Frame size preference.
#51
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,833 Times
Wow, I'm 71 and my height hasn't yet changed. Or less than 1/4", still at 73.25"
60 X 58cm has always been my size. When I wanted to ride the classic vintage euro bikes, my patience required I accept a range of sizes to obtain the bikes I wanted. So, my group runs from 58cm - 62 seat tubes. The 58cm bikes will be the first to go.
So I guess I would size up - but top tube length, stem length, seatpost set back, handlebar dimensions, and the specific saddle all play into making the fit a perfect dream. Or not.
The AustroDaimlers are 62.5X59 ctc
The Bottecchia is 58X57
#52
Quoted: 4234 Post(s)
Liked 2,949 Times
This bike has a bit more than a fistful of seatpost showing but, as a taller rider, I was excited to find this 64x62 cm frame.
This has even more seatpost showing (and a shorter headtube than I'd like - shorter top tube sort of makes up for the less reach, but it's not as comfortable on my back as the above), but again, beggars can't be choosers. I was tired of being without a bike after my previous one had been hit and the above was still in the frameset state and the BB was both bad and seized to the shell, so it wasn't usable. This 62x59 cm frameset was what I could find at the time.
#53
Veteran, Pacifist
Liked 4,833 Times
Nice simple photo, too
Likes For Wildwood:
#55
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
A hot topic for sure and I guess the industry would say you need to get a professional bike sizing to get the best fit, or at least that's what I keep seeing in videos. I think it makes sense to get a bike sizing but what about having multiple bikes, never mind multiple bike types? I have a newer Cannondale bike, 56 cm that I feel fits me quite well and I can ride it for long distances with minimal issues, despite never having got a bike sizing. But then I jump on one of my older steel bikes and now I'm on a different bike geometry and so does that impact the comfort I should have?
Same thing when I ride my 90's mountain bike which is a different geometry and different sizing consideration than the road bikes.
#56
Veteran, Pacifist
Liked 4,833 Times
The original owner only changed 1 item from factory build - the rims from tubular to clincher. I swapped the Record RD to NR, a better seatpost/clamp, and use a tubular wheelset. New gum rubber hoods. Very nice ride. Columbus SP for tubeset (I think), which is good for my 190lb body.
#57
Quoted: 2333 Post(s)
Liked 2,097 Times
I went into two dealers this week, both are telling me about a year for a frame. When my eyes bulged, the guy said he has a customer who had been waiting 3 years. That is one reason someone might be on too small of a frame.
I used to be 6'4'' but measured recently I am only 6'3'' with 36' inseam (crotch bone to floor) with a 1.04 Ape Index. I'm riding a 58 cm frame with a 396mm reach and 605mm stack, 73 degree seat tube angle, 25mm setback seatpost and a 150 mm stem. It fits on paper or video for the fancy expensive fitter. I got sold that frame size by a shop with a good fitter but it never felt right.
Does it fit on the road? Not really. I dominate the thing. Balance isn't right. Too small. As an example, I have a steep bumpy descent with some corners. It is a handful for many reasons. I recently took out another bike on the same hill, it is more of an endurance frame than a road racing frame. Going down that hill, I thought......man, is this bike slow. I looked down and the Garmin was saying the same 40 mph as would be about the case on the "racing" bike. It was boring. It might be a little big but I only need a 120mm stem on it and the longer wheelbase and trail seem better to me than too long of a stem with my ass hanging off the rear wheel trying to keep it straight on steep bumpy descents. I might be wrong here.
#58
Quoted: 514 Post(s)
Liked 448 Times
That Bottecchia has the perfect early '70s vibe. It reminds me of Doug Dale's venerable Cinelli Corsa A.
Universal made very nice brakes. When I built up my Roberts with #68 sidepulls I took some grief from my friends, but they served me very well. Do you have photos of the Follis and Zeus? Many many years ago I connected a girlfriend to a beautiful Follis 972 that was practically made for her. And I always regretted impatiently jumping on a Raleigh International instead of waiting for my flaky neighborhood dealer to find me a Zeus.
#59
Veteran, Pacifist
Liked 4,833 Times
With the latest bike purchase, I was advised by online calculators and a LBS to get a size large. But this one may see some gravel, so I wanted the longer wheelbase and I do like to stretch the upper body, so I sized to XL which closely matches my other carbon fiber bike. Maybe my arms are long for 6'1".
Likes For Wildwood:
#60
Quoted: 514 Post(s)
Liked 448 Times
The last time I was in the Whitefish, Montana, area, I rented an alloy BMC. The shop gladly set it up just right for me, flipped and slammed the stem, and after a couple of days riding it, I had to say I wouldn't mind if this was the last bike I ever owned. Because it fit properly.
#61
Veteran, Pacifist
Liked 4,833 Times
The Follis is either 072 or 172. Falck tubing. The bottom model available. Put a 46/30 crank and cyclocross tires on it and it was my offroad for a while. Now only a frameset.
#62
Quoted: 604 Post(s)
Liked 1,063 Times
Simple answer, from personal experience, much rather have 1 size too large.
Tim
Tim
Likes For tkamd73:
#63
Quoted: 514 Post(s)
Liked 448 Times
Wildwood, I'm in love with your Zeus. Is it, by chance, a 60 cm?
#64
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
I get bikes by the effective top tube length, not the manufacturer's size or seat tube length. That makes a lot more sense and makes the choice of frame size simple - you immediately see what your stem length might be.
Results matter
Results matter
