front brake lever keeps bottoming out
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
Middle of last July, the left (front) hydraulic brake lever of my Kona slowly bottomed out. LBS said bleed. Month later, exact same thing happened. They said bleed again, but I said there has to be something going on, maybe a leak. So I said new brake assembly (caliper, lever, hose). Replaced the original Tektro with Shimano Deore. Now, starting to happen again! What can be the explaination?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
If the system is bled properly turning the bike upside won't matter. If there's no air in the system, there's no air in the system. Sounds like it's never been properly bled.
Quoted: 268 Post(s)
Liked 80 Times
update, fwiw. Took it to a different (my usual shop is temporarily closed) shop- they made a simple reach adjustment, using a 2.5mm hex. Problem solved.
Likes For epnnf:
