I want to make my own leather brake hoods
Has anyone got some cutting patters for me or any other suggestions?
Would love to hear from you all
Fat Guy on a Little Bike
Bikes: Two wheeled ones
Quoted: 1254 Post(s)
Liked 345 Times
I know it was tried by Rootboy...and he wasn't thrilled with the results as I recall.
https://www.bikeforums.net/classic-vi...d-project.html
Photobucket sort of killed this.
52psi
Quoted: 790 Post(s)
Liked 802 Times
The results were solid, I think (there's a pair of 'em on my Paramount and they're sweet)... it was just the colossal PITA construction part that got to him IIRC.
But yeah. It can be done!
Quoted: 1074 Post(s)
Liked 295 Times
I've done a pair.
Don't know how much a pattern would help.
My levers might not be a close enough match to provide much benefit.
I cut a paper template.
Got some thin and supple leather out of an old handbag. Soaked it in warm water. Did a trial fit. Pulled, shaped, trimmed.
Coated both leather and lever base with contact cement. Waited a bit. Mounted the leather. Used clamps to hold it in place while it dried.
Once dry, I did the final trim of the edges, trimmed off some folds and stitched them together.
Quoted: 3811 Post(s)
Liked 6,714 Times
I believe @PastorBobnh also created some.
Quoted: 4806 Post(s)
Liked 3,932 Times
I've done a pair.
Thinking out loud: suppose I glued on a "U" from the top and a small rectangle from the bottom. Let that set up, then wrap the whole thing tightly with quality thin tennis racquet or HB leather tape, contacting cementing it down as I went. So lots of leather so a nice grip. It ought to stay put. Interesting. Might do it someday. (I love the Tektro V-brake levers for drop bars. Wonderful hand holds. When I kill those hoods this could be a really good upgrade.)
Ben
Liked 295 Times
But I stitched mine.
The leather meets in the middle on the underside, behind the lever, and is stitched together.
Felt solid enough.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
It's not that difficult to make a decent leather hood for a brake lever.
Making two good ones that match, that's a much bigger challenge.
Making them in any quantity, as @rootboy was doing (and very well, I think) efficiently enough for it to be worth your time, I kinda doubt it's possible.
I have a pattern I can post, along with my suggestions. I'm sure Rootboy has a better pattern and better advice.
Señor Member
Quoted: 1492 Post(s)
Liked 1,096 Times
I made some a few weeks ago. Getting close to finishing the project they're on, so haven't tested them out yet. Some pictures along the way:
Likes For USAZorro:
52psi
Quoted: 790 Post(s)
Liked 802 Times
@USAZorro -- I'm intrigued by the sparkle blue treatment. Will be watching for the finished project.
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
How do you get blue sparkles on leather?
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Señor Member
Liked 1,096 Times
I mixed two different leather paints. One is Angelus Sapphire (the blue). The other is Leather Studio Silver Metallic. It took about 3 coats to get the saturation I wanted. I am just as curious as anyone about how well it will hold up.
Quoted: 2588 Post(s)
Liked 4,824 Times
They are absolutely fabulous! I bought two sets; one is in use on the gold Colnago and the other one is waiting for the right project some day...
DD
Has anyone tried fastening the hood ends together with eyelets instead of stitching? My first choice would be stitching too, but I have a ton of eyelets that I have been wanting to use up. Just a thought.
Bikes: '85 Schwinn Madison, '46 Higgins Ultralite, 1950s Wally Green, '85 Trek 660, '82 3Rensho Export, '90 Trek 970, '91 Schwinn Paramount, '78 Dawes, '78 Trek 730
Quoted: 77 Post(s)
Liked 263 Times
Likes For brewerkz:
Señor Member
Liked 1,096 Times
I guess you could, but what would you lace them with? In the case of my hoods, I think there'd only be room for 2 eyelets at the point that they're stitched together. Not sure how well that would hold.
Liked 345 Times
Rootboy is a perfectionist...and his own hardest critic. He's made me a couple of bags and bar plugs; I thnk the world of his talent.
Quoted: 109 Post(s)
The blue sparkles reminds me of the blue (or red or silver) sparkle Naugahyde on the Kustom amps of the late 60's and early 70's. I think the Naugas went extinct.
Oh, the same material could be found in some diner and bar stools....
Likes For nashvillebill:
Quoted: 556 Post(s)
Liked 132 Times
Yeah, sorry about the photo death, Logte. Had all my pics on the dastardly Photo****ket and they screwed the pooch, so I deleted all of my pics on that site and haven't figured out how to post directly to this forum.
I was pleased with the few sets that I thought turned out well but they were a major pain in the whatzit to make and, Aaron is right. I am cursed with the perfectionist malady and wanted them to be as perfect as I could make them. A lot of frustration ensued. But some worked out OK. I only made them for Campagnolo brakes, a beautiful if tricky lever body to cover.
The main challenge I found was taking a natural material that has a definite grain (stretches, and shrinks, more one way than the other) ...which was once covering a curved, three dimensional shape, then removed and flattened during tanning, and trying to then get it to conform to a very small shape with lots of compound curves...and not stretch too much, or too little in the process.
It was a fun project though, and I wish you all success.
Anwyay, here's a bit of progress for tonight. I'm going to use a layer of padding of some sort underneath the leather, not sure what yet. It'll have to be molded into shape though.
Liked 4,824 Times
I still have my custom Colnago saddle bag and some tire-savers - but I wasn't quick enough on his short-run of handlebar plugs
@zammykoo: those are looking good!
DD
Steel is real
Bikes: 40 - accumulated over 40 years
Quoted: 377 Post(s)
Liked 1,087 Times
I have been looking into this for some years now but never got around to actually doing it. My reason for being interested is the future lack of original gum hoods - of course. I feel I would rather have a home made solution than using aftermarket gum hoods.
This is the direction my investigations has taken me:
https://www.google.se/search?q=vacuu...w=1366&bih=659
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Those are looking real nice @zammykoo. Rootboy and Drillium Dude kind of set the standard for me personally, if they offer up something its worth taking into account. Biggest thing I can offer is to have patience about everything you try that is this difficult.
They may not make any claims about their personal skills or habits, but their attention to detail brings it out. The guys and ladies here have taught me more than I dreamed of, when getting interested in C&V bikes again. Please keep updating this thread.
Bill
Bill
Semper Fi, USMC, 1975-1977
