Transferring Vulcanizing Cement
Old 08-22-22, 04:07 PM
tessellahedron
Quoted: 79 Post(s)
Liked 5 Times in 5 Posts
I made the mistake of buying this.
it can't be opened without channel lock pliers, and once open it's virtually impossible not to over apply because the brush has been sitting in cement and is beyond saturated. My options are, spend ten minutes wiping back and forth every time I pick up the brush, or over apply while dripping everywhere. I tried using something else instead of the brush but the stuff I tried didn't work. I've got my eye out for a small brush but how ridiculous.
I dunno about the brush but the cap would have been so easy to design properly. It makes me sick. I can't even fix it by driving a nail through it because it's too thin. Does someone else have an easy fix I haven't thought of? I mean a strap wrench, channel lock pliers, or even your mom's jar opener should all be 100% unnecessary.
what are my opinions for transferring this to another container? I bought blunt syringes for transferring ink. Could I just fill them with cement or would it harden in there? I suspect they're polypropylene. I also have some glass jars, kind of like Mason jars, but maybe that's to much air volume, I dunno.
the little tubes in patch kits usually dry out or leak. I had one leak this morning. Is there a better way to carry this stuff?
I'll never buy another slime product. They obviously sell products they've never even tried to use.
tessellahedron is offline
Old 08-22-22, 05:50 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2747 Post(s)
Liked 3,395 Times in 2,056 Posts
What I use. No problems for years.
​​​​​​https://www.napaonline.com/en/p/BK_7651198
dedhed is offline
Old 08-22-22, 06:27 PM
2_i
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times in 251 Posts
I get that you are unhappy, but not much more. This is a standard type of container for rubber cement in auto industry. You wipe off excess cement from the brush against the opening in the container. For use on the road with a bike, I pour the cement into small glass vials straight from such a container, or, for a cleaner job, I use disposable pipettes. The cement can be diluted with heptane or white gas.
2_i is offline
Old 08-22-22, 06:30 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Transfer it to the trash.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 08-22-22, 06:47 PM
tessellahedron
Quoted: 79 Post(s)
Thanks for the napa link! I didn't know they carried that and it's one of the few stores in town.
Knowing what to search I found a few other options on Amazon and two things proved universally true: they all included a brush applicator, and they all had much larger diameter lids than slime.
so I'm gonna try it in a jar and a few vials and probably just chuck it if it dries out. White gas would be expensive since I don't have any. Is a q-tip a bad idea for applicator? I know it says don't get dirt and oil in the patch but what if I just cleaned my finger and used that?
I guess I'm the odd one when it comes to the brush applicator. Actually I just realized part of the reason it's so maddening is that the opening is so small. I'm gonna hope that's it and buy the NAPA cement next time.
Old 08-22-22, 06:56 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,928 Times in 2,553 Posts
Those little tubes in patch kits - do you use the Rema kits? I've found the caps go back on and tighten reliably and that if I rolled the tube up or squeezed until glue started to come out when putting the lid back on, very few tubes dried up. And many bike shops sell just the tubes and just the patches.
That can in your photo looks perfect for a Cycle Oregon mechanic preparing for 2000 cyclists and goatheads. Or this and maybe my next two lives.
79pmooney is offline
Likes For 79pmooney:
Old 08-22-22, 07:05 PM
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times in 348 Posts
That's the kind of container a heavy equip mechanic would carry in his tool box. (metal-puncture proof) Once you break the bead, you slobber a pantload in there, push in a patch with a bunch slobbered on it and push it all back together. If you're running 10PSI you've over inflated the beast. If you need more pressure, you fill the casing with calcium. For my bikes, I like Elmers in the 8oz container with built in brush. Of course, I now only carry a single tube and do all my patching at home. If I get more than one flat, I'm walking. It's not like I'm in a race.
