Front disk hub axle direction
Quoted: 126 Post(s)
Liked 11 Times
I disassembled the front hub, to clean cones and bearings. Of course I forgot to remember the direction of the axle when I pulled it out. Now I am not sure is there a direction? Cones and screw nuts are the same on both sides, no marking I can see on the outside to identify direction. But there is a groove on the outer ring on both sides which seems like it has a direction? Hub is some Joytech from the Cube Nuroad 2021 bike.
some pictures : https://imgur.com/a/5E8qp9T
Half way there
Quoted: 990 Post(s)
Liked 884 Times
Assuming you're talking about the hub spindle and not the through axle: You're good to go.
Half way there
Quoted: 990 Post(s)
Liked 884 Times
I didn't invent, nor do I support ambiguity in part names. It's something we all have to keep in mind when we post questions here.
Likes For Moe Zhoost:
Quoted: 18409 Post(s)
Liked 4,532 Times
What is that loop of stuff that is sticking out from the non-brake side? Also on the brake side. Part of the seal? I'd try to fix it if possible.
Likes For CliffordK:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
The thru-axle goes into the brake rotor side of the hub and screws into the drive side fork leg.
Before you do that, check your work. Looks like there's a seal peeking out from under the endcap/locknut assembly:
Quoted: 645 Post(s)
Liked 797 Times
The pictures clearly show a hub for a through-axle, These hubs have a hollow outer tube that I called a spindle, for want of a better term (Shimano apparently calls it an axle pipe). This is indeed an axle; however these hubs use something called a through-axle in place of a QR skewer to lock the hub to the fork. The OP's question was about the direction of the axle. If he/she were asking about a through-axle then the direction would be important.
Likes For Litespud:
Quoted: 126 Post(s)
Liked 11 Times
1. Sorry if I was not clear, I am not asking about the actual axle which holds the wheel into the fork, obviously it has only one direction and the fork dictates that. I am asking about the direction of the tube (whatever its called) in the hub itself which holds the cones, as you disassemble the hub, you can pull it out both sides. So not sure if this has a direction.
2. I am aware of the seal rubber, its tiny, already stretched out and does not sit tightly in the incut its suppose to be, and as I screw cone nuts back, the grease just keep pushing this rubber out.
Quoted: 166 Post(s)
Liked 252 Times
Mad bike riding scientist
Quoted: 6239 Post(s)
Liked 4,248 Times
One way to avoid this kind of problem is to pick a side that you always work on. Since the rear is usually worked on on the left side (Coaster brakes are different), work on that side on both the front and rear. That way you avoid any confusion.
Stuart Black
Stuart Black
Quoted: 645 Post(s)
Liked 797 Times
What you refer to as the "actual axle which holds the wheel into the fork" isn't an axle - it's either a quick-release skewer, which can be installed either way but usually with the lever on the left, or a "thru-axle", which can only be installed in one direction as it screws into the fork end on one side. Both are clamping devices, neither are axles, despite the name.
Liked 4,248 Times
Try your local hardware store. Smaller ones might be better than a Big Box. At least they will be more helpful and knowledgeable. If you know the size…ask the shop or the hub manufacturer…you can order one from several suppliers on-line, although you will probably have to order them in anything up to 100 lots.
Stuart Black
Stuart Black
Half way there
Quoted: 990 Post(s)
Liked 884 Times
