Where do I find this road shifter spare part?
Quoted: 5 Post(s)
I'm talking about the whole plastic/metal/glass portion on top of each shifter. What are they even called? The metal frame is put into place and secured by two screws under the very tip of the rubber hood. The red gear indicator and insides are now exposed to the elements.
They are available as a small part from Shimano. Typically, online stores do not stock such parts, so find a shop you trust to look up the part in question, and see if it is (still) available for purchase.
Quoted: 18376 Post(s)
Liked 4,512 Times
Is that the Tiagra ST-4500?
The part is called Face Plate or Name Plate.
https://si.shimano.com/php/download.p...4500-2609A.pdf
Part Numbers:
Y-6LP 98030 Right H. Name Plate & Fixing Screw
Y-6LP 98040 Left H. Name Plate & Fixing Screw
Shimano ST-4500 name plate bolt set right Y6LP98030
Shimano ST-4500 name plate bolt set left Y6LP98040
Your Local Bike Shop should also be able to order the parts.
One issue is that Shimano has discontinued support for the face plates of the older shifters, so many of the older Ultegra shifters are impossible to get the faceplates for.
Part Numbers:
Quoted: 5 Post(s)
Thanks alot. That's really helpful. Not sure about model in picture I posted. They look completely identical to shifters on my bike, although mine say shimano tiagra double. I don't think that will make much difference.
Liked 4,512 Times
How many gears do you have? 9 speed?
I think you can roll up the hoods and find the ID of most Shimano shifters near the base of the shifter body.
I would presume 2x and 3x levers would use similar faceplates. But each model is different.
Bikes: 1992 Dave Yates Diabolo MTB, Steel winter roadie upgraded to full 11 speed 105 and Hunt wheels. 2016 Giant Defy Advanced two with Hunt wheels.
Do a search on those part numbers, there's a bike shop in Germany that's brilliant for obscure parts like that but I can't think of the name off the top of my head. I'm in the UK and used them recently, they post anywhere.
Quoted: 9 Post(s)
Here's some name plates, but for 4600. Don't know if it fits your needs or not. https://www.universalcycles.com/shop...3&category=771
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Jenson USA has a good selection of small parts.
Shimano Tiagra ST-4600 Name Plate > Components > Drivetrain > Shifter Parts | Jenson USA
Quoted: 14 Post(s)
Looking for the same parts for my Tiagra shifters but no luck yet. I am digging this "old" thread in case anyone has found a way to get a hold of this spare part ?
Bikes: Peugeot Mont Blanc . Bianchi 28c 1980. Coppi Giro di Lombardia. Vitoria Vintage 1990. Orbea Luarca 1977. Trek 950.
Quoted: 51 Post(s)
Liked 12 Times
Quoted: 14 Post(s)
https://www.sjscycles.co.uk/gear-spa...hand-6um-9803/.
I think they'll charge 8£ for delivery.
Bike shop... they get repair parts to keep older bikes on the road, online sellers favor offering deals on the latest Kit.
I doubt you will fiind just the window, its just not worth it for shimano to inventory every small part, so they Dont.,, try clear packing tape ..
or expect to replace the whole lever..
Quoted: 14 Post(s)
Your odds of finding that part are low. The shifters are old by bike industry standards, and they're not high end. Shimano small parts availability is generally not great. If you need something, look up the component on si.shimano.com. Most parts have a model number on them—in this case ST-4500. Shimano is generally excellent at having exploded views with parts lists. Find the part number you need. Search both Google and eBay for that number and you may get lucky.
Sometimes for current production stuff I've had luck as a professional shop mechanic calling Shimano to get small parts not listed on their dealer portal.
In this case I'd advise giving up on replacement. I don't think the name plate provides a very significant amount of protection to the shifter anyways.
I know this is an old post, but I am running with the same issue. I cannot find the original part, everything sold does not match my lever's place. What did you end up doing in this situation? I'd appreciate your input.
