Well I’ve gone and done it, New Look Frame
#51
Quoted: 4413 Post(s)
Liked 4,863 Times
I must admit, I did raise an eyebrow at the saddle
Wheelset looks ace. If I was building a bike up they would be my choice too. I like that they don't require taping for tubeless.
#52
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 212 Post(s)
Liked 356 Times
It’s coming along, 15.8 pounds as it sits minus 2 rotors, 1 caliper and a chain, thinking it will easily end up around 16.5 once it’s done and the cables and hoses are cut to length and the right stem and spacer stuck arrives. I thought it would be closer to 19 when I was planning.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Likes For Shadco:
#53
velo-dilettante
Quoted: 1628 Post(s)
Liked 3,114 Times
#54
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 670 Post(s)
Liked 976 Times
congrats on your new bike
#55
Quoted: 601 Post(s)
Liked 779 Times
Awesome and like the LOOK and model decals that many other modern stealth racers have removed.
Please keep that Brooks saddle handy for more eye candy joking and tributes to vintage racers
#56
Resident PIA
Quoted: 212 Post(s)
Liked 356 Times
All that is left is bar tape and a little FD tuning.
Shad
67'er
Shad
67'er
#57
Resident PIA
Quoted: 212 Post(s)
Liked 356 Times
She is done.
Shad
67'er
Shad
67'er
Likes For Shadco:
#58
Bikes: Aurelia*Bianchi*Cannondale*Colnago*Dahon*Giant*Haro*Lynsky*Monkey Faction*Origin8*Panasonic*Paramont*Peugeot*Ross*Schwinn*SE*Specialized*Trek
Quoted: 58 Post(s)
Liked 26 Times
Enjoy your new frame set and build
#59
Steel is real
Quoted: 670 Post(s)
Liked 976 Times
very nice build
#60
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Shadco Having had your bike for a whole year now, how do you like it? Was it hard to route the hoses and cables through the headset?
I stumbled upon this thread while researching a Look 765 in medium, which has almost perfect frame geometry for me. So few endurance bikes (i.e., stack:reach > 1.5) with a round seat post.
#61
Resident PIA
Quoted: 212 Post(s)
Liked 356 Times
The frame came without the top cable guide so routing was a little easier, Look came up with the missing piece later on and recently I pulled everything out and reinstalled everything with cables thru the spacer stack it was much easier since I had been there and done that once before. If I had it to do again I would probably go Ultegra Di2 which would be so much easier.
This is how she stands today at 17 lbs 2 oz.
Shad
67'er
Shad
67'er
#62
Liked 1,471 Times
#63
Resident PIA
Quoted: 212 Post(s)
Liked 356 Times
Presumably if I buy the same frame now it would come with the top cable guide and matching steerer spacers, although I do not mind the hoses entering the head tube in front of the steerer as shown in your prior photos. To minimize the complication in either case, I would also go with Ultegra Di2. Your bike looks good! And 17.2 lbs. is pretty light; do you recall the frame and fork weights? How is the handling? (I only ask because of all the above posts re: slacker than common head tube angle.)
This is what was missing from my frame.
The only handling issue I’ve noted is a little bit of wandering at very low speeds on steep climbs but it isn’t a problem just different compared to my Aethos.
.didn’t get weights but mine has a Berk saddle, light weight turbo cotton tires, Ridenow tpu tubes, and an Edco 1 piece cassette all saving a noticeable amount of weight, the Campy groupo is also light as are the s-works carbon bars.
Oh and the Look carbon seatpost which doesn’t come with the frame.
Shad
67'er
Shad
67'er
