Will aluminum skewers corrode a steel bike?
Quoted: 7 Post(s)
I want to replace my stainless steel quick release skewers that came with my vintage Bianchi with aluminum ones... Is that a bad idea in terms of corrosion resistance? I don't want to have to apply grease to the skewers every time I wash my bike.
Quoted: 2339 Post(s)
Liked 2,831 Times
bad idea in terms of strength, why would you want to do this?
Likes For squirtdad:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
the skewer levers are anodized and will resist corrosion for more years than you will own the bike... the skewer rods do require a smear of grease every couple of years... they are steel and will rust, a form of corrosion.
if your bike has horizontal dropouts where the rear wheel mounts up, you will not be happy with your aluminum QR levers.
if the rear dropouts are of the modern vertical design, they will work fine.
you will reduce the weight of your bike by about 2 ounces by swapping to the aluminum levered skewers.
if you take time to properly adjust the axle/bearing tension to a "slightly loose when not mounted to the bike" tension, you will save far more resistance to your pedalling force..QRs TIGHTEN the bearing setting. Do Not Over-Tighten a QR.
https://www.slowtwitch.com/articles/...n_dropouts.jpg
Quoted: 1821 Post(s)
Liked 1,697 Times
On older bikes with horizontal dropouts you need steel skewers with internal cam levers to be able to tighten the wheel in place to avoid the wheel going off centre between the chain stays.
Quoted: 1401 Post(s)
Liked 1,886 Times
one option is a ‘hybrid’ approach - aluminum and steel - aluminum skewer nut on left side and steel nut on the right / drive side ... or an alloy nut with steel insert on the right / drive side
the steel nut on the right / drive side will provide enough bite to eliminate movement on the horizontal dropouts
I did this on a vintage steel bike - Control Tech bolt on titanium skewers with the alloy nut on the left side and a larger steel nut on the right / drive side to ensure the wheel did not move in the dropouts
could do something similar with traditional skewers - just replace the alloy nut on the right / drive side with a steel nut ... or an alloy nut with a steel serrated insert
Quoted: 4420 Post(s)
Liked 1,568 Times
Shimano aluminum skewers seem strong enough for my horizontal dropouts.
Quoted: 7 Post(s)
What do you mean? I thought you were supposed to tighten the skewers as tight as you can when you mount the wheels to the bike. What does "slightly loose when not mounted to the bike" mean? You can tighten QR skewers when the wheel is off the bike?
Quoted: 3515 Post(s)
Liked 2,929 Times
What do you mean about tightening the skewers as tight as you can?
Liked 1,568 Times
He's talking about the hub bearing adjustment, not the skewer. And his comments only apply to traditional loose ball hubs. If the bike was set up by a decent shop the hubs should have been adjusted properly.
Liked 739 Times
The bike has vertical dropouts. It's early 90s I believe.
Liked 739 Times
a bike showed up like that just two weeks ago... the owner got a condensed version of QR 101 that day... i retest them when they return to pick up their bikes...
Quoted: 2026 Post(s)
Liked 1,096 Times
Likes For HillRider:
Liked 1,568 Times
Quoted: 7 Post(s)
Quoted: 7 Post(s)
Yup, I guess I've been doing things all wrong. Thanks for letting me know.
Liked 1,568 Times
Quoted: 1088 Post(s)
Liked 1,028 Times
No, they won't corrode a steel bike. As others pointed out, aluminum doesn't grip into steel frames well and with more horizontal dropouts can slip under heavy load like an out of the saddle climb. During a cross race last fall I ripped the back wheel out of place so the tire would rub the non-drive side chain stay 3 times on the same short off camber climb. Not the fastest rider due to my weight but plenty of power and it sucked having to stop, try to under the skewer and reset the wheel. Vertical dropouts have no trouble with this at all.
Liked 2,929 Times
Liked 739 Times
here's one popular internal cam QR assy... aluminum ends, high grade steel rod... aluminum lever attached to a steel eccentric.
https://www.walmart.com/ip/Shimano-X...8e0b64ccb06fae
Liked 1,568 Times
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
Should the aluminum corrode, not steel? The nobility chart of metals shows aluminum and zinc as the least noble. This means that the steel bike may corrode the aluminum skewer, but the bike itself will be OK.
Likes For csport:
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
Replacing steel quick release skewers with aluminum is a terrible idea that will lead to massive corrosion effects.
I ruined this fine steed doing just that.
Quoted: 569 Post(s)
Liked 589 Times
The paint on your Bianchi is a well proven means of preventing galvanic corrosion between steel and aluminum.
Quoted: 981 Post(s)
Liked 584 Times
Sheldon is correct about the axle compressing slightly; Park is incorrect about the axle flexing, but both are correct that bearings of hubs with Quick-Release axles must be left slightly loose when the wheel is off the bike. An easy way to adjust the bearings correctly, with the axle under compression, is to use an axle vise like THIS ONE.
