Ebike battery charging
Can someone please clear up and ongoing discussion within our cycling group which is - What do owners of ebikes believe is the best charging regime for longevity of the battery.
- After every ride regardless of battery drain
- When I drops to 75% charge
- When it drops to 50% charge
- When it drops to 5/15% charge
Bikes: Rans Dynamik
Quoted: 9 Post(s)
Liked 16 Times
According to my research
...it is total time with the battery at 100% SOC that hurts longevity. I charge to 85% after every ride and only top off right before a longer than usual ride.
Bikes: 2022 Priority Coast, 2022 Priority Current
Quoted: 175 Post(s)
Liked 137 Times
I charge from 15% to 100% or every night when commuting. When not commuting once a week. I store the battery inside of my home when not riding.
Likes For alloo:
Quoted: 340 Post(s)
Liked 276 Times
I recharge our batteries after every ride, and charge to 100% when we are using our bikes every day. When I know we're not going to use a battery for a week or more, I'll leave it half charged.
I've not seen the studies, but I suspect that running a battery down to 20% before recharging is more stressfull for life than recharging after every ride. It's also less stressful for my range anxiety to go out with a 100% charged battery vs one at 80%, even,for a shorter ride.
The controversy remains. Yes, there are those who think some wild regimen will make their battery last for a hundred years but it just wont happen.
Treating your battery like a lead acid battery and having it continuously on the charger? BAD. No controversy over that.
How low can you take it? I have totally discharged batteries on rides and charged them right back up with no seemingly ill effects. I will typically plug a battery in when it is low, or top it off for a long ride when its below full. The only real caution is if you run a battery down and forget about charging it for a month or two it may not charge because of the BMS seeing a lower voltage than expected. Thats the only bad thing.
Get out and ride your bike. Charge it up as needed. Enjoy the ride, and forget bout silly controversies.
Likes For speedy25:
Quoted: 883 Post(s)
Liked 824 Times
Several years ago I read an article about Tesla (who were using 18650 batteries similar to the ones in our kits then) that stated they were able to give an eight-year (or whatever) warranty on their batteries by not allowing them to be charged past 80% nor be discharged below 20%. That's good enough for me. I only charge to 100% if it's going to be a long ride. Gave away my last battery (52V, 10 ah) after five perfect years and it was still as good as new (qualitatively).
Likes For 2old:
To some degree, things depend on the charger. We don't usually know, for example, to what voltage our chargers take the battery, nor do we know how our battery charge indicators are calibrated. It's possible that a particular brand of battery, bike and charger says 100% when the battery is at 80% like a Tesla.
Lots of unknowns. Personally, I just plug in when I get back from a ride. Range anxiety is not something I want to deal with. I have a Trek/Bosch system, and have not read anywhere a single comment about battery failure. YMMV, especially with low cost generic stuff.
Likes For klevin:
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
Do commercial ebikes (as opposed to DIY bikes) have this kind of option for charging or do you just have to watch the time carefully?
Likes For skookum:
I think that is a common tactic among electric car manufacturers. Over build the batteries in terms of capacity then charge only to 80% and make sure they can't discharge more than 30%. That greatly increases the number of cycles you can get out of your battery. Some chargers can be programmed to do that.
Quoted: 340 Post(s)
Liked 276 Times
An electric car can afford the weight penalty to overbuild the battery, since it's very hard to replace them. I suppose an electric bike could do the same, since so many folks are loving their 75 pound bikes, Cannot argue with the science. Running a pack between 80% and 30% will maximize battery life.
Still, unlike cars, bikes do not have battery heaters for cold weather running. Unlike smart phones, bikes don't usually carry temperature sensors to inhibit charging when the battery is below 40F. You could follow a strict charging regimen and still screw up your battery recharging it after a sunny winter ride,
For all we know, the BMS in branded battery systems could already be limiting useful capacity to extend battery life. Since I have a Bosch system, I'll ask on a different forum to see if anyone knows. There's a Bosch guy there regularly.
Quoted: 883 Post(s)
Liked 824 Times
Smart chargers, which we hope are all lithium battery chargers, use voltage sensing, and switch to low current trickle charging at a certain point. No charger could use time as a variable. Perhaps a consumer, based on experience, could do so? But why? Where's the evidence that charging to a certain level, as indicated by the charger or the battery, has any value. Too many unknowns.
https://electricbikereview.com/forum...y-guide.24443/
Likes For mclewis1:
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Does it really make a difference?
Like stated above, OEM vehicle makers - especially with a range extender ICE, used to keep SOC between 30% and 80%. But as battery technology and experience has changed, that has kind of gone out the window. I've kinda scratched my head at this too - if you only use the middle 50% of the battery and the battery can take twice as many charges - well isn't that what you would expect? That would end up with the same amount of miles ridden/driven.
