Derailleur Adjustment Sequence
I replaced the crankset on my time trial bike and have been adjust the front and rear derailleurs including the "B" limit screw. I think I need to start from scratch as I've gotten everything out of whack. Do I start w/ the front or rear derailleur first? Do I adjust the "B" limit when doing to the rear or does it need to be addressed first of all?
Thanks
Thanks
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Thanks
Thanks
A bit more information on what your bike is doing would be helpful but you really don’t need to “start from scratch”. That route is likely to put things even more out of whack than to fix the problem.
Stuart Black
Stuart Black
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
If you've messed things up and aren't super experienced starting from scratch is a great idea. OP...which front derailleur?
Liked 4,218 Times
Honestly, even on a new install, there is very little to do in terms of adjusting the limit screws.
Stuart Black
Stuart Black
Bikes: lots
Liked 2,932 Times
Yea. Great idea if you want to really make a mess of things…especially if MLProbst isn’t “super experienced”. And how far towards “starting from scratch” do you suggest on going? Remove the derailer and back out all the limit screws then reinstall?
What does that have to do with the price of rice in China?
Liked 4,218 Times
I just love how everyone questions my “experience”. Please point to a derailer that isn’t set up like just about every other derailer that is radically different from the last 50+ years. Even electronic ones have limit screws. Looking at the current Shimano derailers and the dealer’s manual, they aren’t fundamentally different from those other antiques nor do are they set up any differently. The limit screws still do what limit screws have done since the invention of derailers…they limit travel. They don’t do anything else.
Stuart Black
Stuart Black
Bikes: lots
Liked 2,932 Times
Current Shimano 'toggle link' derailleurs are not like any other derailleur EVER. Go read the manual and tell me it's the same as every other derailleur out there. Even the SRAM YAW derailleurs are different. I guess you don't see those very often, yeah?
I have moved the front derailleur from its original position on the frame and I replaced the cable. At any rate, I seem to get nowhere. I can get the rear derailleur adjusted, but I've not had any luck getting the front derailleur adjusted correctly. I can get it to shift, but never seem to get it adjusted to where I don't have serious chain rub in either the small or the big ring.
Bikes: lots
Liked 2,932 Times
Once again...what derailleur do you have? I can't help you if you don't help me.
Liked 4,218 Times
No, I don’t see those very often but I’m reasonably certain that I could install and adjust one without much more very few problems. It’s not like either one lacks limit screws or cables or attaches in any significantly different way. Honestly electronic ones have more differences and they still rely on the same kind of technology as a 70s Simplex derailer.
Stuart Black
Stuart Black
Liked 4,218 Times
Once you check the alignment (and adjusted if needed), check the cable tension. In the smallest chainring, the cable should be taut. Shift to the largest chainring and see if the front derailer moves outward if you put pressure on the shifter. If it does, you need to increase the cable tension slightly.
If you have been adjusting the limit screws, you may need to set them again. Follow what the Park Tool links say for setting those if you need to. But, generally, once those have been adjusted, they don’t usually need further adjustment.
Stuart Black
Stuart Black
Likes For cyccommute:
Bikes: lots
Liked 2,932 Times
“Toggle links” are not like any derailer EVER?! Really? Have you read the manual? They have some refinements but that use the same steps (with some additional ones) but it’s not like they are nothing like any other derailer. Same with SRAM YAW.
Liked 4,218 Times
Sounds like you've never seen one. There are 2 major differences that you'd know if you ever had...wanna tell me what they are? Yes, this is a test. It's very easy for anyone that's worked on one of them. 'Very few problems'? A single one is enough to keep it from working properly. And no...the Di2 derailleurs are more similar to 'normal' derailleurs then the toggle link are. Go ahead, tell me what you think the 2 big differences are. They're pretty obvious.
Neither of those are “big differences”. Minor…and welcome…refinements but not something that fundamentally changes how a derailer is set up.
I’ve already said I haven’t worked on one. But I have read the manual and looked at videos on how to install one. They aren’t all that different from any other front derailer. And certainly not something that makes it so that I need to know what kind of derailer is on the bike to offer advice on how to make adjustments based on what information has been provided.
And, finally, just because I don’t see a lot of newer bikes doesn’t mean I have no experience. I’ve worked on thousands of bikes. There is very little that I haven’t seen or fixed. It’s all pretty much the same and approached in the same manner.
Stuart Black
Stuart Black
Bikes: lots
Liked 2,932 Times
Except that with the new derailleurs ALL adjustments are made w/ the rear derailleur on the large cog. And that the high limit adjustment is made by checking chain clearance with the INNER cage plate and chain on the large cog, not the 'same as always' chain clearance to the outer place while in the small cog. You may have worked on 'thousands of bikes' but I see so many newer bikes that are set up incorrectly and I can only guess there are a couple of reasons for this. Either a new, inexperienced mechanic OR an experienced mechanic that doesn't see the need to RTFM because 'they all work the same, right'? The new Shimano and SRAM derailleurs are different. That's a fact. If someone needs help adjusting one you can't just give them the same methods you've been using forever.
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
...*sigh*
...*sigh*
Bikes: lots
Liked 2,932 Times
What?
Bikes: lots
Liked 2,932 Times
Quoted: 1944 Post(s)
Liked 2,164 Times
I think it might be best if the OP let us know what FD he is trying to setup.
This thread is like the quartet on the Titanic...
"Let's play Nearer my God."
"How about When the Saints go Marching in?"
"Can't we just play Auld Lang Syne? We probably won't get to do it on New Year's."
"We've never done In the Garden of Eden by I Ron Butterfly. That will probably take us to the end."
John
John
Likes For 70sSanO:
Bikes: lots
Liked 2,932 Times
I've asked twice what derailleur the OP has...obviously no reply yet. Knowing which model he has definitely makes a difference in how it's set up despite what some 'experienced' posters would have us think.
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
...it's actually worse than you've let on. A couple of weeks ago I had to sort out some godawful hybrid bike for someone, that came equipped with a very low end Shimano indexing system. Probably a Mart bike originally, it had been given to my friend, who fiddled around with it and replaced the front derailleur cable.
This particular front derailleur had a cage that was stepped, so it was wider at the bottom portion, narrower at the top.
I suppose it was designed with the idea that it needed to be narrower at the top for the shifting push, then wider at the bottom, to accommodate a wider chain angle variation.
Anyway, somewhere along the line a previous owner (or possibly my friend), had dropped the front derailleur position too low. With the cheap, low end. front indexing shifter, you couldn't really trim the thing to avoid chain interference with the cage. It took me a couple of minutes of head scratching to figure out what was going on, and I had the damn thing in front of me. Mart bikes are like that. I momentarily flashed back to my Saturdays working at the bike co-op. PTSD, I think.
But don't let me get in the way of another pointless exchange with you know who. I, for one, am enjoying it.
Likes For 3alarmer:
Liked 4,218 Times
Stuart Black
Stuart Black
Liked 4,218 Times
See the part of the picture over on the far right side? Notice that it is set in the outer chainring and outer cassette cog?
By the way, did I get the answer you were looking for? Did I pass your test?
Stuart Black
Stuart Black
