Frame Pump
Frame Pump
Old 08-24-22, 04:37 AM
Colorado Kid
Quoted: 358 Post(s)
Liked 136 Times in 82 Posts
Frame Pump
I took the long way home yesterday and I had a flat. No problem, I though. I change the tire/tube and started to pump up the tire. Nothing. The pump wouldn't work.. What is the best frame pump on the market?
Colorado Kid is offline
Old 08-24-22, 09:15 AM
pdlamb
Quoted: 2604 Post(s)
Liked 1,933 Times in 1,213 Posts
A new pump? A pump that's been maintained, i.e. the O-ring has been oiled periodically? Not just trying to be sarcastic; the problem is any pump that's infrequently used may have seals dry up and shrink, and then they don't seal any more.
I've been a fan of the Topeak Road Morph for years. Not quite a frame pump, though it mounts on the frame. It pumps well for 10 years or so without any maintenance.
pdlamb is offline
Likes For pdlamb:
Old 08-24-22, 10:31 AM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,931 Times in 2,556 Posts
The pumps that are a joy to use and are very reliable are the Zephal HPX pumps. Full sized (they come in four lengths) to fit under top tubes or in front of seatposts. Many run them along the left seatstay on modern CF bikes. 90 strokes will get most road tires to full pressure, not just "enough to get home". 120 psi is easy. They require close to no maintenance and replacement gaskets are available. Company is going nowhere. They've been making those pumps and their very similar predecessor for 50 years. I've been using the HPs since 1973 and have two on bikes now. The HPXs started around 20-25 years ago. Biggest difference between them is that on the HPX, yo can lock and unlock the handle spring so when you pump, you aren't working against it. That and the HPXs are black, not silver unless you get the silver "Classic"r.
Those HPs were my only pumps for years; one on each bike. I did all my racing with just those. (Yeah, at some races I had the luxury of someone putting a floor pump in my hands; sometimes even with a gauge!) Racing tires were thin latex tubed and got pumped from scratch every time.
79pmooney is offline
Likes For 79pmooney:
Old 08-30-22, 09:20 AM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 464 Times in 365 Posts
I have 3 Topeak road morphs, one older and two newer models. All work well. One is on my road bike, one on my commuter, and the third was to replace the older one but realized I just didn't need it. I've put the third on various other bikes at times. What surprised me is that when I went to use the one on my commuter (I've retired but still use this bike to get around) I had never changed it over to presta valves, which means I'd never gotten a flat in the three years I had it with me! Now of course I've jinxed it.
zacster is offline
Likes For zacster:
Old 08-30-22, 11:18 AM
Trueblood
Quoted: 95 Post(s)
Liked 50 Times in 29 Posts
Anyone have experience with the Uniche pump? - https://www.amazon.com/dp/B01AUHOY2C...ing=UTF8&psc=1
Has a pressure gauge built in. Definitely more work than a Zefal HP, but seems to have decent reviews on youtube. For frame pumps, Zefal is hard to beat. There are other options if you want something smaller.
Trueblood is offline
Old 08-30-22, 11:42 AM
surak
surak's Avatar
Quoted: 878 Post(s)
Liked 726 Times in 436 Posts
Depends on whether you need a high pressure (road) or high volume (MTB, really wide city/touring/urban) pump.
High pressure the Lezyne Road Drive is excellent. Lots of good reviews for the Silca Tattico and Topeak Road Morph, although I found the latter confusing to use when I borrowed it once before I bought the Lezyne.
I don't have much experience with high volume minipumps but was just researching them for my new MTB. There are good reviews for the one I just ordered: Lezyne Pocket Drive, and also for the OneUp EDC and CrankBrothers Gem.
surak is offline
Old 08-30-22, 11:56 AM
RB1-luvr
I don't know.
RB1-luvr's Avatar
Quoted: 317 Post(s)
Liked 853 Times in 446 Posts
Road Morph ftw.
RB1-luvr is offline
Old 09-05-22, 11:04 AM
grolby
grolby's Avatar
Quoted: 288 Post(s)
Liked 86 Times in 60 Posts
Boosting this. If you want a true frame pump, nothing else will do. Topeak Road Morph doesn’t even come close to a Zefal HPX. Full-size frame pumps have gone out of style, but not because there’s anything available that replaces their function. If you want speed and light weight, get a CO2 inflator and a couple canisters. If you want 100% reliability and unlimited air, get a Zefal HPX.
grolby is offline
Old 09-05-22, 11:12 AM
raqball
raqball's Avatar
Quoted: 377 Post(s)
Liked 221 Times in 121 Posts
Just do some research and read reviews on any pump you are considering. I generally just use Co2 cartridges but I do have a Bontrager Air Support HV frame pump for emergencies and it works fine.
I generally only carry one tube, one Co2 and Park GP-2 patches for emergency use if I get more than one flat on a ride.
raqball is offline
Old 09-16-22, 12:04 PM
blingshock
I've used the Topeak Pocket Rocket to replace roadside flats a bunch of times and that has not given me any issues (road bike tires)
blingshock is offline
Old 09-18-22, 05:55 PM
Gear_Admiral
Gear_Admiral's Avatar
Quoted: 24 Post(s)
Liked 15 Times in 9 Posts
Lezyne Micro Floor HP
https://ride.lezyne.com/products/1-mp-mfdr-v204hp
It has a holder that screws on the frame without blocking anything (pump is held offset), the thing screws onto the valve (better seal than a a
squeezing end) and it has a pull-out panel to step for leverage and work like a small portable floor pump.
I hate the super small ones you hold in two hands and work with a vulgar rhythmic motion.
Gear_Admiral is offline
Old 09-24-22, 03:28 PM
Joseph Williams
Frame pumps? I don't know about those. People now a days tend to be using these much lesser. I'm not sure but aren't there CO2 inflators going about the market? I'd rather use those instead of a frame pump. Frame pumps just doesn't sit right with me.
Joseph Williams is offline
Old 09-24-22, 04:06 PM
79pmooney
79pmooney's Avatar
[QUOTE=surak;22629681]Depends on whether you need a high pressure (road) or high volume (MTB, really wide city/touring/urban) pump.
I don't have much experience with high volume minipumps but was just researching them for my new MTB. There are good reviews for the one I just ordered: Lezyne Pocket Drive, and also for the OneUp EDC and CrankBrothers Gem.[/QUO NTE]
The Zephal HPX isn't design for high volume tires but it does rather well anyway. Not a hardship to ride 38c tires to the gravel, drop the pressure to almost nothing then pump back up to 70 psi to get home. So, again, put one of these on each bike and you're done; ready for anything. Pumping tires is so easy it's simply not a big deal. Nightmare ride with a half dozen or more flats? Yes, tubes, tires, patches may be a huge issue but getting sufficient air in won't be.
Old 09-25-22, 12:21 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 3126 Post(s)
Liked 2,105 Times in 1,369 Posts
I have a Mountain Morph. I had a heart surgery and for a while my chest couldn’t do mini pumps, so I needed the foot rest,. Only disadvantage is it’s huge. Road Morph is just as long but smaller diameter for higher pressure.
Darth Lefty is offline
Old 09-25-22, 02:05 PM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 986 Post(s)
Liked 880 Times in 527 Posts
I have Silca and Zefal frame pumps and like them. Unfortunately they don't fit on some of my bikes.
Moe Zhoost is offline