SpedFast is offline
Old 08-22-22, 07:09 PM
2_i
Quoted: 840 Post(s)
Q-tip is not a good idea as it will leave fibers. Just be more diligent taking off excess cement against the opening. Tip of a screwdriver, narrow piece of sheet metal can be good applicators.
The vials are better than cement tubes as you can see whether the cement started drying out or not and you can always a bit of solvent to keep it useful. Mineral spirits may work in place of white gas, but it would be the best to try out on a small quantity.
Rema has additives that speed up vulcanization, especially in contact with Rema patches.
2_i is offline
Old 08-22-22, 07:21 PM
tessellahedron
Quoted: 79 Post(s)
I had 5 or 6 tubes of cement when I moved last year. Three or 4 were completely empty. They looked full, but when squeezed nothing came out and they just flattened down. Another had leaked, another was almost gone, and the last one had a split cap. They were all generic garbage but even so, the pathetic performance pushed me to buy the can.
now I'm looking at other containers. I think I'll use a glass jar for the bulk of it and try the little dishes that THC concentrate comes in to carry on the bike. I found one type of dish that has a fully plastic lid and that's the closest thing I have to a vial.
I saved an empty hand soap bottle with the pump. That would be weird but I think it's too large.
Old 08-22-22, 07:24 PM
dedhed
SE Wis
dedhed's Avatar
Never used anything but the brush cap on those.
dedhed is offline
Old 08-22-22, 07:31 PM
2_i
Quoted: 840 Post(s)
I found 6ml (16x60mm) with alu caps to be the best for the road. https://www.ebay.com/itm/203928536989
2_i is offline
Likes For 2_i:
Old 08-22-22, 08:07 PM
BCDrums
Recreational Road Cyclist
BCDrums's Avatar
Quoted: 257 Post(s)
Liked 252 Times in 134 Posts
Rema, Rema, Rema
No kidding. You don't even say what you're using this goop for, but if you're patching tubes, discard the Slime product and get a Rema patch kit. Much less trouble. If you insist on a lifetime supply, buy the Rema can. Best of luck.
BCDrums is offline
Likes For BCDrums:
Old 08-22-22, 08:51 PM
sch
Quoted: 303 Post(s)
Liked 136 Times in 104 Posts
Slime is what I am using currently to patch tubes, IME such cans are good for about 5 yrs before evaporation thickens the
goop to the point of unusable. At $6-8/can I would throw it out but I haven't bought one in a while and note they are upto
$10-12 now. Slime is not 'vulcanizing' ie chemically reactive with the patch, which gives a somewhat superior bond to
such as slime, but IME slime or its analogues are adequate. Vulcanizing cement costs ~3x as much. If you patch a lot
Rema patches are on amazon in boxes of 100 for ~$20 or so.
sch is offline
Old 08-23-22, 06:11 AM
2_i
Quoted: 840 Post(s)
One should distinguish between solvent evaporation and vulcanization. If it is only evaporation, the solvent may be added and the cement can be made liquid again. However, after a number of years, this does not help and the vulcanizing fluid just turns into a ball of goo that does not react to the solvent. I.e., you cannot have a lifetime supply in practice. The lifetime is shorter for Rema.
2_i is offline
Likes For 2_i:
Old 08-23-22, 08:32 AM
pdlamb
Quoted: 2604 Post(s)
Liked 1,933 Times in 1,213 Posts
I've got the same stuff, but keep it for use at home. If you need pliers to open the can, you probably need to get some sturdy rags and clean the dried-up glue off the can and lid threads.
pdlamb is online now
Old 08-23-22, 08:38 AM
pdlamb
All true!
My father-in-law used to say, "Sometimes 15 minutes in the lab will save you a week at the blackboard." Of course it takes more than 15 minutes to see how well the two adhesives work on bike tubes, but I haven't seen a difference between Slime and Rema performance. From my point of view, Slime works as well, costs half as much, and (IME) lasts at least as long in the can and on the road.
Old 08-23-22, 08:41 AM
Crankycrank
Quoted: 837 Post(s)
Liked 1,061 Times in 745 Posts
Store the can upside down. Same effect as sealant in tubeless tires. Any slight leaks in the cap that allow evaporation will be sealed by the fluid.
Crankycrank is offline
Likes For Crankycrank:
Old 08-26-22, 11:18 PM
Camilo
Quoted: 1109 Post(s)
Liked 1,200 Times in 760 Posts
If all you're looking for is an easier way to apply a bike patch sized amount of the glue, get some "acid brushes". They're small, cheap, reusable, but disposible if/when they're messed up available almost anywhere, any local hardware or big-box store. Here's just one example:
HDX Acid Brushes (3-Piece) 80-721-111 - The Home Depot
Camilo is offline
Likes For Camilo:
Old 08-27-22, 02:29 AM
tessellahedron
Quoted: 79 Post(s)
I ordered some tiny vials (2ml I think) with orifice reducers. I considered the roller ball or eye dropper vials (they make them that small!) But the minimum order was 25 and I only wanted 5 or 6. The roller ball would be so awesome if it works and doesn't gum up. I may try it someday unless someone else has. Chemical compatibility is my next concern but the plastic capped vials are used in labs so I'm gonna try them. Good to know aluminum exist. Ty
if I get the slime cement on my fingers and smear across the edge of a patch, the patch will partially dissolve and spread out across the inner tube. I'm pretty sure that means it's vulcanizing. Real rubber cement works but is a different patching method and using it just like vulcanizing cement didn't hold for half a second when I did it.
EXACTLY! My dad had one of those on his work bench for years but I didn't know the name. Thanks!
Likes For tessellahedron:
Old 08-27-22, 06:45 AM
2_i
Quoted: 840 Post(s)
Remember that for, the same size of opening, the rate at which a vial will be drying out is coarsely inversely proportional to the volume. I.e., a 2ml vial will be drying out 3x faster than 6ml. A too large vial may start to be vulnerable to breaking, so there is some sweet point.
2_i is offline
Likes For 2_i:
Old 08-27-22, 11:00 AM
tessellahedron
Quoted: 79 Post(s)
finally someone else who thinks analytically!
I see what you're saying about the size of the opening, but that's with the top off. I've been looking at drying rate as function of the ratio of cement to air in the container. With each opening, assume 100% air exchange, and now you have X ml's of clean air for the volatile components of the cement to evaporate into.
after thoroughly overthinking everything, I ordered 1ml vials. I can't say if they'll dry out or leak or turn into solid platinum so I figured a single use size was the safe bet.
Old 08-27-22, 11:28 AM
2_i
Quoted: 840 Post(s)
With and without the top. Every seal in the world leaks, the question is just at what rate. With a full 6ml vial I can afford adding solvent once a year, with a full 2ml, I may need to add it every 4 months. Opening briefly for gluing does not need to matter. However, keeping the container only partly filled is expected to hurt.
2_i is offline
Likes For 2_i:
Old 08-27-22, 12:03 PM
tessellahedron
Quoted: 79 Post(s)
Since you're using vials too what's your applicator?
1ml is more than enough for one patch right?
Old 08-27-22, 01:10 PM
2_i
Quoted: 840 Post(s)
I carry an alu strip, 8cm/3.25" long, 4.5mm wide, a left-over from cutting an alu sheet, 1mm thick. I rounded corners, so I do not scar the rubber. I try to spread the glue very thin. It dries then quickly. I also spread it on the patch. The amount you spend is minimal. I think it is a small fraction of ml.
2_i is offline
Likes For 2_i:
Old 08-27-22, 02:58 PM
grumpus
grumpus's Avatar
Quoted: 499 Post(s)
Liked 434 Times in 333 Posts
Reduce the width of the brush with a sharp knife?
grumpus is offline
Likes For grumpus:
