Converting my fat bike into MTB without replacing Rims
Adil
Bikes: Land Rover foldable Fat Bike 20 Inch Rim Size
I want to replace my fat bike tires 20x4 inch size with normal 20x2.5 inch MTB tires but could not afford to replace the wide rims with narrow rims. Few of the spare parts shop onwers told me that you can do it easily and told me that they have replaced several fat bike tires with normal MTB tires without replacing the rims on their customer bikes. Is it possible to install narrow tires on wider rims.
Quoted: 2236 Post(s)
Liked 1,314 Times
Short answer. Probably not.
Long answer. Even if the tires would fit, your bike was designed with a bottom bracket (bb) height optimized for 20x4 tires. Assuming that's what came with the bike. When you replace those with 2.5 tires you will drop the bb significantly closer to the ground which will cause pedal strike when you turn corners.
Quoted: 6193 Post(s)
Liked 4,809 Times
I wouldn't mess up the bike to convert it to something it wasn't intended to be. Maybe if it was an old POS.
You'd be doing yourself a favor to just get another bike that is already a mountain bike whether new or used. Sell the other if you have no desire for it or just give it away to someone.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
If these shops say they can and have done it, then let them do it on yours. If it fails, you can hold them accountable.
Likes For Rolla:
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
2.5 tires will probably mount up fine. Guys were running them on Surly Pugsleys years ago. If you just want it to be faster rolling, switch just the rear out first. My fatbike has had a 27.5 x 2.5 wheel and tire on the back and 26 x 4 in the front for over a year.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
What is the rim width? Internal width, more specifically?
Likes For Kapusta:
Liked 1,314 Times
it is very common for fat bike owners to have a second wheel set for summer use, using a 29r rim and mtb tires (26×4+ for snow). Your described mullet set up (27.5/26) follows that thinking. Did these Pugsley owners do that? or mount 2.5 mtb tires on their 26x4" rims.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12771 Post(s)
Liked 7,687 Times
2.1" tire on a 45mm rim is my record. It worked out just OK but it looked kinda
That's more of a plus size rim than fat size though.
Quoted: 186 Post(s)
Liked 234 Times
This person wants to fit the smaller tire on the same fat rim.
2.5 hookworms work fine on fatbike rims.
Bikes: everywhere
Liked 7,687 Times
Liked 1,314 Times
I think the easiest thing is just for the OP to buy a cheap new or used mtb tire or two and try to mount to see. This isn't a very expensive experiment in the scheme of things. So far they haven't listed their rim size so I'm a little jaded as to their effort level.
Quoted: 186 Post(s)
Liked 234 Times
Hookworms are better off road than most give them credit for at first glance. Every week or so at my local trailhead some idiot looks at my bike and says those tires won't work out here. I've been riding these tires for about 10 years, and these trails for about 20, what do I know?
Likes For c_m_shooter:
Quoted: 883 Post(s)
Liked 823 Times
How wide are the rims? I switched 4" tires to 2.3" with neither it looking untoward or causing handling/mechanical issues, but the rims were only about 3.5" wide AIR.
Advanced Slacker
Liked 2,537 Times
If you say it works I believe you, but that sure does not sound right.
