Need help with replacing 7 speed Cassette on tricolor 600
Old 12-05-21, 05:06 PM
NDL
Quoted: 14 Post(s)
Liked 9 Times in 6 Posts
Hi Guys,
I am currently running a 7 speed hyperglide cassette with a spacer on the 6402 hub (6402 hub came with 8 speed but I prefer my old 7 speed groupset so I added a ring and swapped it to 7 speed back then),
Now it's time to replace the cassette since it's skipping and I've tried replacing the chain but it was still doing it.
The problem is that I couldn't seem to find any replacement 7 speed cassette for it, the common ones I saw online are all starts with 11t, and I heard that the 6402 hub doesn't work with 11t.
So what are my options? Can I use CS-HG200-7 on 6402? CS-HG200-7 has 12-28T.
NDL is offline
Old 12-05-21, 05:17 PM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 2321 Post(s)
Liked 1,348 Times in 805 Posts
I am pretty sure the cassette will fit the hub, with the spacer, but I don’t recall the max cog for 600 RD.
just pay attention to your max chain wrap. https://velobase.com/ViewComponent.a...fd096&Enum=108
https://www.roadbikereview.com/threa...apacity.21443/
Sugar "Kane" Kowalczyk
Bianchigirll is offline
Likes For Bianchigirll:
Old 12-05-21, 05:31 PM
embankmentlb
embankmentlb's Avatar
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 68 Post(s)
Liked 112 Times in 56 Posts
Minimum cog is 13 teeth and max 28 for 7 speed hyper glide.
Uniglide may permit a 12 tooth threaded cog.
eBay will have something.
embankmentlb is offline
Old 12-05-21, 05:47 PM
NDL
Quoted: 14 Post(s)
Originally Posted by embankmentlb View Post
Ebay can be your friend. Minimum cog is 13 teeth
Thanks, so the Minimum cog is 12 or 13? I could only find 12t - "CS-HG200-7" has 12-28T.
https://bike.shimano.com/en-EU/produ...S-HG200-7.html
but nothing on 13t.
NDL is offline
Old 12-05-21, 05:52 PM
embankmentlb
Quoted: 68 Post(s)
but nothing on 13t.
I would look for a Sunrace cassette.
Old 12-05-21, 06:24 PM
embankmentlb
Quoted: 68 Post(s)
but nothing on 13t.
After a bit of research it seems a 12 will fit on some iterations of the tricolor hub. This was a transition era for Shimano and that makes it more complicated. Sorry if I confused things more than I helped. Hopefully someone else will check in.
Old 12-05-21, 09:07 PM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Bikes: Bob Jackson, Wizard, Pegoretti Duende, Merckx ProSLX, Pelizzoli, Cannondale ST, Schwinn Tempo, Davidson Sport Custom, Canyon Endurace, Richard Sachs, Davidson Discovery
Quoted: 1716 Post(s)
Liked 1,558 Times in 657 Posts
12 tooth smallest cog works fine. 11 will not fit.
Plenty of 7 speed cassettes out there, including the HG200.
rccardr is online now
Old 12-05-21, 09:55 PM
NDL
Quoted: 14 Post(s)
Thanks for confirming 11t won't fit, searching through the forums I found a lot of comments said "Plenty of 7 speed cassettes out there" but none of those listed what other models are interchangeable, can you share a few of these 7 speed cassettes out there?
NDL is offline
Old 12-05-21, 10:30 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3497 Post(s)
Liked 1,825 Times in 1,174 Posts
The 12-28T HG200 will work fine.
Pity we don't still have the selection we had a couple years ago...
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 12-06-21, 07:06 AM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Amazon has 12.28 HG200 Tourney cassettes for $21. Hards to get cheaper than that but eBay has a bunch too.
Just get a CASSETTE not a FREEWHEEL. Anything Shimano, SRAM or Sunrace is compatible.
Old 12-11-21, 12:14 AM
Fivethumbs
Quoted: 29 Post(s)
Liked 10 Times in 5 Posts
I've run a 12-28 on a 6400 derailleur with no problems. I've also taken apart cassettes to make a custom cassette.
Fivethumbs is offline
Likes For Fivethumbs:
Old 12-11-21, 12:31 AM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 23138 Post(s)
Liked 6,495 Times in 4,661 Posts
...either this, or I have at times used an 8 cog cassette from Shimano, leaving off the smallest cog.
With the 8 cogger, you're changing the spacing a little bit, I think. But in my applications, it didn't seem to matter.
If you've got 7 speed indexing, you can either run it in friction, or dial out the 8th position with the limit screw, and adjust the indexing to work best in the middle range. This is usually all you need for it to work OK.
3alarmer is offline
Old 12-11-21, 10:58 PM
canklecat
canklecat's Avatar
Quoted: 4386 Post(s)
I'm running a Shimano 8-speed 12-25 cassette on a bike with a 7-speed group. I just skip the big cog and ride the first seven 12-23 cogs. With a 53/39 chainring and our mostly modest roller terrain it works okay... at least when I'm in shape. I haven't been able to ride much for a few months due to vertigo from a persistent upper respiratory inflammation, but when I rode that bike a couple of times in October it was fine even on the most challenging segments of my usual routes with some short-ish grades that max out at around 8%, but average 2%-3% overall.
I have some SunRace 7-speed cassettes with 11T small cogs, mostly in the 11-28 range. They work fine, but I don't care for the somewhat awkward steps around the middle cogs. Doesn't flow as well as the closer spaced 12-25 cassettes. And I don't like 11T small cogs on any bike. They feel grindy. The chain wrap is too tight for bike chain link lengths. The smallest cog I've tried that turns without feeling grindy and lossy is 12T, but I prefer 13 unless I'm feeling really strong and want to try for a PR on a couple of time trial segments. (I haven't felt particularly strong this year and at age 64 it ain't getting any better.)
I'd prefer 12-25, 12-28, or 13-25 or 13-28 in both 7 and 8 speeds, but the cassettes and freewheels I want are still in short supply due to the ongoing shipping slowdowns so I'll make do with what I have for now. That 8-speed 12-25 came with an older Mavic wheelset I bought from a guy back in August or September.
canklecat is offline
