My sprocket size and ratio research.
Quoted: 1109 Post(s)
Liked 1,200 Times
Why do we need anything other than the ratio between the the chainring and the cassette sprocket here? And more importantly, can I score some of ya'lls stash...
I will say that there is a difference in friction (and wear), all be it small, and bigger is better in both cases.
I really don't know (repeat: I really don't know, not implying that nobody would know) why one would have to be more precise than that. Oh, and crank length - for me - 170-175 - is A-OK and I notice no difference, not only in how it feels, but would be meaningless for how the gearing works. Repeat: FOR ME. I have no doubt that people who compete and have the motor to be truly competitive would want to optimize these things, but for me and probably the other 99.9% of enthusiastic riders and weekend competitors... ? Probably not.
I used to play around with the online calculators, but they didn't give me any more functional information than a simple division exercise.
Quoted: 1858 Post(s)
Liked 664 Times
Sheldon Brown is wrong period. Nobody including him mentions different size riders. For a short rider 165mm cranks would feel more friendly than the 180mm cranks that a tall rider like me likes, both size cranks feel the same to appropriately sized riders. All riders seem to like a cadence between 80rpm-90rpm, backed up by a poll on this very forum not long ago.
All I was trying to do was research if there was that if a 1:2.7 drivetrain ratio was good for me to use, if there was any advantage to using smaller sprockets or larger sprockets because their different diameters might offer more torque, and my measurements said there was no advantage. And that thought and research has nothing to do at all with anything Sheldon Brown talks about at all, zero. Finding flaws in his thinking was just a bonus because the forum member linked to his site when they mistakenly thought the page had something to do with my research, which it did not.
If you have discovered that 1:2.7 is an ideal ratio for you, more power to you! I assume you are riding a single speed primarily. If you have read Whitt and Sharp, you know that the frictional loss in chain/sprocket drive systems decreases as the sprockets get larger, though it is not a large effect. Yes, leverage increases when the pedal arm gets longer, but I don't think that makes any difference in rear wheel power or speed if the sprocket ratio is kept 1.2.7. The energy lost decreases as the sprocket pair gets bigger, but the change in output power is small.
Quoted: 4412 Post(s)
Liked 4,862 Times
Not worrying about Sheldon Brown for the moment, sorry.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I've read that industry prefers a minimum sprocket size of 16T for efficiency and wear. So either of your two ratios are just fine. The 52/19 would be slightly smoother and longer-lasting, but at the penalty of extra weight.
My fixed-gear has been 45/16 for years and years. In the beginning, I was bummed that I couldn't fit a chainring bigger than 45T on that bike, but it has proven to be plenty durable and smooth, so I'm happy with it.
Liked 664 Times
Power is a function of how hard you pedal (pedal force) x cadence. Power is not a direct function of gearing other than choosing an appropriate gear that gives you a sensible ratio of pedal force vs cadence for a given power level. A longer pedal arm has the same effect as a lower gear i.e. it reduces your pedal force for a given power output, but it also effectively reduces your cadence since your pedalling circumference is larger. So you have to move your feet faster to maintain the same cadence and hence power. Power = Pedal Force x Crank Arm Length x Cadence.
Liked 4,862 Times
I'm agreeing with you here.
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
I think the differences in friction between practical sprocket sizes sometimes gets blown out of proportion. The entire drivetrain typically has a power transmission efficiency of around 96%, give or take 1%. So at 200W you could expect to lose around 6-10W max depending on how clean your drivetrain is. While that is still significant, there isn't a lot you can do about it. For example a 2x drivetrain might save you a couple of Watts over an equivalent 1x due to chain line differences, gear sizes etc. Basically not very much. Then when you start looking at differences between things like 10t vs 11t sprocket or a 52t vs 48t chainring on the same drivetrain, it's going to be fractions of Watts that really don't matter at all. Basically you stand to gain more from cleaning your drivetrain!
When we do aero testing on the road, the differences in drivetrain losses are large enough to be annoying and affect the precision of our estimates.
Liked 4,862 Times
The range in drivetrain efficiency for derailleur bikes can be much larger than that; even more if the drivetrain is dirty. For single-speed track bikes, we've measured efficiency in the range of 98%; for triple-ring MTB drivetrains we've seen efficiencies in the range of low 90's up to 96%, depending on the ring-cog combination. If you're putting out 250 watts at the crank on a steep hill, that's like 10 watts difference, which is, um, a drag.
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
I wasn't really thinking of the extreme ends of the drivetrain spectrum or even differing efficiencies across the cassette and chainrings in the same drivetrain. I was thinking more about the effect of changing the size of the chainring and cassette gear for a given gear ratio in the same drivetrain - related back to the OP's question. i.e. would a 52/19 be significantly more efficient than a 43/16 on the same chain-line?
