Airport and trailers (bike) how is it and bob trailers
Old 05-21-18, 02:27 PM
first trip
Quoted: 57 Post(s)
hi
im looking for purchasing a trailer for bike tourring
Bob trailer seems very good but i read that in ariports they are causing problems since they cannot fold and are very big
ANyone has airport experience with a yak trailer (positive or neg)
Maybe explain how it works.
thx!
first trip is offline
Old 05-21-18, 03:35 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
tow fork in backwards, inside the load area, and zip tie the rear wheel to the deck and it wont be as big..
put it and your gear in a big duffel bag..
haven't bought it yet? look at extrawheel ?
https://www.bikeshophub.com/product/...trailer-p-1377
use another front wheel like your bike has on it..
fietsbob is offline
Old 05-21-18, 06:46 PM
first trip
Quoted: 57 Post(s)
I have not chosent yet .
I read that in some airport it is not possible to travel with it (even unmounted).
One other person said that it was too big(evne unmounted to even be in the oversized luggage category.
what kind of experience with which airplain cie did you have ?
Old 05-21-18, 07:43 PM
saddlesores
saddlesores's Avatar
Bikes: inferior steel....and....noodly aluminium
Quoted: 1054 Post(s)
Liked 341 Times in 229 Posts
flew with bob on japan air long ago.
bike goes in bike box, trailer goes in DIY cardboard box. check airline regs for oversize limits first.
remove the yoke (2 hex bolts) else it takes up too much space. that leaves the deck area of the trailer free. put some padding on the two front tabs and on the dropouts at the back.
stow the yoke in the drybag and fill with as much gear as will fit and still be within the weight limit per piece. bob wheel and fender on top of (or in) the dry bag...tape it shut.
you should be able to spread all your gear betwixt the two boxes so only need to check two pieces. one pannier can be used as carry-on.
saddlesores is offline
Old 05-21-18, 08:06 PM
first trip
Quoted: 57 Post(s)
r betwixt the two boxes which boxes are you talking about. ENglish is only my second languange. Are you saying that once unmounted all the trailer can go inside the dry bag?
if you have image could be nice
Old 05-21-18, 08:32 PM
saddlesores
your bike goes in box #1....a regular cardboard bike shipping box from a bike shop.
the drysack is the waterproof bag that comes with the trailer. it fits inside the trailer to hold your gear. trailer will NOT fit inside the bag. load whatever will fit in the bag (and still be under the weight limit). the bag sits in the trailer like normal. must remove the yoke...if you just turn it back, the bag won't fit.
the trailer with loaded dry bag goes in your cardboard box #2 . get a big cardboard refrigerator box and cut to size.
assume you'll have two saddlebags. load one with gear, should fit inside the bike frame if you remove the water bottle cages. the second one is your carry-on.
Old 05-22-18, 05:06 AM
Philly Tandem
Bikes: Too many! Santana tandems and triplet; MTBs; touring bikes
Quoted: 88 Post(s)
Liked 19 Times in 15 Posts
I have a BOB but have never flown with it. That said, I'm pretty sure you could get it into a box sized for free carriage on the airline. Just custom-make a box that fits within the 62" size limit (L+W+H = 62").
I have traveled with a Burley trailer several times (Burley Solo child trailer) and was able to get it into a checkable box, but it took a lot of disassembly and I custom-made the box. I think a Burley cargo trailer would probably pack down to a small-enough size easily.
Philly Tandem is offline
Old 05-22-18, 06:31 AM
Aushiker
Aushiker's Avatar
Bikes: Surly Long Haul Trucker, Salsa Mukluk, Riese & Muller Supercharger GT Rohloff (Forthcoming)
Quoted: 103 Post(s)
Liked 27 Times in 22 Posts
I have an Extrawheel trailer and have flown with it a couple of times. Both with my Surly Long Haul Trucker. First time I went the two boxes route but the second time I got the bike and trailer into the one box.
Aushiker is offline
Old 05-22-18, 09:44 AM
fietsbob
Bikes: 8
More bike trailers
https://www.radicaldesign.com/bicycl...-trailers.html
https://carryfreedom.com/#2 .. https://carryfreedom.com/the-y/
fietsbob is offline
Old 07-31-19, 08:53 AM
first trip
Quoted: 57 Post(s)
how would you compare bob trailer t o extrawheel?
Old 07-31-19, 11:19 AM
saddlesores
hi first trip!
i see you're posting trailer questions to the trailer thread you started over a year ago.
what have you learned in the intervening 15 months?
have you had time to search the interwebs for reviews?
have you popped by an lbs to view the trailers?
have you perchance test-driven a trailer at a bike shop?
have you taken your first trip yet, first trip?
if so, how much stuff did you carry, how did you carry it?
do you truly need a trailer?
Likes For saddlesores:
Old 07-31-19, 03:27 PM
gauvins
Bikes: Custom built LHT & Troll
Quoted: 846 Post(s)
Liked 149 Times in 106 Posts
We use an extra wheel when family touring. My wife pulls our younger daughter, I pull an extra wheel loaded with extra luggage.
1. Extra wheel is less expensive.
2. It will allow you to carry 2x20L+ Ortlieb panniers. A Bob can carry larger items.
3. Extra wheel fits inside a flight bag, with the bike. No extra luggage. A Bob isn't flight friendly.
4. Extra wheel can be pulled on a single track. Or riding close to the edge of the road. Better than a 2-wheel alternative. Even a Bob might be tricky.
5. Extra wheel is very easy to remove from the bike. When you've reached your campsite, 5 seconds and your bike is free.
6. Extra wheel weighs a couple of kilos.
gauvins is offline
Old 07-31-19, 09:05 PM
first trip
Quoted: 57 Post(s)
cool tx
Old 07-31-19, 09:09 PM
first trip
Quoted: 57 Post(s)
hi first trip!
HI i tried a bob . it feels good except when jacknifing or bike falling on the side. my biggest issu is to instal on a 12m axle 1,25 (no through possible for my setup). I wonder how people lock their bob when they go do grocerys to avoid people grabbing stuff for the bag.
Old 08-01-19, 02:24 PM
Philly Tandem
Quoted: 88 Post(s)
Burley flatbed or cargo trailers pack down fairly compactly, but sounds like you want a single-wheel trailer.
treebound
Utility Cycling
4
03-29-16 05:31 PM
PatrickGSR94
Utility Cycling
6
04-01-14 06:45 AM
VT_Speed_TR
Touring
6
05-27-13 05:11 AM
jscalia
Folding Bikes
5
06-30-12 04:56 PM
dgeller
Touring
6
02-20-10 12:09 AM
