11 speed cassette with a 16T
Liked 2,972 Times
Looking for a Shimano or Sram 11-32T cassette that contains the 13-14-15-16T in the grouping. Any suggestions? Some sites don't list the full breakdown & others show it only available with a 11-28T
-Oh Hey!
-Oh Hey!
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,470 Times
DM-RACS001-02-ENG.pdf (shimano.com)
Cassettes | SRAM
Only the SRAM version of the 11-28 cassette has a 16T cog, but it does not also have the 32T cog which you seek.
Liked 2,972 Times
What you are looking for does not exist:
Cassettes | SRAM
Search for "shimano cassette dealer manual" to find the individual cogs in a Shimano cassette.
Cassettes | SRAM
-Oh Hey!
-Oh Hey!
Liked 1,470 Times
Advocatus Diaboli
Quoted: 4735 Post(s)
Liked 1,532 Times
https://edco.bike/collections/monobl...33253771083916
Likes For Sy Reene:
Liked 2,972 Times
Came across references to this outfit in another thread.. pricey stuff built for weight weenies.. but maybe of interest:
-Oh Hey!
-Oh Hey!
Liked 2,972 Times
probably could remove the shim on the hub for it.... is it a 11T with 34T or 32T
-Oh Hey!
-Oh Hey!
Liked 1,470 Times
Liked 2,972 Times
11-13-14-15-16-------32
As long as I can get the 15, 16, & maybe even 17 together on a 11-32T 11spd assembly, it'd be sufficient.
-Oh Hey!
-Oh Hey!
Quoted: 767 Post(s)
Liked 1,740 Times
you could get a 14-28, get rid of the 12 in your existing cassette and add the 16.
Advocatus Diaboli
Liked 1,532 Times
Edco does not make a 11-32 cassette with only single tooth gaps between the 13T cog and the 16T cog as Troul wants; I thought he was asking about a custom cassette for which he can specify the individual cogs.
Quoted: 3240 Post(s)
Liked 2,086 Times
According to Mike Shermans gear chart, Shimano has an 11 spd. 11-32 with a 16. Says 11-12-13-14-15-16-17
https://mike-sherman.github.io/shift/
Don't know if it exists.
Liked 2,972 Times
Liked 1,470 Times
Quoted: 767 Post(s)
Liked 1,740 Times
Yea, I know, what I was thinking is get both, pull the 12 and add the 16.
Likes For jaxgtr:
Liked 2,972 Times
Liked 2,972 Times
going to dig in the ole parts cabinet tomorrow evening to see if I have an old 8 or 10 speed cassette that may be able to donate a 16T....
-Oh Hey!
-Oh Hey!
Liked 1,470 Times
I have tried to create a custom / Frankenstein 11 speed 12-28 cassette from two donor (12-25 & 11-28) Ultegra cassettes, but could not get the downshift across the transition (between the two donor cassettes) to work properly. YMMV, good luck.
Liked 2,972 Times
Wouldn't the 8 speed version be too thick to work in an 11 speed drive train?
-Oh Hey!
-Oh Hey!
Liked 1,470 Times
My Frankenstein Ultegra cassette was intended to replicate a Shimano DA 12-28 cassette: 12-13-14-15-16-17-19-21-23-25-28. Detailed here:
Bike Forums - View Single Post - Custom 12-28 cassette
Quoted: 767 Post(s)
Liked 1,740 Times
I just did check of my extra cassettes thinking I had a 11-32 but it was an 11-30,
Liked 2,972 Times
i'd thought that sweep would be easy for the system... Did you have the back spacing, shim, in between spacers, & chainline good? New cable & housing?
-Oh Hey!
-Oh Hey!
Advocatus Diaboli
Liked 1,532 Times
I guess a 12-32 option is out? Would require a freehub swap to campy, but I've been pretty happy with the centaur 12-32, a relative bargain these days at under $70
12-32 Teeth (12-13-14-15-16-17-19-22-25-28-32)
Liked 2,972 Times
