Kurt K power computer with Cycleops Trainer?
Has anyone tried using their KK power computer on a cycleops trainer?
How do you re-program the computer? I don't see any instructions in the owner's manual.
thanks.
joel
thanks.
joel
Bikes: 2006 Cannondale CAAD8
i do not believe it can be recalibrated. all it does it take the speed read and convert it to watts. it does not actually calculate watts and doesnt show accelerations properly.
FBoD Member at Large
Quoted: 30 Post(s)
Liked 7 Times
At least the old one could, there is the following reference on the website:
https://www.kurtkinetic.com/calibration_chart.php
Trainer Model A B Corresponding Formula
BlackBurn Fluid 9005 1000 9.00528x + 0.00999636x3
CycleOps Fluid 2 0747 4669 0.74715x + 0.0466912x3
Elite Fluid Alu 7113 0886 7.11346x + 0.00885877x3
Elite Volare 4660 1316 4.65979x + 0.0131627x3
Kinetic AC Pro 5245 1917 5.244820x + 0.01968x3
Kinetic Cyclone 6481 2011 6.48109x + 0.020106x3
Kinetic Standard Fluid 5245 1917 5.244820x + 0.01968x3
Kinetic Road Machine 5245 1917 5.244820x + 0.01968x3
PerformanceTravelTrac Century Fluid 4145 1217 4.145000x + 0.01217x3
Spinervals Super Fluid 4.5 5245 1917 5.244820x + 0.01968x3
I looked in the manual for the current models, doesn't seem to be that A/B setting.
I was going to pick up one of the older models on eBay just to have "watts" displayed, then pull it for non-trainer use.
Call Kurt, they'll tell you.
Bikes: 2012 Parlee Z5
Bikes: Lynskey R240, 2013 CAAD10
Quoted: 50 Post(s)
Right, I was referring to 0.74715x + 0.0466912x^3
If that's the case, than my trainer session on Wed evening left me with 105 minutes @ 295 Watts, which came after 3 harder days and was intended to be an easier effort.
Edit: I know I'm a strong rider, but there is no way I'm that strong.
(0.74715(x)) + (0.0466912(x^3))
and just change the x to your speed. 20mph is about 388 watts.
Quoted: 50 Post(s)
I averaged 18.2 mph after a 10 min warm up on Wednesday night for 1:45.
https://connect.garmin.com/activity/21842960
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
That sound pretty close to what I recall observing. Just for the heck of it, I did a chart for my Cycleops Fluid 2 when I got my PT. Don't know where I put the chart now though.
You could get lost and die.
You could hit a tree and die.
Quoted: 50 Post(s)
... Jeez, why did I have to spend so much on an engagement ring to where I blew all my powermeter monies?
pan y agua
Liked 727 Times
Actually went back and dug up the file. 20mph is around 290 watts, and 18 is about 230.
Of course precise results would vary by your particular unit, and thes etup, (i.e. how tight the unit is cranked to the wheel)
If anyone is interested I can email the file.
Quoted: 50 Post(s)
Well, here is something interesting... I found the old power curve for the previous Fluid2's w/ the knob to tighten (the new ones have a heavier flywheel and a few other changes). It's not quite as high as what KK says, but it's not too far off. Perhaps they just picked a point on this curve and formed an x^3 tread line equation. It seems, however, the fluid2 is only a squared equation and not a cubed, like the KK.
Bikes: Bianchi Giro
Quoted: 50 Post(s)
It would really depend on the time someone is able to maintain that number in order to determine the weight. For the type of ride I did, and my weight (80 kg), it's not too shabby, especially considering that with KK's equation my FTP would be around 480-500 Watts.
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
As long as you realize how unlikely that is...
Bikes: Bianchi Giro
Don't look to me as the artiber of what is impressive. My only point was that power by itself is fairly meaningless as weight/size matters as well. Someone who is larger/weighs more is going to require more power to go the same speed. Some people post some very "impressive" power numbers but you have to realize that they are very large as well. Someone who is tiny might actually be faster on much lower power. That is why we generally discuss power as Watts/Kg. However it should be noted that on flat ground it's actually Watts/CdA (coefficient of aerodynamic drag) that matters, it's just that it scales roughly with weight.
Edit: I'm about 65kg. All things being equal, 295W would be "more impressive" for me than silversx80 at 80kg.
And don't get me started about speed on a trainer
20 mph = ((5.244820)(20)) + ((0.01968)(20^3)) = 262 watts.
Look at this chart for watts per kg for specific abilities
https://www.cyclingpeakssoftware.com/...profile_v4.gif
This is the formula for power on a KK Road machine where x is speed in mph.
((5.244820)(x)) + ((0.01968)(x^3))
Here is the chart made from the formula above for the power levels of a KK Road Machine Trainer. I have a powertap and my power is always within 5 watts of the chart.
https://www.kurtkinetic.com/documents..._Curves419.pdf
Take your weight and convert to kg. find a w/kg at a level you think you might be in the FTP column. find the watts and corresponding speed to get those watts. get on the trainer and see if you can hold it for an hour. if you dont have an hour do it for 20 minutes but your ftp will be 95% of the 20 minute power.
pan y agua
Liked 727 Times
. My only point was that power by itself is fairly meaningless as weight/size matters as well. Someone who is larger/weighs more is going to require more power to go the same speed. Some people post some very "impressive"power numbers but you have to realize that they are very large as well.
Case in point, my FTP by my last field test was 331. As for the weight side, lets just say its well north of 80kg
