Measuring a stem length?
Mike J
Bikes: 1975 Peugeot PX-50L, 1971 Peugeot PX-10, 1974 Peugeot PX-8
Quoted: 392 Post(s)
Liked 6 Times
Wondering how you determine the length of a stem. For the one shown, if I measure the length as center of the steerer-post to the center of the handlebar clamp, along the length of the extension, there's a different measurement (105mm) than if I measure from the center of the steerer-post, perpendicularly, to the center of the handlebar clamp (95mm).
[IMG][/IMG]
[IMG][/IMG]
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,833 Times
I lay my ruler on the top of the stem, then measure ctc. Conforms to what's on the stem, usually.
carpe diem
Bikes: CAAD 9 , Schwinn World, Prologue, Madison , Sports Tourer ; Ironman , Opus lll , Allez , Peugeot 753, Trek 531 (2) , Assenmacher ( custom)
Quoted: 10 Post(s)
I would measure the center of where the steerer bolt pops out of the top of the stem , to the center of the clamp area .
Its the center lines of the Bar bore , and the bolt centerline* .. center to center..
*which is also the steerer tube center line .
Quoted: 1829 Post(s)
Liked 3,375 Times
The general convention is to measure along the length of the extension. This is illustrated in the photo below by the use of the calipers to measure the extension.
The only exception to this (that I know of) is the Nitto Pearl. In the photo below, there is an illustration on the Pearl's box that shows how it measures the distance perpendicular from the quill to the center of the handlebar.
As shown, the Pearl 9 measures 90mm using Nitto's method, while the conventional method would tend to suggest 100mm.
Steve in Peoria
Steve in Peoria
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I agree with the above, that traditional quill stems, that have a horizontal* extension when installed, are measured center to center on the horizontal plane.
*These typically have a 17° angle between quill and extension, and so ideally fit a bike with a 73° head tube.
The problem with that, however, is that for the last 30 years or so they've been making stems with a variety of angles, which are not always indicated in a uniform manner (a stem with a 90° angle is sometimes called a 90° stem, sometimes 0° rise). Add to this the phenomenon of threadless stems that can go either easy, +10° or -10°, and so on, things can get very confusing.
When I measure a stem now, I measure it as if it had a 90° angle. That is, a dimension perpendicular to the steerer, measured center to center; this is the length of the stem, and it is a property of the stem. At the same time, I measure stem height, which is a property of the setup of the bike, since it is variable.
Bikes: 1974 Copper Raleigh International, 1975 Olive Green Raleigh Grand Prix, 1974 Raleigh Europa Custom
Quoted: 104 Post(s)
Steve in Peoria
Steve in Peoria
Decrepit Member
Mike J
Quoted: 392 Post(s)
Liked 6 Times
Steve in Peoria
Steve in Peoria
Maybe i'm making it too difficult, but the engineer in me wants it to make sense, and I've seen countless ways of measuring it. My understanding is that I'm wanting to measure "reach", and I keep seeing "reach" as a horizontal measurement, since the quill stem's top is normally horizontal when installed, and that "reach" would only go horizontally if I stop my measurement at the center of the steerer, and not at the top of the bolt.
So, if I want to sell a stem and need to accurately describe its dimension, I just want to make sure I give a correct measurement, or at least make sure myself and a buyer have the same idea of what reach is.
Liked 3,375 Times
Yeah, for some reason I had a brain-freeze when measuring one. In your example, I see how you got 100mm, but if I drew a line from the center of the bars to the center of the steerer tube, along the axis of the center of the horizontal part of the stem, it would be less by 6 or 7mm. Your example extends the reach by measuring center of the bars to top of the stem, which offsets the angle of the 73-degree horizontal plane, since you don't go along the center, but upward to the bolt's top.
1. measure along the extension (illustrated with the caliper). This is generally from the center of the bolt to the center of the handlebar. I don't know if I've seen a drawing from a manufacturer that clarifies whether it is from a line drawn through the handlebar center that is parallel to the quill axis, or through the "vertical" axis as my measurement uses. I'd have to run the math, but I think the difference would be a couple of mm at most. (edit: about 4mm)
2. measure perpendicular from the quill to the handlebar center. This is illustrated by Nitto and shown on the box in the photo.
Method #2 seems to be what you are describing in the text I quoted.
