Replacement brake pads for CLB professional brakes?
Old 09-20-23, 02:19 PM
Piff
Piff's Avatar
Quoted: 791 Post(s)
Liked 741 Times in 406 Posts
What brake pads have the proper bolt diameter fit for CLB professional brakes? Just purchased a set of brakes w/o the pads or holders. As I understand it, the bolt diameter is different between shimano and campy, of course...
Thanks!
(not my picture)
Piff is online now
Old 09-20-23, 08:40 PM
ZenNMotion
Bikes: 2016 Tom Kellogg steel Spectrum all-road, '89 Eisentraut Rainbow Traut, '81 Marinoni Special, 2018 Ritchey Road Logic, 2006 Ritchey Breakaway Cross, 2009 custom Joe Wells alu Tsunami CX, '71 Favorit (Czech Rep) Special, 2012 Co-Motion Tandem
Quoted: 5 Post(s)
Liked 7 Times in 6 Posts
I have no idea, but I solved a similar issue with a set of Suntour Cyclone calipers that (apparently) required a slightly smaller (like Campagnolo) bolt diameter when I already had several sets of nice polish finished Kool Stop brake shoes with new dual compound pads with larger Shimano spec bolts. A chopstick wrapped with a bit of sandpaper will solve the problem if the CLB brake arm slots need to be made a bit larger to accommodate Shimano-style shoes. Then you'll have lots of options without having to go down rabbit holes looking for arcane pads to fit modern shoes.
ZenNMotion is offline
Likes For ZenNMotion:
Old 09-20-23, 09:23 PM
PhilFo
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 163 Post(s)
Liked 261 Times in 179 Posts
Those look a lot like Modolo holders. When you get the calipers, measure the width of the slot and if you're at 6mm then you can fit virtually anything, even a modern threaded post pad with hemispherical washers for better toe-in.
PhilFo is offline
Likes For PhilFo:
Old 09-20-23, 11:30 PM
Bad Lag
Bikes: 1974 Bob Jackson - Nuovo Record, Brooks Pro, Clips & Straps
Quoted: 1104 Post(s)
Liked 794 Times in 452 Posts
When one is unsure, it is always best to wait until you have the parts in your hands to know for sure.
Did I say that correctly?
Bad Lag is offline
Likes For Bad Lag:
Old 09-21-23, 04:33 AM
oneclick
Quoted: 1105 Post(s)
Liked 1,324 Times in 781 Posts
I'd be wary of using a fixing-bolt smaller than the slot in which it is to go.
You don't want that to move.
I had a similar issue recently (cannot remember which combination of pad and caliper) and made a set of T-shaped flanged inserts, can do that again, pm me if you want to go that route.
oneclick is offline
Likes For oneclick:
Old 09-21-23, 06:33 AM
John E
feros ferio
John E's Avatar
Quoted: 1390 Post(s)
Liked 1,322 Times in 835 Posts
Number One rule regarding brake pad selection: If KoolStop makes something compatible with your calipers, or something you can adapt to use with your calipers, that will be by far your best option.
John E is offline
Likes For John E:
Old 09-21-23, 08:12 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,389 Times in 1,927 Posts
Why not just replace the pads instead of the pads and holders?
I suspect Kool Stop pads for Weinmann or Campagnolo holders ought to work:
https://koolstop.com/collections/insert-replacement
JohnDThompson is offline
Likes For JohnDThompson:
Old 09-21-23, 11:13 AM
Piff
Piff's Avatar
Quoted: 791 Post(s)
You guys are telling me to be rational and wait to measure the brakes when they arrive rather than obsessively search online for the appropriate substitute part!?!?
Well, yes, that's probably a good idea.
oneclick That's what I was worried about. I thought for a moment that I would simply purchase the brake pads w/ the smallest bolt size diameter, but realized there probably is a good reason for the bolt matching the slot nearly exactly. Thank you for the offer to make some inserts! If the slots end up being strange (i.e. French) I will definitely take you up on that.
JohnDThompson Unfortunately, the brakes have neither the pads nor the holders.
