paved MUP yesterday and came upon a fat bike/rider who was pumping away with the smallest of hand pumps. I slowed as I approached him, and was going to offer the use of the 16g CO₂ cartridge I carry with me. But then figured that it wouldn’t touch the inflation of that completely flat tire. He’s probably still out there pumping. But I’m just curious…how many cartridges does it take to properly inflate those tires? Is there a hand pump that is efficient for them? I felt bad there was nothing I could do to assist him. I always offer assistance when I pass a stopped cyclist.
Dan
_ForceD_ is offline
Old 02-17-22, 12:35 PM
Nvreloader
Bikes: 2021 Wart Hog 750MD
Quoted: 10 Post(s)
Liked 4 Times in 2 Posts
I use/carry Co2 cylinders for my fat tire bike, I use about 2-1/2 12 grm cylinders to fill the Wart Hog tires to just less than 30 lbs. I use a lot of 12 grm cylinder for my air rifles, my co2 inflator uses 16 grm cylinder threaded type, I just put 5 or 6 Nickels inside the carry handle and can use the 12 grm cylinders also, plus I don't waste any gas etc.
It is this model: https://www.thebikesmiths.com/produc...vations-g20310
Also use the same item for my ATV along with mushroom plugs, which work perfectly.
HtH,
Don
Nvreloader is offline
Old 02-17-22, 10:29 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2762 Post(s)
Liked 2,537 Times in 1,433 Posts
Some pumps made for mtb are high volume, low pressure. That make things go faster.
Kapusta is offline
Old 02-17-22, 11:13 PM
MarcusT
MarcusT's Avatar
Quoted: 766 Post(s)
Liked 617 Times in 344 Posts
Fat tires only need about 4-15 psi, so a cartridge will suffice. But, He could have been just adjusting his pressure. I will lower pressure for technical trails and pump back up when I get on the smoother paths.
MarcusT is offline
Likes For MarcusT:
Old 02-18-22, 10:27 AM
_ForceD_
_ForceD_'s Avatar
This was in the Ft. Lauderdale area. I don’t think there are technical off-road trails in this “megaopolis.” But the bike was pretty loaded down with panniers and such…like he was touring. The tire was completely flat when I saw him. I know the psi for those bigger tires is much lower…but the volume of air required is much more. It just didn’t seem like one 16g CO₂ cartridge would do much for it.
Dan
_ForceD_ is offline
Old 02-21-22, 10:03 AM
Hypno Toad
meh
Hypno Toad's Avatar
Quoted: 1111 Post(s)
Liked 1,013 Times in 519 Posts
Dan
I thought everybody on a fatbike looked like this
https://www.singletracks.com/mtb-gea...r-co2-carrier/
Joking aside ... I have a Lenze frame pump on my fatbike and honestly, it's faster/easier to air up a fat bike tire than a road tire. Repeating other posts, the difference is pressure versus volume, getting a road tire up to 80 to 100 psi is takes more work than getting a fat tire up to 12 psi. Also a repeat ... I ride to/from winter single-track trails, I dump my tires down to 6-8 psi on the trails and use my frame pump to get them back up to 10-12 psi to ride home, it only takes a minute and makes the ride home much easier/quicker.
Hypno Toad is offline
Likes For Hypno Toad:
Old 06-03-22, 05:48 PM
trace
Quoted: 33 Post(s)
Topeak Mountain Morph, a high volume mini pump, works well.
trace is offline
Old 06-04-22, 08:00 AM
Ghazmh
Ghazmh's Avatar
Quoted: 696 Post(s)
Liked 910 Times in 487 Posts
They do make large CO2 cartridges for fat bike tires.
https://www.biketiresdirect.com/prod...d-co2-inflator
Ghazmh is offline
Old 06-04-22, 03:02 PM
Bearhawker
Bikes: '23 Devinci Hatchet Carbon Apex1 '19 Norco Bigfoot 6.1 ,'12 Motobecane Turino (killed by dog crash), '12 Trek 3700 Disc
Quoted: 149 Post(s)
Liked 128 Times in 74 Posts
I use mine as a daily-driver and run 30 psi all the time I intend to ride on the road. Ionly ever run very low pressures when on snow.
I'd run more than 30 but the tires I am running claim that to be the max.
2000 road km on mine so far...
*no way* I could ride the way I do with less than 30 psi
Bearhawker is offline
Old 06-04-22, 08:05 PM
Airfehr
Quoted: 43 Post(s)
Liked 108 Times in 48 Posts
My wheels have a 25 psi max rating. 30 must be rock hard.
I have a Crank Bros. Gem pump. Can't say I'm happy with it. Have not had an issue yet picking up cactus quills running tubeless. Need to find a better pump before my luck runs out.
Airfehr is offline
Old 06-05-22, 06:36 AM
Bearhawker
Quoted: 149 Post(s)
There is still lots of squish at 30 - WAY more comfortable ride than my road bike for sure.
Thankfully I've never had to hand-pump them at the side of the road!
Weighed the bike last night for another post here and without water bottle it is 43 pounds as I ride it - before bags and groceries. lol
Craziest ride was one winter when I rode down a clay road that doesn't get plowed in the winter. I was running around 5-6 PSI in my Jumbo Jims (I run el-cheapo 4" Kenda tires in the summer on the road) and I got stuck in the snow. Completely aired-down the tires to where no more would come out and made it the rest of the way - the limiting factor was dragging the pedals through the snow as I crested snow drifts.
The only real downside was pushing teh bike home the last km or two as there was no way I was going to ride on the road with zero air... and didn't bring a pump.
At least I didn't have t carry the bike home through snow I couldn't really walk through. I now carry snowshoes on the rear rack on winter adventures
LOL
