If you will lie about something small.... A Salsa Story
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,438 Times
In the end. regardless of what the manufacture and shop did or did not do, it is up to the rider of the bicycle to insure that all is in good working order, and everything is attached, connected is an appropriate and safe manner. The OP's user name gives a bit of a hint on what his perspective is. Not saying it is wrong, it is just opinion.
Likes For delbiker1:
I believe that I may have been unclear. The bicycle was professionally assembled and checked by a high quality bicycle shop of high regard. They rode it and I rode it. There was no issues to be detected in casual riding it around. It wasn't until it was "out in the wild" that the lever slipped. It didn't come off or dislodge. It slipped and remained loose. You can debate or blame place all you want but the fact remains the the factory incorrectly assembled a component that failed in use.
As for the cable rubbing the head tube, this is a problem specifically documented to drop-bar journeyers in several reviews that I read and watched prior to purchasing the bike. Perhaps this is the price to be paid for having the cables under the tape. I don't know. I do know the this is the only bike that I have had that has had that issue. I don't think that it is unreasonable to think that would be something that a major company would notice and eliminate over time.
And, again, these are just minor quibbling that caused me to reach out to the company.
The issue is:
Jared, and by extension, Salsa, LIED TO ME. He told me that the NEVER put protective vinyl on ANY bike. They put two pieces of it on MY bike.
"was that frame heat treated correctly"? Why Yes, yes it was!
"did you adjust Robot 12 to spec so the handlebars don't fall apart"? Yes we did!
"did you dump that toxic waste into the river"? No way!
who knows.
The issue is:
who knows.
2023 Salsa Journeyer
2023 Rad Rover 6
1980ish Raleigh Marathon (Vintage Steel)
2006 Trek 820 (Captain Amazing) RIP
2010 Specialized Tricross (Back in Black)
2008 Specialized Roubaix RIP
"I'm built like a marine mammal. I love the cold! "-Cosmoline
"MTBing is cheap compared to any motorsport I've done. It's very expensive compared to jogging."-ColinL
Rides:2023 Salsa Journeyer
2023 Rad Rover 6
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 570 Post(s)
Liked 773 Times
Me at 11 years old - picked up my nice custom Skyway TA BMX bike from a local shop that did a repair that I couldn't handle. I built the bike up myself, an 11 year old kid & it worked great. Pro bike mechanic, not so much.
Rode the bike home from the shop, hit a jump... and to quote Ron White "the wheels fell of, they fell the bleep off. I guess that mechanic failed lug nut class". That hurt bad... I walked back into the shop a bloody mess, walked out with a fixed bike and a very nice new set of freestyle rims - I think they were Z Rims.
Lesson learned; life lesson learned - I don't trust any bike shop to do anything right. The shop may have a decent mechanic or two, and they may have three monkeys turning wrenches.
Quoted: 3241 Post(s)
Liked 2,512 Times
I'd suggest some pie or ice cream, maybe both. That should help with the situation.
Likes For seypat:
Expired Member
Quoted: 3683 Post(s)
Liked 5,447 Times
Moving along toward resolution, note that some like the brifter to be tight enough to be secure during normal use but not so tight that it won't move if the bike is dropped on the bars. Investigate how it attaches so you can tighten it to your preference. It's worth learning how your bike is put together so you can fix stuff like this yourself, even in the field if needed. The cable rub is common, depending how the stops are configured and even the size of the bike. As mentioned, tape and or rubber grommets. That's a nice bike and a great price with the current sale!
Quoted: 4420 Post(s)
Liked 4,873 Times
The issue is:
who knows.
The issue is:
who knows.
I also don’t think Salsa lied to you about the cable protection. Far more likely your misunderstanding. As I read it, they said that they don’t apply any protection against cable rub. Chainstay and downtube protection is not for cable rub. Some manufacturers do apply protection patches for cable rub and some don’t. Salsa clearly don’t, which is what I believe they were telling you. A keen shop could have easily spotted the potential for cable rub and applied their own protection patches. But they didn’t bother.
