P-clamps issue
P-clamps issue
I want to attach a rack to a bicycle but the bike frame does not have eyelets. I plan to use p-clamps but the the frame at the clamping point is not completely round. It flattens out about where the wheel begins. Can a p-clamp tighten on a more rectangular surface?
Quoted: 581 Post(s)
Liked 921 Times
Probably, yes, but it might move around a bit and require tightening after a few rides and it has found its natural resting place. However, P clamps are not great for holding a load - they will probably eventually break if you are using them as structural supports at dropouts. This is not a problem with using p clamps on the seat stays for the upper supports because these don't hold any weight. But at the dropouts they're best for only light loads.
Likes For ClydeClydeson:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
What kind of bike are you clamping on? Carbon is a no go and if the frame isn't designed for a rack probably that is the manufacturer saying maybe not a rack. Remember if you do end up using p-clamps you will likely void the warranty, and won't be able to hold as much weight.
Bikes: Merida Speeder
Quoted: 233 Post(s)
Liked 165 Times
For road bikes, look at something like this:
https://www.axiomgear.com/products/r...iner-road-dlx/
It attaches via the rear QR skewer and the seatstay bridge eyelet.
Likes For PDKL45:
Quoted: 383 Post(s)
Liked 690 Times
Likes For kahn:
Quoted: 5224 Post(s)
Liked 3,584 Times
one might use some padding around the frame part so that the p-clamp will be snug
this is a home made clamp, on the right
I use p-clamps to hold the rack on my road bike, but it's not ideal. they are strong enough but there are more elegant ways to do it
this is one of mine. it is not quite tight enough but there is minimal movement due to it's location, but the frame does show some wear
Likes For rumrunn6:
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
Use them at work.
Yes they’re strong enough.
But all the work applications clamp around much thicker wall thickness than a bike frame. FWIW.
Also, if clamping around something not actually round, might have to experiment with the next size down than you might think and re-bending and re-tightening after awhile.
