Late-80s Basso?
Quoted: 25 Post(s)
Late-80s Basso?
This might be a 1988 Loto(?) from my quick search on the forum. I'm interested in buying it as my first road bike but I wanted to get more information before driving the 80 miles to see it. The crankset is Campagnolo but the groupset is Shimano 600? And Shimano 600 is the old version of modern-day Ultegra?
I am 5'7" and the frame is 54cm which I hear is the biggest frame size for my height. But I read that Basso bikes also have a longer top tube?
It is selling for $350. I appreciate any information you can share about this bike.
Bikes: '71 Raleigh Inter, '98 Tommasini, '83 Trek 500, 83 Trek 720 '
Quoted: 118 Post(s)
Liked 199 Times
I'm not a Basso expert, however i am lead to believe they are good bikes, Italian of course, nice chrome front lugs, what looks alike a columbus tubing sticker, it depends on the tubing type as to whether the bike would be considered mid level or
upper level, so that being said, would i buy it... in a heartbeat at $350, i am suprised it has shimano 600 tri color components mixed with campy headset and crankset and brakes , i would definitely convert to all campy..
check for frame damage as best you can then....
Buy Buy Buy..
Buy Buy Buy..
Quoted: 804 Post(s)
Liked 2,985 Times
Lotto?
should have columbus slx as the Lotto was the top dog.check for splines in the fork steerer tube.also look real close for any stress hairline fractures.
Edumacator
Quoted: 2440 Post(s)
Liked 3,129 Times
Basso makes quality stuff in steel. Loto is not my favorite of the Bassos but as stated above was the top rung. It’ll ride like a dream, stable and comfortable yet nimble and stiff.
The frame alone is a $300ish piece...the tricolor RD, FD and shifters, though somewhat sacreligious, are really solid pieces.
Check at the seat lug!stays attachment area, and the top tube/fork that everything is straight. If it is, that’s a bargain.
Quoted: 656 Post(s)
Liked 469 Times
That’s a great price.
It will be interesting to learn how long the top tube really is. Someone put a long-reach stem on it to stretch it even longer.
Quoted: 1819 Post(s)
Liked 1,696 Times
Buy Buy Buy..
Buy Buy Buy..
That bike is filthy, present owner gets an F- for presentation
Quoted: 601 Post(s)
Liked 781 Times
My guess is that the Shimano derailleurs were installed because they shif far better than the Campagnolo derailleurs of the same era. It was very common for bikes to have a mix of components at that time, especially if they were built up from a bare frame
Bikes: yes
hm Right
Quoted: 211 Post(s)
Liked 199 Times
BUY IT NOW !!!!!
I have a 1990 Loto and has a mix of Campy and Shimano.
These were sold as frames......and as stated above.......shimano ......shifts......VERY SMOOTH !!!!
If this was in my area, I would go BUY it !!!
And...as stated above...seller did not even clean it up for sale.
Probably was sitting around in the attic of the bike shop, and was discovered.
Either way, looks to be in VERY nice shape. Will clean up nicely !!!
Even though I am " thinning the heard" ...slightly
Did you buy it ********************??
Quoted: 25 Post(s)
BUY IT NOW !!!!!
I'm hesitant because I have a short torso and the bike is made longer with the stem ><
Quoted: 211 Post(s)
Liked 199 Times
It IS a Loto !!!
You can tell by the seat stays.
100% sure
If you don't buy it let me know contact info so I can buy.
Thank you
Michael
Quoted: 25 Post(s)
Something like this? https://www.theproscloset.com/produc...BoCgfAQAvD_BwE
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
If it's too long for me, can I can get a short-reach stem to replace the long stem?
that would be a lovely addition to that bike
Quoted: 1119 Post(s)
Liked 2,255 Times
Quoted: 25 Post(s)
I'll have to keep searching for a bike, one that I don't have to mess with.
Quoted: 656 Post(s)
Liked 469 Times
Quoted: 25 Post(s)
Plenty of shorter reach stems still around but you don’t want anything like the one in your link. Stick with a traditional 1” quill stem. You’ll also need to make sure the bar clamp diameter matches the bars you have. The stem currently on the bike looks to be a reach of 120cm-130cm. You may find this works fine. If you feel too stretched out, get a shorter reach. 100cm would probably be more common for that bike.
Quoted: 656 Post(s)
Liked 469 Times
I use a threadless stem on one bike that I resto-modded with modern STI shifting. There are two reasons I went threadless in this case: 1) I really wanted to use Ritchey Classic handlebars and they were only available with a 31.8cm clamp area. 2) I needed quite a bit of rise and the quill equivalent would have been too much quill IMO.
Likes For plonz:
Edumacator
Liked 3,129 Times
Honestly, the top tube will not be an issue with the correct stem, whether quill or a bit of a modification.
I have not found my Gap to have any longer top tube than other frames of its ilk.
Thats a solid buy.
Thats a solid buy.
Likes For jdawginsc:
Bikes: Road: 1972 Raleigh Competition,1989 Marinoni, 1990 Limongi. MTN: 1990 GT Team Avalanche, 1991 Rocky Mountain Blizzard, GT Team RTS , Rocky Mountain MSL 50 Element, CCM fat bike
Quoted: 35 Post(s)
Liked 81 Times
The picture that shows the stem seems distorted with the handlebars at the edge of the frame. It could be the original stem. If the seller has changed parts, they may include the old parts.
