Crown Race Reducer for Merida Speeder 100 Fork
Bikes: Merida Speeder
Quoted: 233 Post(s)
Liked 165 Times
I have a Merida Speeder 100 https://www.merida-bikes.com/en/bike/3127/speeder-100. It has a carbon fork with a tapered steerer tube. The headset is a "Merida M2341 Neck" and I cannot find detailed specs for it on the Merida site.
I am interested in replacing the Merida 100 carbon fork with a Surly Disc Trucker fork. Axle-to-crown and offset are just fine, but the Surly fork has a straight 1 1/8" steerer tube.
Can anyone please help me work out what sort of crown race reducer I would need?
Would any 1.5" to 1 1/8" generic crown race reducer work? Like this one for example: (https://www.bike24.com/p2264279.html).
Or is there something I am missing?
Thanks for any help in advance.
Edit: Sorry, the title should have read "headset" rather than "fork." I want to fit a 1 1/8 straight steerer tube fork in a tapered headtube. TIA.
Quoted: 4205 Post(s)
Liked 3,864 Times
Check out Cane Creek's offerings for a complete headset with a mixed upper and lower stack spec.
Thanks for providing us links to your bike and possible crown race, so many people don't give us easy access to what they have looked at. I do note that Merida gives no dimensional info in the spec sheet. No surprise as this info is not needed to sell a bike So, I can't say if the crown race will fit the fork. It is not an adaptor but a complete replacement race. Whether the conical bearing seat is of the right diameter and angle to match up with the OEM bearing. OR whether the replacement crown race will interface with the OEM lower stack's outer "skirt" and seal. The proposed race looks to be shaped for a specific headset and not at all what I would call "generic".
Without more info I will say that you need to have the bike/fork in hand to measure before you will know what works and what almost but not quite fits. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
You could potentially do it but why? Just run that bike into the ground and save up money towards a bike that makes more sense for you? That fork is probably the nicest parts on the bike and not one I would remove.
Quoted: 2026 Post(s)
Liked 1,096 Times
The factory headset seems to be an FSA No.57/No.61BP and it isn't available with a bottom assembly to fit a 1-1/8" straight steerer. Cane Creek doesn't appear to offer a suitable lower either. Check with your dealer but I believe you are out of luck.
Likes For HillRider:
Quoted: 233 Post(s)
Liked 165 Times
Thanks for the info. I am keen to run SKS bluemels fenders and a Racktime Topit rack, as the carbon fork doesn't have an eyelet in the fork crown. I get that there are clip on fenders, but they don't have the coverage want, or the ones that do are unavailable to me. I actually have fairly inadequate clip on fenders on it right now. Lots of Speeders online--even the newer revamped models--have a fender mounting eyelet on the rear of the fork crown in photos, but mine lacks one for whatever reason. I'm sick of snow melt water in winter and water during rainy season commutes, as well as mornings after overnight showers, but I guess I'll work something out.
Edit: I've actually been quite dumb, in that the answer was there all along, had I actually dug deeper and checked something out properly. Looks like I've just worked something out.
Quoted: 233 Post(s)
Liked 165 Times
If anyone finds this thread through Google, looking to insert a 1 1/8 straight steerer tube into a Merida or similar bike with a tapered headtube and tapered steerer tube, look closely at the headset. For Merida it's zero stack, so the stock tapered headset will look like ZS44/28.6-ZS55/40 (ZS for zero stack and the other measurements for tube diameters). You can use any ZS44/28.6 headset top portion, but you will need to find something like a ZS55/30 bottom headset portion for 15 Euros or something. My advice is don't accept defeat, teach yourself what the numbers mean and then find the part you need.
Likes For PDKL45:
