Motobecane ?
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
Motobecane ?
Does this look right ?
Repaint ?
26.4mm seat post seems right .
Paint just looks a bit too good (from this distance) to be right .
Repaint ?
Quoted: 18378 Post(s)
Liked 4,512 Times
I haven't seen those lugs and fork on a Motobecane, although most of the ones I've encountered were from the 1960's and 1970's.
What does the sticker on the top tube say?
Looking at photos on the web, by the mid 80's, Motobecane started selling bikes with a similar aero rear stays. But, the seat tube lug still looks a bit different from what you have.
Quoted: 4722 Post(s)
Liked 3,038 Times
Based on the extensive chroming, Columbus tubeset and La Redoute decal on the top tube, it would appear to be a Team Champion, which was claimed to be a exact replica of the bicycles used by the La Redoute pro team. The only years that show cables routed below the top tube are 1983 and 1984 but the 1984 model was inexternally brazed, so that leaves 1983. However, I notice that you are in new Zealand and I don't know how much market to market variation existed. However, if it truly is a Team Replica, I wouldn't think that there wouldn't be any such variation. Regardless, it's not a perfect match. This model typically came with a number peg and the blue seems too bright. The catalogues describe it as Night Blue.
Likes For T-Mar:
Quoted: 283 Post(s)
Liked 636 Times
Thank you
As always a mine of information
There are some other pics which I will load up shortly .
The fella who is the new owner bought it as his first bike build ( brave man some would say )
The more I look at it , the more I suspect a repaint . The level of corrosion to the chrome seems out of step with the paintwork .
Quoted: 283 Post(s)
Liked 636 Times
what is going on with that groove under the top tube ?
cinelli BB SHELL
Quoted: 283 Post(s)
Liked 636 Times
Likes For 1simplexnut:
Quoted: 283 Post(s)
Liked 636 Times
Motobecanes are not my usual flavour .
That being said I like the look of this frame .
Quoted: 1641 Post(s)
Liked 831 Times
It seems like almost all the pro factory French teams defaulted to Columbus or Reynolds tubing for their steel pro bikes.
I wonder shy they did not try to promote French tubing makers like Vitus. I'm sure Vitus would have tried to even develop tubing with specifications that could match the Italian tubing makers if it meant more commercial exposure in the pro circuit.
Liked 3,038 Times
Good point on the dropouts. I hadn't picked up on them in the original pics. Those are Campagnolo dropouts, which were used pre-1982, per the literature. However, those years didn't have the brake cable running under the top tube or the fully chromed stays and forks. 1982-1984 used Simplex dropouts. Neither the French or USA market catalogues show a Team Champion for 1985,. This is getting more perplexing.
Liked 3,038 Times
Liked 3,038 Times
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Edumacator
Quoted: 2440 Post(s)
Liked 3,130 Times
I have those top tube grooves on what seems to be a mid-level gravel-xcross MBK frame (the badge for the 90s I think after Motobécane became MBK). I have never been able to place or find the frame since I got it.
Likes For jdawginsc:
Quoted: 192 Post(s)
Liked 566 Times
Hi T-Mar .
Thank you
Thank you
A re-spray would also explain why the color is a little light in shade.
Quoted: 283 Post(s)
Liked 636 Times
Will have a fossick about for mbk frame info
Thanks.
Liked 3,038 Times
I also just noticed that the frame has a Camapgnolo style front derailleur mount. The 1983 and 1984 Team Champion had the Simplex mount that looks like a bottle boss. None of the lower models had brazed-on front derailleur during this era, outside of the Profil, which required one due to the teardrop shaped set tube.
This frame was obviously built for Campagnolo components, which would seem to contradict the LaRedoute tie, as the team was only in existence form 1979 to 1985 and used either Huret or Simplex derailleur systems.
BTW, I made an error in an earlier post, stating that the 1984 version of the Team Champion was inexternally brazed, It was traditional lugged construction, like 1983. I advertently referred back to the next model down, Le Champion.
Quoted: 283 Post(s)
Liked 636 Times
I don't think that the frame that the OP is questioning goes into the 1990s, let alone the late 1980s. It's obviously a higher grade frame by virtue of the Cinelli BB shell, Campagnolo dropouts, reinforcing tangs, etc. Yet it only has a single set of bottle bosses. Two bottles were de rigeur on high grade racing models, let alone team replicas, by the late 1980s.
Thanks again for your thoughts and expertise !
I am pretty sure we can forgive your error
When did the Campagnolo style front hanger come into existence ?
Seems fairly certain that this frame is a repaint /redecal .
It is a nice frame but pretty confident it is not what it presents itself as .
I dont think the owner will be bothered either way .
Thanks all for your comments and input .
Quoted: 192 Post(s)
Liked 566 Times
I have a “Team Champion” with a somewhat mysterious past. I cleaned it up and resprayed it as the existing paint was not worth saving and was pretty tatty. The chrome, etc. was of a high standard and still in very good shape. I did remove the number mount as what was left of it appeared to have been cut off with pliers. It was alleged to have been a team frame, but who knows? There were a few letters printed on the steering column when I stripped it, but I could not match anything up. In any event, I don’t believe that it was made by the same people that normally make the frames. While the bottom bracket, Columbus (metric) tubing and some other details were the same, the chrome pattern, lugs, and especially the dropout treatment was quite different. It is a very nice riding bike, and I have never experienced another bike whose ride was more “ruined” by clinchers. The ride is very light and nimble with tubulars, but it acts as if it is half asleep with clinchers…
Liked 3,038 Times
The earliest literature in which it surfaces is the Olympic Catalogue, released in the autumn of 1982 for the 1983 model year. However, if you look at old pro race photos you'll see it on the 1982 team issue bicycles. It was common practice to test products with at least a season of pro racing before commercial release. So, depending on the exact nature of the frame, it should be no earlier than 1982-1983. . A 1983 model year would coincide with the apparent introduction of the cable housing trough. I would have expected Portacatena compatible dropouts but these look like they may have had some extra work done on them by the builder
Liked 3,038 Times
The rear dropout looks like Meral. I don't know much about the brand but I do know that when La Redoute ended their pro team sponsorship in 1985, the team got new title sponsorship from R.M.O. Motobecane also ended their deal at the same time, with the bicycle sponsorship being taken over by Meral. Consequently, several La Redoute-Motobecane riders also rode for R.M.O.-Meral. Is it possible that the previous owner got things a bit mixed up and that this is an RMO-Meral team issue bicycle ridden by an ex-La Redoute-Motobecame pro? I'm just thinking out loud. I'll check my old 1986 race photos, to see what I can find.
Likes For T-Mar:
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 391 Post(s)
Liked 813 Times
Allegedly original team bike for paint match, I think its way darker.
Motobecane La Redoute 1983 (velovintageagogo.com)
Quoted: 283 Post(s)
Liked 636 Times
