crank interchangeable: Bafang vs Bosch?
For crank drive ebikes.
Are the cranks interchangeable? Same as ISIS / 4 taper/ Octalink pattern on bikes?
Quoted: 682 Post(s)
Liked 949 Times
bosch is isis spline and there are only a few brands that fit. like so https://praxiscycles.com/product/bos...arbon-ecranks/
Quoted: 668 Post(s)
Liked 529 Times
Odd. My BBSHD has standard square tapered crank spindles.
Quoted: 891 Post(s)
Liked 852 Times
[QUOTE=Pop N Wood;22983891]Odd. My BBSHD has standard square tapered crank spindles.
/QUOTE]
My BBS02 has square taper too, but I'm using Lekkie arms to overcome the bias in the distance from the crank to chainstay. Over the years I've had both square and ISIS on various bikes, and it's a tossup; I like the ISIS interface better, but the square bearings last (me) longer.
/QUOTE]
Bikes: 2019 KonaLibre- 2003 Litespeed Vortex -2016 Intense Spider Factory Build -2008 Wilier Mortorolio- Specialized Stumpjumper Hardtail converted to bafang 750 mid drive -1986 Paramount 2014 - --- Pivot Mach 429c
Quoted: 43 Post(s)
Liked 23 Times
the square tapered Bafang is crap. stripped out. very cheap metal. Have shimano cranks now. Likewise their stamped chainring I went with lekke offset
Quoted: 891 Post(s)
Liked 852 Times
I think he means the square taper became rounded. This happens when the system is cinched inadequately, and hasn't occurred on my wife's bike (which has the original BBS02 cranks) or on my bike(s) before I switched to Lekkie.
Quoted: 668 Post(s)
Liked 529 Times
Wow. Had not heard of that. Still doesn't explain how the OP had the splines.
I went with Lekkie stuff from the get go, never used the bafang crank arms. Wanted the better gearing. The Lekkie stuff shredded the self extracting feature so not sure how much better that is.
Randomhead
Liked 3,789 Times
Bafang OEM mid-drives* used to have ISIS cranks. Then they switched. But I have seen people talk about putting aftermarket cranks on them. There are still ISIS cranks being made.
*what do you call a mid drive that is made to be integrated into a frame?
