Constantly logged out
Bikes: 1974 Motobecane Grand Record, 1987 Miyata Pro, 1988 Bob Jackson Lady Mixte (wife's), others in the family
Liked 172 Times
I have had a problem recently with the site logging me out, even with the page staying open in my browser. It's to the point that today I can logged in, read for a while, started a post, and when I went to post it, found that I'd been logged out and had to log in again. This is not happening with other sites.
Obviously I'm hitting 'remember me' every time I log in, but to no avail. I'm on Chrome on a Mac; the browser is the latest version that's compatible with my OS, which is Mojave, so not recent. No updates or changes on my end recently. Any help appreciated.
I never think I have hit hard, unless it rebounds.
- Dr Samuel Johnson
- Dr Samuel Johnson
Liked 5,002 Times
The only time that has ever happened to me is when for some reason the "remember me" box gets cleared.
Any time you clear your cache then you'll also likely clear that persistent cookie that gets set for that "remember me" function. So you'll have to again check that box and log in to the forum.
Perhaps if you are using some aggressive malware checking program or app, it might have gotten set up to remove the persistent cookie or whatever it is that gets set now when this is done. I think long ago, some browsers had a security setting that would clear all such cookies when the browser was closed. Might even still be there. But usually the default installation has that disabled.
Liked 172 Times
I should have thought of that before I wrote in. Did so this morning and that seems to have fixed the issue. Thanks!
- Dr Samuel Johnson
- Dr Samuel Johnson
Likes For Chicago Al:
Bikes: Gary Fisher Advance (1993, heavily modded); Fuji Absolute 2.0 (2010; modded); 1989 Miyata 512 (58cm; $50, thrift buy); KHS Classic (63cm, 12-spd); Schwinn World Sport (58cm); Schwinn Voyageur (58cm); 1987 Centurion Ironman (60cm); etc.
Liked 45 Times
I lost two paragraphs of text TODAY, in my Miyata 512 thread, because of this RIDICULOUS issue that has PLAGUED this forum for as along as I've been here.
Here's what happened ... completely serious ... was composing a follow up reply to another member Miyata 512 ... had to use the John ... came back ... added a few more words and submitted. And then the Logged Out message. So I simply followed the prompts ... usually, all is okay. But this time, something got stuck ... and it wasn't me as i have a clean movement ... but the BF screen was white for 10 - 15 min. And there was nothing posted. I clocked back arraor as sometimes the Aut-Save will have a copy in the buffer. But nope/
Two whole paragraphs and 1/2 hr poof gone.
Come on Admin ... this is plumbing emergency.
Likes For IBkatherine:
Liked 5,002 Times
Clear your cache. Then when you next sign on, make certain to check the remember me box.
If you don't wish to check the remember me box, then you can do like I use to do and remember to copy your reply before you post. Then you can paste it back if you are required to sign in after attempting to submit the reply.
Liked 45 Times
So have you performed any of the remedies?
The problem with "Remember Me" is that it never worked from the get go. I run Windows 7 and the latest Linux Mint, multiple computers. Same issue. The "Remember" forgets.
Not sure about phones. May work better ???
Liked 5,002 Times
elcyc Might be some browser issue. On Win7, Firefox is the only browser that still officially supports operations on Win7. Microsoft doesn't even support it's own browsers for use with Win7. That doesn't mean those browsers wont work. Just that as time goes by and more things change, you'll see quirks happening or things that just don't work correctly. But more likely your issue might be what I said in reply #3 above.
As for Linux Mint, have you tried different browsers. It's been a few years since I've run Mint, but it was the same for me with Mint. No issues as long as I had the "remember me" box checked at login. I used it with chrome and firefox. I don't remember if I ever used Duck Duck Go with BF.
But quite possibly your browser isn't hanging on to that persistent cookie for some reason. Although I don't know for certain that is the method BF uses for that process. But commonly it use to be. And since when I clear my browser cache I have to sign in again, I will think that's how they still do that.
Randomhead
Liked 3,806 Times
I've never had trouble with "remember me" on linux. I usually use chrome though
