Tubeless rim tape width
Old 07-03-21, 01:02 PM
PoorBob
Quoted: 38 Post(s)
Liked 8 Times in 6 Posts
Trying to figure out what the best rim tape size would be.
My rims are 21mm internal width and 25mm external.
Thanks,
Bob
PoorBob is offline
Old 07-03-21, 02:53 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Tubeless tape should span the whole width from sidewall to sidewall on the inside. Does your 21mm mean between the beads or the sidewalls?
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 07-03-21, 05:07 PM
masi61
masi61's Avatar
Quoted: 1163 Post(s)
Liked 442 Times in 315 Posts
21 mm bead to bead might require 23 or even 24mm to account for the curvature of the well.
masi61 is offline
Old 07-03-21, 06:37 PM
PoorBob
Quoted: 38 Post(s)
21 is bead to bead.
So the tape should go bead to bead? No gap or 1mm- gap on each side?
I suspect I could take some painters tape to get the width including the curvature or valley in the rim the pull it off to measure the true distance of surface.
PoorBob is offline
Old 07-03-21, 07:04 PM
ThermionicScott
Adding a millimeter per side -- perhaps a smidge more -- seems like a good rule of thumb. Pacenti recommended 21mm tape for my SL23 and Brevet rims, both with a bead-to-bead width of about 19mm.
RUSA #7498
Old 07-03-21, 07:23 PM
well biked
well biked's Avatar
Quoted: 140 Post(s)
Liked 162 Times in 89 Posts
Something like 2-5 mm wider for the tape than the internal width of the rim, depending on the rim. Example (and this is obviously a very wide rim example): For WTB i45 (45mm internal width) rims, WTB recommends their 50mm tape. The extra 5mm of tape width is used for the contour of the rim channel.
well biked is offline
Likes For well biked:
Old 07-04-21, 07:05 AM
Pop N Wood
Quoted: 668 Post(s)
Liked 529 Times in 355 Posts
Trying to learn here. I see lots of recommendations saying it only needs to cover the spoke holes. Putting tape on the channel edges cuts into possibly already tight clearance for the tire.
Does everyone do it this way?
Pop N Wood is offline
Old 07-04-21, 07:50 AM
Crankycrank
Quoted: 837 Post(s)
Liked 1,061 Times in 745 Posts
What make and model are your rims? The mfr. may have a recommended width on their website.
Crankycrank is offline
Old 07-04-21, 04:11 PM
ThermionicScott
Covering the spoke holes is important, but you generally want the tape to extend under the tire beads to ensure everything seals well. It's also a part of the tire fit, increasing the rim diameter slightly so that the tire is less likely to come unseated if you have a flat.
The tight fit of the tires is a feature, not a bug.
RUSA #7498
Old 07-04-21, 05:03 PM
Cooperator
occasional marmot
Cooperator's Avatar
Liked 6 Times in 3 Posts
Yes. It is best for the bead of the tire to compress the tape against the rim. That will create the best seal.
Fwiw I've found that cheap 1" Gorilla Tape from the hardware store to be an excellent width for 19-21mm internal width rims.
Cooperator is offline
Old 07-05-21, 06:51 AM
Pop N Wood
Quoted: 668 Post(s)
In my grand experience of setting up one set of wheels tubeless I had trouble with the tire sitting on the tape causing the tape to unseat when the tire was being seated or removed.
The wheels came with I think Stans rim tape, which I tore every time I tried to seat it into the spoke channel. Went to gorilla tape, which like you note was a perfect bead to bead width and super easy for a noob to work with. This spring I pulled the gorilla tape and went with a tape cycocommute recommended. The gorilla tape pretty much came off when I pulled the tire. The new tape goes the full width of the channel but is much thinner and a slicker surface than the gorilla tape, so hopefully no more worries about losing seal on the tape with trailside repairs.
Likes For Pop N Wood:
Old 07-05-21, 05:56 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2762 Post(s)
Liked 2,537 Times in 1,433 Posts
I used to be one of those folks who thought it only needed to cover the spike holes.
I was wrong.
Kapusta is offline
Likes For Kapusta:
