Giant Halfway
Giant Halfway
It turns out the “schwinn” are actually giant HalfWay bicycles. Anyone have an opinion on them. The frame closure looks a little dodgy to me but I am not a folder guy.
Otherwise they look pretty cool.
TigerTom
TigerTom
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 452 Post(s)
Liked 405 Times
Are you saying that they were not Schwinn bikes but are Giant Halfways???
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
55+ Club,...
Bikes: 9+,...
Quoted: 1113 Post(s)
Liked 848 Times
Likes For tds101:
Seat post diameter??
I saw when adjusting the seat height on the bikes I purchased that there is a collar/shim between the 28.6 diameter seat post and the down tube. This collar only goes in 4 to 5 inches, which seems like a bad idea. Shouldn’t the seat post fit snuggly the whole length of the Dow tube?
Is this just a shortcut for a base model bike? Are larger diameter aluminum seatposts available?
TigerTom
TigerTom
Likes For bluesteak:
My aluminum Dahon seatpost is 34mm. However I don't think you have a problem; the minimum insertion marking on my post is 4.5" from the bottom, so that's a safe amount of overlap. If you insert more than the minimum, it shortens the lever arm and your safety factor is even higher.
Likes For Antifriction:
Quoted: 452 Post(s)
Liked 405 Times
Paul Pinigis
Paul Pinigis
Likes For Pinigis:
Thanks for your input. I’m old school where if your seat post stuck out 4 inches you needed a bigger frame.
Seems like I will need to adjust my thinking.
TigerTom
TigerTom
