Help with a headset
Bikes: '92 MX Leader, 84 Colnago Mexico, 85 Recherche, 86 Panasonic ATB Pro, 88 Roberts, 80 moser... ect
Quoted: 68 Post(s)
Liked 134 Times
Help with a headset
Wondering if anyone knows who made this headset? Steel, probably english thread... time wise, if its the same age as the frame, late 70's early 80's. I tried looking through velobase, but didn't see a match.
Likes For uncleivan:
Edumacator
Quoted: 2441 Post(s)
Liked 3,136 Times
Interesting upper cup...
Quoted: 3814 Post(s)
Liked 3,345 Times
maybe it is the lighting but the finish and the upper and lower stacks appears different
one thing which can sometimes happen is that you can pick up a bicycle where someone has made up a headset from miscellaneous loose parts
do not wish to assert that the case here, mention only as a possibility to be aware of...
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Quoted: 310 Post(s)
Liked 679 Times
The upper sorta looks like one of those Stronglight needle bearing doo-hickies from the 80s with a few extra nuts/spacers to accommodate an over-length fork.
Not that I've ever created a headset out of bin parts. Not me.
Quoted: 1612 Post(s)
Liked 2,594 Times
Close, not as tall.
https://velobase.com/ViewComponent.a...111&AbsPos=114
Quoted: 68 Post(s)
Liked 134 Times
I appreciate the help. I don't think it's cobbled together. I am building the bike with campy record/super, but I kind of like how the headset looks. I may end up leaving it. Would still like to know. It was on the frame when I bought it.
Edumacator
Liked 3,136 Times
TDC product? Is it a British frame?
Quoted: 68 Post(s)
Liked 134 Times
Yes, the frameset is british. It is a Willi Moore, built by Mike Mullet.
Quoted: 68 Post(s)
Liked 134 Times
Regarding the 'TDC product' I have no idea. As much as I think I know, i have a lot to learn.
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
I can see the resemblance to the Stronglight Delta version of their needle-bearing HS, but this ain't one of them. And appears to be chrome-plated steel (not alloy) so...stumped me!
It does have similar "coining" on the rim to the Milremo example, but that's not a match...maybe someone like Hillary Stone will know.
Liked 3,345 Times
one simple check which could be made would be to see if there be any marking on the underside of the locknut - this is an occasional occurrance...
Quoted: 68 Post(s)
Liked 134 Times
Ok, I took the headset apart. There are no markings. The bearings are normal, not needle bearings. The topnut is machined to look like two pieces but is one single piece. I'm going to regrease everything and reassemble it, but all looked good. I've decided to leave it on the frame as it came to me that way.