What really hurts is if you go too low on state of charge - something that in my experience can be exacerbated by leaving the battery in freezing temperatures. Leaving it at 100% isn't geat either, but its not the end of the world.
Realistically, I fill it up after every ride (and try not to run it dry).
Old enough, hmmm?
In the real world the battery will handle 70 km of mixed terrain including some 12+% grades. The seller states 55km in the features (https://www.rbsmsports.com/product/r...-adder-e-bike/)
More from the real world; today's ride was 61+ km on a flat course (Rail Trail), at the start of the ride the battery was fully charged i.e. showing 100% and the charger had switched to green. At the end of the ride it still showed 66%.
The odometer has only 670km to show, so it's early days! Over that distance I figured out that matching the PA level to the gear and cadence will most likely result in the greatest distances on one charge.
BTW officially the "Mud Adder" is a e-MTB , but I consider it a good all-round bike for anything from "mild" single track to pavement.
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
Keep the battery charged roughly between 30-80%. The battery will wear out faster when frequently used outside that range.
Likes For Moisture:
Grin Technologies makes the Satiator, generally regarded as the best ebike battery charger in the world. It is programmable for charging up to whatever percentage you like. Their info sheet shows how charging up to only 80% triples battery life: https://ebikes.ca/product-info/grin-...-satiator.html
Likes For Numerozero:
Old enough, hmmm?
Hard data on this topic seems to be remarkably difficult to find. Ditto for real life experience. I asked on a Bosch specific forum if anyone had a battery failure. No replies. Asked for details on their BMS. None available.
The weakness of Grin's charger is that it sees the voltage as reported by the BMS, not necessarily the true battery voltage.
The Satiator was apparently designed as a charger for a wide variety of battery products, rather than as a Bosch specific charger. Unlike the majority of commercial ebike batteries Bosch produces batteries that require chargers with unique pinouts and awareness of the internal BMS, likely for a level of vendor lock in. I don't see that lack of Bosch specific characteristics as a specific weakness in the Satiator product but more of the reality of creating a popular product rather than a vendor focused small niche product.
Likes For mclewis1:
Yes, the Satiator is designed to work with a wide range of battery types, including lead acid. The only way it can do that is to just have a user adjustable voltage limit. That's an OK approach, but hardly the most sophisticated that could be done. I'm sure it's an OK product, but it's not a particularly sophisticated solution to the charging issue, especially at it's price.
Unfortunately, we ebike users live in an information vacuum, with a dearth of hard, factual information regarding best charging protocols for maximum life. Yes, there's a lot of "I think" and "I read somewhere" suggestions. No doubt some of them are accurate, but which?
I have a 52v 14.5 ahr/750w battery in a downtube case. To go along with it I purchased the Luna Advanced charger instead of the basic 2a brick or the expensive Satiator. A few folks question the Luna's build quality but from a feature/functionality point of view it does everything I need. After a long ride I set the charger's switches to 2a and 80% and leave it for a while (I'll turn it off when I notice it's at 80% voltage or hear it cycling). Just before it's next use I think about what I'll need. I might leave my battery at 80% (with my battery that's ~450 usable watts) or if I need more distance I'll turn the charger up to 5a and 100% which only takes a few minutes to get to 58.8v or so (~600w usable). Occasionally (every few months) I'll charge to 100% at 1 or 2a and just leave it for a little while, letting the BMS do it's balancing thing. All very simple and straight forward.
The alternative for me with the way most ebike charger setups work would have been two chargers (2a and more powerful one), an AC outlet timer, and an inline voltage/amp/wattage display. Then it would take a little experience with my battery (noting it's voltage sag and charging characteristics) and some time with those battery SOC charts (modified with a time variable) that I'd refer to each time I charged my battery.
I don't understand why we don't see commercial ebikes coming with either more intelligent chargers or more flexible manual chargers (like the Luna). Well actually I do understand it ... they get to sell more batteries this way.
Likes For mclewis1:
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
I do agree that continously charging to 100% takes something out of the battery.
I follow the "30 to 80%" rule for the most part.
one of things I learned from tesla is that if you have a battery charged above 90% there's no capacity for the regen braking to dissipate energy.
So, ride it down to 30 and charge to 80. Agree that some more information and smarter chargers would be useful.
/markp
/markp
Battery packs have an estimated number of charge cycles in determing their life expectancy. If I charge when the battery pack is at 75% SOC I will be doing so 3 times as many times per mile as if I would recharge at 25% SOC, and I will be shortening its expected life by roughly 66% in the process. This is why I like the approach Specialized took with their Creo bike and the optional Range Extender battery pack. The bike can be programmed with the smartphone app so that the motor first draws down the external battery before drawing power from the battery in the downtube or it can draw from both packs at the same time.