Piff is online now
Old 09-21-23, 12:15 PM
El Chaba
Quoted: 191 Post(s)
Liked 562 Times in 196 Posts
You might want to send Wayne Bingham at Mel Pinto Imports an email. Mel Pinto was an importer of CLB back in that time period. Wayne has all sorts of small service parts, and you might get lucky. As an aside, some models of Galli brakes from that time period used CLB pads and holders. That is another needle in a haystack, but on the bright side searching for them as well increases your chances by 100%.
El Chaba is online now
Old 09-21-23, 12:29 PM
Piff
Piff's Avatar
Quoted: 791 Post(s)
That is a wonderful lead, thank you! I am worried that modern brake pad replacements may not fit in the original holders, from my online looking it seems like it's a common issue.
But, there is this ebay listing which claims their pads fit the CLB pro holders! Here's to hoping Mr. Bingham has some extra pieces still.
Piff is online now
Old 09-21-23, 05:28 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1560 Post(s)
Liked 1,282 Times in 853 Posts
Without actually loosening the nut securing the pad, I can measure the slot in my CLB Professional calipers as being at least 7.4mm wide, possibly just slightly wider if I were to loosen the nut and slide the pad holder all the way out of the way.
My pads/holders are Gran Comp replacements, plain looking pieces having 6mm studs. The slot being a bit bigger seems not to interfere with adjustment, of with the security of the pad mounting.
These are great brakes if you are a lightweight, though may seem flexy if you are at all on the big side. I'm not using the Dural cable housings as mine came with Dia Compe cabling (on my sold-as-frame/fork-only Nishiki Pro from 1978).
dddd is offline
Likes For dddd:
Old 09-21-23, 06:27 PM
Piff
Piff's Avatar
Quoted: 791 Post(s)
Thanks, dddd ! Perhaps this problem is more of a mole hill than a mountain.
Good to hear they stop well, it's what I've seen written elsewhere too.
Btw, do these brakes require a different setup compared to regular single pivot brakes? As far as I can tell they don't have the usual wrench flats. Or, a nut at the front...They seem like one is supposed to simply center them like a dual pivot??
Piff is online now
Old 09-21-23, 06:55 PM
Steel Charlie
Steel Charlie's Avatar
Quoted: 365 Post(s)
Liked 523 Times in 275 Posts
CLB Professional is a contradiction in terms. One of a multitude of oxymorons in cycling marketing
Steel Charlie is offline
Old 09-22-23, 02:38 PM
Chombi1
Chombi1's Avatar
Quoted: 1635 Post(s)
Liked 823 Times in 532 Posts
Combine them with CLB's super lightweight, aluminum cased "Dural" cable set and it gets really interesting...... as in ultra spongy compressible feel. You lose like at least 50 percent of braking power, compared to using their regular steel cased brake cable set.
It's CLB's weight weeniness to a fault!
But then Jeannie Longgo did win a lot of championships using CLB "Professionel" brakes on her Vitus bikes during her long career......
Chombi1 is offline
Old 09-22-23, 05:25 PM
oneclick
The bolt (or long nut) is always going to be smaller than the arm slot or it won't fit in the slot and thread (rotate) into the shoe/pad.
Well, there's smaller, and then there's SMALLER.
A 6mm (nominal) bolt in a 7.4mm slot is going to be trouble.
oneclick is offline
Old 09-22-23, 06:23 PM
bertinjim
bertinjim's Avatar
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1970s Carlton Kermesse, 1982 Peugeot PB 12
Quoted: 343 Post(s)
Liked 262 Times in 154 Posts
Piff-
In the CLB box there should be a two prong, hooked wrench that will fit into the spring on the back of the caliper. It will allow you to tilt and hold the brake in position while tightening the fixing bolt. If it's gone, a similar one was available from Park tools.
https://www.parktool.com/en-int/prod...ategory=Brakes
bertinjim is offline
Likes For bertinjim:
Old 09-22-23, 11:26 PM
Piff
Piff's Avatar
Quoted: 791 Post(s)
Originally Posted by bertinjim
Piff-
Aha! Thank you.
Piff is online now
