Specific tool for Campagnolo chains?
I am replacing a Record 10 speed chain.
I have done it in the past just using the chain tool on my multi-tool. Maybe I never read the instructions before but they are very specific in saying to only use the Campanolo tool, part # UT-CN200.
I never mind buying the correct tool for a job but at over $150 is it really needed? Anything else that would be recommended that would do a better job then the Muti-tool that is not as expensive as the Campy tool?
Thanks in advance for any info.
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
Campagnolo requires a peening tool so different than a special S-group chain tool. I recall Pedros and Park making a tool that does peening. The Park one is currently discontinued only because a new one is in the works but your local shop might still have a CT-4.3. Me personally if I did have a Campagnolo drivetrain I would probably have the tool as I would want to make sure I did it correctly because I bought the Campagnolo drivetrain and want to stick with Campagnolo parts though I am lucky enough to have a Abbey Decade Chain Tool so in that case I might not because I have the finest chain tool out there which has the peening ability.
A multi tool is a really poor chain tool. Multi tools are tools I would carry with them while riding to perform usually functions that require a different hex and torx wrenches and maybe a screwdriver or two and maybe some separate tire lever(s) and inflation. The only time I might consider a chain tool is mountain biking or long distance touring or something like that. Multi Tools that try to do everything seem cool in the head but aren't great in actual practice. Trying to miniaturize and keep everything together leads to tools that are harder to use in the end. Plus I don't think I have seen a multi tool that has a chain tool that also handles Campagnolo chains but even so everything still applies.
Quoted: 2026 Post(s)
Liked 1,096 Times
Campy has always warned against using any chain tool but their own ridiculously expensive and frequently changed ones. If you followed their advice you would have to buy a new chain tool ($$$) from them every time Camy introduced a new chain.
The Park CT-3.3 chain tool sells for about $40 and will work with just about any bike chain made. Also, instead of using Campy's specific joining pin/link KMC makes a Campy-specific 10-speed "Missing Link" reusable quick link that works very well and is far more reasonably priced.
Likes For HillRider:
Quoted: 837 Post(s)
Liked 1,061 Times
+1 for what HillRider said above. KMC Missing Links are VERY reliable, easier to live with if you remove your chain for cleaning and $ as opposed to $$$$$$+ for the tool.
Quoted: 4407 Post(s)
Liked 1,560 Times
Not peening the pin is a recipe for disaster. Do it right or use a different link, or different chain.
Bike shops generally don't charge that much to put a chain on with their tool.
Likes For alcjphil:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Funny Q&A on their website IMO:
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Park made the CT-11 chain peening tool, but it seems to be discontinued. BikeToolsEtc was blowing them out for $20 a while ago, but they seem to be all gone now.
Thank you everyone for taking the time to reply. I appreciate the info.
Will order the park tool and some quick links.
Likes For gt3racerich:
Quoted: 1819 Post(s)
Liked 1,693 Times
I bought one of those years ago when Campagnolo brought out 11 speed chains. I already had a good chain tool and all I needed was to be able to peen the pin. I was able to buy at wholesale prices back then so it wasn't a big expense. I have only used it a couple of times because I am running Campagnolo 10 speed but it is nice to have if I ever need it
I bought the Missing links and tools but when I install them on the chain they are too tight and un usable (they squeeze the chain to tightly, not along the length of the chain but the width). It is a simple design and straight forward installation. Any ideas as to what the problem might be? It is the correct link for the chain.
Liked 1,096 Times
