double for mtb?
double for mtb?
My knees are not used to and not liking the width of cranks that are triples. Can I use a double crank with a 108 length bb? Anyone else do that? Any suggestions?
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
I ran a double back in my racing days, but basically just took the small chainring off, instead of replacing the crankset.
Where would one acquire a double for the rigors of MTB'ing?
I'm running a road isis BB on my raceface prodigy cranks with two rings. It works fine. Granny gears are definitly not needed around raleigh, nc, and this skinny q-factor feels more familiar (started on road bikes).
you can only run a shorter BB if you have a square taper, ISIS, or old (3 piece) XTR. Newer shimano octalinks are different between road and mountain stuff.
everyone has a plan...
works great.
Bikes: 2010 Wilier Gran Turismo
I have a double crank set on my mountain bike. It is a Truvativ Holzfeller 2.2 RG, I don't know what the BB length is or what the q-factor is though.
Writin' stuff
Liked 19 Times
You can just take the little ring off to run double, but that doesn't solve your q-factor problem. What you want to do is buy a 2x9 specific crank like the Middleburn RS8 duo, the FRM 2x9, or the new FSA 2x9 when it comes out. This way you can run a tighter BB and reduce your Q-factor to a more road-like configuration. I believe extralite makes a double crank as well.
