Cycling Computer for a Brompton
I suppose that all (most) wireless cycling computers will work with 16" wheels, but I'm wondering if any are more optimized or more accurate than others for my Brompton. Do smaller wheels present problems that full size wheels don't encounter? I don't want a Garmin or other GPS stuff. Just basic speed and distance would be fine.
What do other Brompton riders use?
Thank you.
Thank you.
To be on the safe side you could measure the actual distance and check the datasheet of the desired computer.
Quoted: 3243 Post(s)
Liked 2,091 Times
Any GPS, Bryton, Hammerhead, Wahoo, Garmin will work. They don't care about wheel size, they determine GPS position, use a stop watch to determine speed, shows you the results. GPS app such as RideWithGPS will do the same as an app on a phone,
Palmer
Quoted: 1671 Post(s)
Liked 1,828 Times
LED headlamps can mess with wireless computer signals.
We've been very satisfied with the Xoss G on our 16" trifolds.
I wander why you wouldn’t consider GOS stuff, because of costs? I use Garmin GoS computers to track distance, it exports data automatically and it can be also synced automatically to other apps which will allow you to monitor total distance for maintenance purposes if that’s what you’re looking for.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 274 Post(s)
Liked 244 Times
Then when it come to accuracy with older device (like my fenix 5 plus manual mode), the best is set 2 marks 10mm apart , align the valve with the 1st mark and then count the number or rotation needed to reach the 10m. Or, align the valve, count 5 rotation, mark the valve @ rotation 5 and measure the distance.
Once you have the distance per rotation, add it to the sensor setup in the machine.
But, most of GPS equipped devices (fenix 5plus in mode auto or edge 530/130plus) will disregard the speed sensor data for 1K but would still count the number of rev. After that 1k, it give a message saying the speed sensor is calibrated and switch to speed sensor reading (useful in tunnel)
Quoted: 274 Post(s)
Liked 244 Times
Thank you.
Thank you.
Quoted: 8 Post(s)
Liked 9 Times
On my Brompton, I recently replaced my wired bike computer with a GPS type computer (COOSPO Bike Computer Wireless GPS, Bike Speedometer). This model allows me to switch off GPS, so the battery lasts forever. I use this setup to simply monitor speed and cadence via two ANT sensors. Due to the range and quality of the ANT sensors, this works very well.
Quoted: 8 Post(s)
Liked 9 Times
The circumference of the Brompton wheel is usually between 1.27 m and 1.30 m depending on the tire. This should get you close to within 1 or 2 %. If you go for a ride and montior the GPS distance, you can compare the two and slightly adjust the circumference of the tire, so that everntually both distances agree.