I just looked it up, I gave some data and analysis in this thread several years ago. You may have to scroll down a bit. In that thread there are also links to some articles on drive train efficiency that appeared in the IHPVA journal.
Liked 4,862 Times
As in all things, it depends on what you mean by "significantly."
My idea of "significant" would be around 2.5% i.e 5W difference at 200W output - but that's obviously completely arbitrary. I expect the OP would not be looking for the odd Watt here or there in this analysis.
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
Hmmm. Can you see the image in post #12 in that thread?
But you're right, I didn't post a link to the actual data used to make that chart. I just looked, and if you want I can give you a link to the raw data files. As an oddity, I see that yesterday was the 14th anniversary of when the data were collected. Must be a winter thing.
The image file is here.
The original SRM file is here.
The original PT file is here.
Quoted: 790 Post(s)
Liked 348 Times
The pedal cranks make one revolution for every 2.7 the rear wheel makes, the cranks are the first mechanism in the driveline of the bike, so you put them first. Just as in an automobile with a 4:11 to 1 rear axle, the driveshaft, which is before the rear axle, turns 4.11 times for each revolution of the rear wheels. So you are 100% wrong.
Liked 2,568 Times
Likes For ThermionicScott:
Liked 4,862 Times
Quoted: 790 Post(s)
Liked 348 Times
I always clean the derailleurs on my multi-speed bikes, I think it is one of the most neglected areas on the average road bike, and those little wheels like to gum up. if anything does.
My coaster-braked single-speeder probably has a lot of drag from the grease-packed rear hub and braking mechanism, the rear wheel does not like to spin as easily as a freewheel mechanism, but after a breaking-in period it seems very loose and free and I don't think it has any more penalty than a derailleur system. If my health holds out maybe I will get to test it around a known circuit with the 2.7 gearing and see if it gives the same average speed over distance as my old 70s road bikes.
A clydesdale rider like myself, who is well over six-feet tall and weighs over 200 pounds, can use longer pedal cranks if anyone can. I have tested a lot of bikes in a short period of time over an old level TT course for average speed and the fastest times always come from the bikes with the longest pedal cranks. With the long cranks a rider pedaling at their top cadence can either hold the same gear up a grade easier than with shorter cranks, or on the level can possible hold a gear higher than with shorter cranks for a longer period of time. Big, long heavy legs are just harder to spin higher cadence with, but the longer cranks will let a big and tall rider have more torque and the same power at a low cadence, as a small, lighter rider will at a higher crank rpm with short cranks. It is no different than getting power from an internal combustion engine where rpm x torque = power. If you can not get the rpm, a longer stroke can make the same power at a lower rpm.
Liked 4,862 Times
Crank length really comes down to personal preference based on your stroke length, but there is no inherent advantage to running longer cranks - especially on a multi-geared bike where you can manipulate torque vs cadence at will. However, there are several potential advantages to running shorter cranks e.g. allowing a more aerodynamic position and less demanding on your range of joint articulation. I've discussed this with two very experienced fitters and they both advocate relatively short cranks, even for tall riders.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
While I'm not a fan of GCN the did a video about this not too long ago and video does show the difference in crank length in relation to pedaling dynamics. <br /><br />At least I thought it was neat
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
There is no doubt that for instant acceleration, just upping cadence is the way to go.
I have used all the crank lengths.
So going from 165 to 180 is 9% diff. At the same road SPEED, 180 will do a 91 cadence at say 100GI, while the 165 will have 100 cadence with 91 GI.
When you calculate the sum of foot travel on the 2 circumferences, the total will be exactly the SAME. Foot speed is exactly the SAME. What is gained in FORCE is LOST in distance. Simple physics 101. FACT.
I had to replace my 180 mm White Ind. crank because the stump was too thick for my chaincase and their rings are stupid 3/32".
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Le Crocodile
Quoted: 370 Post(s)
Liked 787 Times
No, the woman's record was in the 90s--see:
https://www.cyclingnews.com/news/ell...speed-concept/
"Van Dijk is reported to be running a 58-14 ratio to allow a cadence of between 93-97 RPM over the duration of her attempt."
Tragically Ignorant
Liked 9,098 Times
His range was 100-110, btw, which pushing a big gear non-stop for 1 hour is significantly faster than 93-97. The middle of those ranges is exactly 10 rpm apart.
Tragically Ignorant
Liked 9,098 Times
That's absurd. X% increase in the distance of a single revolution is X% regardless of the height of the rider. Your comment is the one that's meaningless. Your point may go to comfort, but it has nothing to do with speed.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Larger riders have a smaller relative advantage on level ground, since the increase in frontal surface area scales with an exponent a slight bit less than 0.7.
Otto
Likes For ofajen:
