IRD triple front derailleur question
Quoted: 598 Post(s)
Liked 283 Times
I've got an IRD Alpina-D triple front derailleur installed presently with my triple 9 speed drive train and everything works fine. Do you think if I switched over to a 10 speed chain and drive train, it could handle the slightly thinner 10 speed chain adequately? For what it's worth the crank is a 46-36-24
As always, thanks for your input.
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
Probably, but why tempt the gods? What, pray tell, do you hope to gain?
(And to answer the question directly, we would need to know what you are using to shift it.)
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Quoted: 598 Post(s)
Liked 283 Times
I've got standard Ultegra STI 9 shifters presently but would be picking up some Shimano 10 speed sti shifters (not sure what level at this time, maybe the Tiagra because they've got the barrel adjusters built in which would be convenient).
I would think it might only need a little tweaking the stops if possible, or do the new Tiagra front shifters pull a different amount of cable than the Ultegra shifters from 6 or 7 years ago? Thanks, I do appreciate the help.
I love Friction shift levers they work with Just about anything
Not adventurous stick within Shimano stuff Road = road Mtb = Mtb
micometers of chain width is probably meaningless
IRD is a Brand of Merry sales Imports ` in So San Francisco & They have a telephone.. they can be asked directly.
https://commerce.merrysales.com/msc/a...=&Tp=&FgtPass=
Elitist Troglodyte
If you're going to change the shifters too, then the index will also change. The FD is just a dumb lever. The smarts are in the shifter. I'd say you can keep the FD, and good luck.
- Will Rogers
- Will Rogers
Expired Member
Quoted: 3674 Post(s)
Liked 5,432 Times
I think the derailleur would be fine. I've used 9 speed Shimano front derailleurs with 10 speed chains and it worked well. One problem might be your chain rings as some designed for 7-8-9 reportedly do not work well with 10 speed chains. I have no experience with this.
Si Senior
Bikes: Too Numerous (not)
Quoted: 23 Post(s)
Liked 10 Times
