Remove tubular glue from. rim.
Quoted: 261 Post(s)
Liked 346 Times
I installed a tubular tire for the 1st time yesterday. It was really messy but you got to start somewhere. I got glue everywhere the brake track on the rim. Is there any way to remove it without damaging the tire or rim. I can't just have the brake pads rub it off as I ride fixed gear with no brakes.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
On a brakeless track bike, there's no compelling reason to remove glue from the rim sidewalls. Dave Tesch used to glory in this, smearing mass quantities Clément red rim cement with little regard for where it ended up.
But if it bothers you, a rag with some odorless mineral spirits should soften the glue enough to allow it to be scraped off.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Mineral spirits probably won't do it. I've always used lacquer thinner, it works great especially if you clean right after mounting the tire. I've probably mounted over 1500 tubulars so I've tried everything. Lacquer thinner is by far the best, most easily acquired, not hugely nasty stuff you can get. I can't stand seeing glue on rims/tires, to me it means that the person that installed the tire doesn't really care about the quality of their work.
Likes For cxwrench:
Quoted: 4806 Post(s)
Liked 3,932 Times
I got some Tubasti rim cement on my rim doing my first in 20 years. Took it off with lacquer thinner just fine but cvould not get rid of the noisy "grabbies" of the brake shoes using more lacquer thinner, Simple Green and dish detergent in all possible orders. Then I read here about treating the rm with garden dirt. Yup, Works. 500 or miles later I might have to give it another once over.
Quoted: 506 Post(s)
Liked 639 Times
