Shimano caliper compatibility
Will tiagra brake calipers work with sora components? Updating an older bikes caliper brakes and tiagra calipers are cheaper than soras. Thanks as always
Quoted: 20810 Post(s)
Liked 9,456 Times
You might want to post in the Mechanics forums. In general, though, I think that brakes and levers from the same generation are compatible with each other. When you're mixing generations, like levers that are one gen old and calipers 3 gens old, you may get in to a situation where the pull ratios are slightly different and the braking is compromised.
You can also check with the Shimano tech docs, available on their website.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
They'll work. And yes, should be in the mechanic's section. Where I'm still banned.
Likes For cxwrench:
Quoted: 6199 Post(s)
Liked 4,816 Times
Shimano gives you all the stuff you need to figure this out. Depending on how old the Sora is you might have to go into the archives.
https://productinfo.shimano.com/#/co...737&acid=C-456
https://si.shimano.com/en/#/
Yes, mechanical questions are better ask in the Bicycle Mechanics section. Not all of the knowledgeable mechanics and DIY'ers come to this sub-forum.