For me and pretty much everyone reading this thread, your bike shop appears to be a bit slack and you are putting far too much blame on the manufacturer, even if they didn’t pay much attention to detailing like cable runs. At the very least, the shop should have checked your brake clamps properly in the first place.
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,899 Times
I will be sorry to see Salsa/Surly go under as I am sure the lack of your pending future purchases will surely sink Surly..
Quoted: 827 Post(s)
Liked 1,660 Times
It sounds more like a case of waaaa, waaaa, waaaa.
Quoted: 6199 Post(s)
Liked 4,816 Times
I'm just having trouble believing that I wouldn't have noticed a loose brake lever and tightened it before doom and gloom happened.
Likes For Iride01:
Quoted: 3957 Post(s)
Liked 7,310 Times
The issue is:
who knows.
The issue is:
who knows.
The entire story about the big LIE is just so out of proportion and not even worth talking about it.
Likes For trailangel:
Quoted: 1104 Post(s)
Liked 1,825 Times
QUIT CRYING AND BE GLAD YOU DON'T HAVE A REAL PROBLEM.
If this is the attention you give something small; I suggest you do what you can to avoid a cancer diagnosis.
On my first bicycle from a local LBS, on the first ride the handle bar fell out on a turn. I had no tools, I walked home and took it back for a refund and went to another LBS. The second LBS was wonderful and I have used them since. I always have said it was divine providence as my second bicycle has been a dream.
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 179 Post(s)
Liked 169 Times
Another reasonable possibility is that Jared may not be aware that they put protective film on some bikes in their line or have in the past. Otherwise he was right that the shop was responsible to check all fasteners prior to delivery to you. But, yeah it's more fun to be mad at someone than to chill and go for a ride. Maybe in time you will enjoy your new bike.
FWIW a few years ago it took my LBS months to get a frame replacement for my oldest son's Allez. The new frameset came with little oval clear stickers to protect the headtube where the cables might rub. It was up to the assembler to place them on the frame during or after buildup. Housing rub is a known "feature" with drop bars and under tape cable routing.
Sir Mark, Knight of Sufferlandria
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
To echo what a bunch of folks have already said...
1. It was the bike shop's responsibility to check everything on your bike for proper and safe operation. They are the double-check after factory assembly. You are correct that the lever was possibly improperly mounted at the factory, but it is the shop's responsibility to catch that mistake.
2. Jared @ Salsa didn't lie to you. He was responding specifically to your issue, which was cable rub. To his knowledge, other manufacturers don't install vinyl protectors, either. His knowledge may or may not be accurate.
3. Cable rub happens on bikes with internal cable routing. All of my bikes with internal routing have this condition. One of them was originally built with rubber bumpers on the cables, the others were not. If this is an issue for you, there are options to mitigate it. This is up to you to deal with.
Quoted: 1110 Post(s)
Liked 1,204 Times
mr,grumpy how do you like the Apex 1? I got a Journeyer Microshift Advent 1 9 speed (from REI - assembled very well I must say). I really like the Microshift shift lever design and ergonomics. I've posted before on other threads, I think it's a better design than Shimano, and as good (for me) as Sram (which has been my strong preference until now).
I bought the Advent 1X 9 speed instead of the higher cost Sram and Shimano options mostly because of cost. We wanted cheaper/simpler bikes than our high-zoot titanium, AXS Etap, hydraulic brake gravel bikes to keep with our RV which we store in another state. We're very happy with the Journeyers and I'm very happy with the Microshift stuff.
I've said enough - as have we all - about your original complaint (let it rest guys!). Please think about the unanimous opinions stated and most of all, enjoy your new bike.
Quoted: 1461 Post(s)
Liked 1,486 Times
Serious question here - do new bikes really come from the factory to shops with shifters/brakes attached to the drop bar? Are they pre-wrapped too?
I've always assumed that shops were installing shifters and cables on new bikes.