...but... as you note, if there is any doubt, always confirm that both the buyer and seller are using the same method.
As the saying goes... "the nice thing about standards is that there are so many to choose from".
Steve in Peoria
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
Unfortunately lot's people dont use the traditional way to measure stems - or frames for that matter. as I've found out the hard way several times.
Likes For exmechanic89:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Interesting thread here, I think that this subject has been discussed before?
For sure, those particular stems from Nitto, end up being longer than stated on the packaging, which is an oddity.
But there are two very common other ways that stems are measured, always parallel to the extension by the way.
Lower-end and Japanese stems, with few exceptions, measure stem extension "drafting board" style, which is center-to-center, along the centerline of the extension.
Higher-end, mostly Italian racing stems measure them across the top, from the center of the bolt to the center of the bars.
I believe that this is because actual racers and coaches are the ones who might actually make field measurements, and measuring on-center instead of across-the-top is mechanically awkward to achieve. So this is for serious users, not so much for parts-spec'rs sitting in a chair in their office.
The "Italian way" as I call it gives about a 5mm-longer measurement, so yields a 5mm-shorter stem in the real world, and this applies to all Cinelli and TTT stems and most ITM stems as well. Gravity-cast ITM stems turn up which are measured the "Japanese" or "drafting table" way, so will net a longer actual stem.
Most Nitto stems seem to be measured the "draftsman's" way, however the Nitto-made Shimano stems measure the "Italian" or "field" way, across the top, so will come up 5mm shorter as mounted.
(I've also noticed that most such AX/EX stems will accept a 26.4mm handlebar, fwiw).
Rhm mentioned measuring stems perpendicular to the quill, which makes the most sense since this is perpendicular and thus independent from the adjustment of quill height!
My own way of tagging my stems (after first grouping them by clamp diameter) is to add an "A" suffix to my written "95" or whatever, and which means "actual" or center-to-center on-center (drafting board style). This is just because I started out with a lot of cheaper equipment way back then, and the Japanese stems measured this way.
Nitto's "sometimes" way of measuring the perpendicular offset makes the most sense, but never caught on with the industry.
And like Yang07 mentioned, how the bike fits on the road (with the actual rider balanced fore-aft over the bottom bracket axis) is all that matters, at least within any particular range of riding intensity.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,484 Times
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Stem Length Suppositions
ZOMBIE THREAD! ARGH!
Yang07 we'd like to welcome you as a new member to the Forum.
Suggestion: the unofficial protocol/etiquette within the Forum generally discourages calling up older threads especially ones dormant for a few years.
One reason, other members have to scroll down through a lot of messages that may be unrelated to your interests to find your post.
The preferred/recommended approach is to start a new thread, especially if you want to post a supposition for discussion that's easy to find and starts at the top of the other posts.
As dddd mentioned "Interesting thread here, I think that this subject has been discussed before?"
A Google search of Bike Forums will find lots of related threads.
To put my 2¢ in, many quill type stems have the size stamped or molded into them. For whatever reason Nitto stems are 5mm longer center to center than the size listed on the box and the stem itself.
... and as SurferRosa mentioned, for many years, 3TTT stems came in 5mm increments. So did some early Cinelli and ATAX stems.
BITD, this was the standard method for measuring stem length. It worked as a starting point for years:
The human body is an amazing organism that can quickly accommodate to a lot of physical situations like minor differences in stem length, bar and saddle height an so on.
Fine tuning those adjustments plus changing some components as needed are what helps to make a bike fit comfortably especially on rides over a few mile long.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 472 Post(s)
Liked 1,028 Times
Right? Wrong? So what?
Likes For Prowler:
Quoted: 1079 Post(s)
Liked 1,899 Times
verktyg
Liked 1,238 Times
Spam! Spam! Spam! Spam!
Check out this post in the Commuter forum: https://www.bikeforums.net/commuting...l#post22184996
BTW, nation of origin listed as NM...
verktyg
Chas. ;-)
Chas. ;-)
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,599 Times
Likes For cb400bill:
Liked 1,296 Times
Yang07'spost got pulled, and which now makes it look like I was the one who revived this zombie thread.
Oh well, mods got to do what they gotta do.
Gotta admit that I got pulled in by a bot, probably not the first time...