At a minimum, I'd expect my shop to check all the bolts before sending it out the door. They're still assembling other things on the bike, so this doesn't seem unreasonable to assume.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I always thought that bike shops received bikes to be assembled in boxes and then it was the shops responsibility to assemble. Have never seen ready to go bikes wheeled off UPS trucks (or any other) and set on the sales floor. As far as culpability, I would go with the shops’ negligence. Salsa gets a pass.
I also don't care about protective tape. By the time I change the stem length and height, adjust the bar angle, and adjust the lever angle, the cables rub in a different place anyway and any tape applied at the factory is useless. Cable rub happens.
It's like riding a bicycle
Randomhead
Liked 3,701 Times
Cables are installed. The handlebars are loosely fastened to the top tube.
As far as checking bolts, I imagine this varies by shop.
Many bikes come with some kind of protective tape in the parts bag, but it's for unnamed spots on the bike. I'm pretty sure this usually goes in the trash.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,923 Times
I would not assume that the manufacturer builds the bike all the way up to rideable, then disassembles it minimally to put it in a box, unless it's being sold direct to consumers. So, yes, it is up to the SHOP to assemble the bike, set up and adjust the brakes and shifting, and make sure every fastener is properly torqued down.
And, you know, the best shops make the occasional error. And to claim they've built thousands of bikes and never made such an error? How in hell would you even know that? Did you ask their thousands of customers? Ever think that maybe the rare mistake got handled like yours, with the shop fixing it for free and sending you back on your way?
Quoted: 1821 Post(s)
Liked 1,697 Times
The answer to this is..... it depends. I have assembled hundreds of bikes from dozens of manufacturers. I have seen brake levers not installed on handlebars. I have seen the levers installed but the bars not taped. I have seen bikes come in that have the bars fully taped ready to go. My son's road bike arrived with the hydraulic brake hoses not connected. I used to work for a bike distributor whose bikes came in as bare frames, the customer could then order any build kit we stocked and the shop would build the bike from a bare frame. I certainly would not expect the manufacturer to install frame protection to protect the head tube from cable rub in advance, depending on setup, the rub area could change from one build to another. When I received my Canyon Grizl, there was no frame protection installed, but it was supplied with the parts needed to assemble the bike. I have a couple of road bikes that don't have any protection on the head tube because none is needed, they are both over 15 years old with no hint of cable rub damage in that area
Likes For alcjphil:
Quoted: 18424 Post(s)
Liked 15,582 Times
Loose brake lever is a shop fault. They should have checked it pre-delivery. They obviously didn’t in this case.
Cable rub is also a minor shop issue. A really good shop would have anticipated this (pretty much all bikes with cables are prone to rubbing) and applied clear patches as appropriate. They obviously didn’t go into that level of detail here and IME most shops don’t.
The reality here is that your bike shop is not very thorough with their pre-delivery checks.
As for the patches, yes again. I’ve never purchased a bike with them. (I can imagine the irate purchaser receiving a bike with such a “blemish.”) A good shop will ask you if you want them.
Likes For indyfabz:
Quoted: 1581 Post(s)
Liked 1,192 Times
The (non-)issues the op is whingeing about have been well dealt with in this thread. I'll simply make one other point: the op (see post #28) was very well aware prior to his purchase that 'cable rub' happens on this particular frame:
"As for the cable rubbing the head tube, this is a problem specifically documented to drop-bar journeyers in several reviews that I read and watched prior to purchasing the bike."
If the op does not like the appearance of 'cable rub' all he had to do was ask his lbs to provide him with a sheet of protective patches -- I've no doubt they'd have some to give away -- and apply them for him should he not be inclined to undertake this very complex task himself.
All three of my most recent bicycles had/have some cable rub. I am by no means mechanically gifted -- far from it -- but even I managed to apply patches of protective film successfully, once I had dialled in my fit etc. As another poster pointed out, these kinds of patches would be utterly useless if factory installed -- unlike protective film on a downtube or chainstay.
Likes For badger1:
